Which version of Tamron 17-50?
Started Sep 18, 2012 | Discussions
govindrv Regular Member • Posts: 280
Hello all,
I have used a Canon 50mm 1.8 fairly now for a long time and am now seriously considering buying a wider angle and chose the Tamron 17.50 f/2.8 as I'm on a budget.
There are different versions of this lens. Which one should I go for?
Is the IS (VC in Tamron's case) really important. With the short focal length, I'm fairly capable of steady shots handheld. All I'm worried about are the optics and image quality. Which version of the lens produces the best images? And is lighter on the pocket
Also another question: I have a Canon 1d MkII. Will this lens work on this camera?
Thanks for the advice in advance
Cheers
GRV
Its your ATTITUDE, not your APTITUDE that decides your ALTITUDE
Canon EOS-1D
PStu Regular Member • Posts: 334
Re: Which version of Tamron 17-50?
govindrv wrote:
Hello all,
VC takes a moment to kick in after you half-press the shutter release; not as quick as my kit lens. Unless you have a camera body that has great high ISO capabilities, the VC will be welcome for indoor shots.
Doing side-by-side comparisons, I can't see any noticable differences with the 18-55IS except at 100% view. I think that distortion at the wide angle is slightly better.
I believe this lense is APS-C only, but you can double-check at the Tamron website.
Cheers
GRV
 PStu's gear list:PStu's gear list
Olympus XZ-2 iHS Canon EOS 450D Olympus PEN E-PL2 Panasonic Lumix DMC-G6 Canon EF 50mm f/1.8 II +9 more
nightfly Contributing Member • Posts: 543
No, it's APS-C only.
Andreas
Working on http://nightfly.square7.ch/i5
 nightfly's gear list:nightfly's gear list
Canon EOS 60D Canon EF-S 15-85mm f/3.5-5.6 IS USM Sigma 105mm F2.8 EX DG OS HSM Tamron SP 70-200mm F/2.8 Di VC USD Sigma 18-35mm F1.8 DC HSM Art
