D600 gets 94pts DXOmark
Started Sep 19, 2012 | Discussions
TrojMacReady
TrojMacReady Veteran Member • Posts: 8,683
Re: D600 gets 94pts DXOmark
CyrusK wrote:
oklaphotog wrote:
I don't think it's confirmed as a Sony sensor, it may be a Nikon in house design fabbed by either Renesas or Sony. According to the DPR listed specs they are not the same....
D600 Sensor Size: 35.9x24mm
D600 Max Res: 6016×4016
A99 Sensor Size: 35.8×23.8MM
A99 Max Res: 6000×4000
I agree... There is still some doubt about this one and the 24Mpx APSC of the D3200 (at least no offcial confirmation).
I fully believe the D3200 sensor wasn't made by Sony, for the sensor looking different from any other Exmor (Pentax and Nikon implementations included) and the output does too (slight difference in DR curve, white dots at higher ISO's that we haven't seen from Exmor sensors since about 2008).
I was sceptical about the D600 sensor too, but since I've seen the sensor and especially after seeing these results, I fully believe it's an Exmor.
TrojMacReady
CyrusK wrote:
Nice to see a high score for the 24Mpx FF
Actually... Is it confirmed that it is a Sony sensor ?
http://www.dxomark.com/index.php/eng.../Cameras/Camera-Sensor-Database/Nikon/D600
For comparison:
D800E: 96 pts
D800: 95 pts
D600: 94 pts
A900: 79 pts
A77: 77pts
Waiting the A99...
I'd say between 88 and 91. It loses about half a stop in terms of SNR due to the SLT design, it might lose a hair for using stronger CFA's and PDAF dedicated pixels, it gains in the arbitrary overall score for offering ISO 50. That's the main reason why the difference between the A77 (offers ISO 50 too) and NEX 7 ( not ISO 50) is a mere 3 points, while based on the SLT design alone you'd expect about 5 to 6 points.
j900 Regular Member • Posts: 401
stol2004 wrote:
I think is all about marketing with this DXO ranking. The company who gives more > money gets better score ... the one who doesn't gets a crappy rank . PPl must be naive > to think that is no marketing in that ' top sensors ' from DXO .
DXO's method is explained in depth and produces fully reproducible results. Take the camera, do the measurements (you can do them at home), and see you results.
That is assuming of course that you're smart enough, unlike what your post suggests.
 j900's gear list:j900's gear list
Sony Alpha 7R II Sony 50mm F1.4 Sony 70-300mm F4.5-5.6 G SSM Sony 20mm F2.8 Sony 100mm F2.8 Macro +2 more
rinkos Senior Member • Posts: 2,227
For comparison:
D800E: 96 pts
D800: 95 pts
D600: 94 pts
A900: 79 pts
A77: 77pts
Waiting the A99...
thanks for showing us to these results...
amazes me that the new sony sensor is more than 3 stops ahead of the canon one...this is far more impressing for me as 1/3 more noise stop .....really good job from sony on that aspect.
rhlpetrus Forum Pro • Posts: 24,480
They are same, images
D600 from DPR:
A99 from internet
RX1 from gizmodo
Renato.
http://www.flickr.com/photos/rhlpedrosa/
OnExposure member
http://www.onexposure.net/
Good shooting and good luck
(after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
Amateur Sony Shooter Veteran Member • Posts: 5,417
Good find...
that will settle. So we can expect A99 to be in 90 pt range.
 Amateur Sony Shooter's gear list:Amateur Sony Shooter's gear list
Sony RX100 Sony a77 II Sony 70-200mm F2.8 G Sigma 10-20mm F4-5.6 EX DC HSM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +5 more
Mark K
Mark K Veteran Member • Posts: 5,204
thank you
Exactly same thoughts of mine.....the A99's AF performance can be better
j900 wrote:
Nice find, thank you.
If this is the same sensor as in the 99 (give or take a few nikon optimizations) then we may expect the same performance, minus the SLT penalty which is usually 3-5 dxo points (1/5-1/3 of a photographic stop). So we might expect a solid dxomark=90 for the 99!
On a side note this is 11 points, or 2/3 of a stop better than the A900. Given the high price tag I'm not sure that this is going to make A900 users switch, except those who are craving for a better AF system.
Mark K
 Mark K's gear list:Mark K's gear list
Sony Cyber-shot DSC-RX100 III Sony SLT-A77 Nikon D800 Canon EOS 5D Mark III NEX5R +64 more
