EF-X20 Best Flash I have
Started Sep 16, 2012 | Discussions
MuMinded
Senior MemberPosts: 1,939Gear list
Sep 16, 2012
I have 5 Nikon speedlights in varying models. My latest two are the SB-600 and SB-800. However, I can now say after owning and using the EF-X20 flash that it's the best flash that I own... Here's the simple reasons why.
1. It's not bogged down with fussy and complicated menu driven menu's, in fact, I doesn't even have a LCD screen. The adjustments are 100% control dial, or lever based. This is such an underestimated point that it goes unnoticed sometimes. When I'm shooting a quick portrait I don't want to ruin the mood by fiddling with my speedlights or diving into my Nikon menu settings.. I simple shoot, review LCD screen, quick adjust with a simple twist of the dial and I'm ready to go.. literally 3-5 seconds..
2. It's small, compact and hangs on the camera in a wonderful way. With the flash attached the camera still hangs around my neck and rides on my hip as if it wasn't even attached at all.
3. When it's not on my camera it is so small that it easily fits in my bag, ensuring that I always have it with me.
4. It provides perfect balance fill light in bright outdoor sunny conditions. This of course allows for a balanced bright background with the subject reasonably lite. Since my XPro-1 has such good low light IQ I don't use it much for indoor shooting, but when it's bright and sunny outside the flash is always on my camera...always.
5. I has a remote flash mode that allows it to fire off the camera as soon as it senses any light.. This makes it perfect for use as a small yet effective portrait flash when doing impromptu shooting sessions.
The down side of the flash is that it has no bounce capability. But, I'm already working on a rube-Goldberg design to let me modify it (with a small mirror) to allow bounce capability...
Anyone else with comments either good or bad on this flash?
MuMinded
 MuMinded's gear list:MuMinded's gear list
Fujifilm X100S Olympus Tough TG-4 Nikon D300 Fujifilm X-Pro1 +2 more
Torq
Regular MemberPosts: 155Gear list
Re: EF-X20 Best Flash I have
In reply to MuMinded, Sep 16, 2012
It is a pretty nice setup ...
The EF-20, which will tilt (for bounce), is a nice combination ... optionally using the EF-X20 as a slave.
Both flashes, the X Pro 1 w/ grip, and all three current lenses all fit nicely in a little Domke F-5XB bag.
 Torq's gear list:Torq's gear list
Sony Cyber-shot DSC-RX100 III Leica D-Lux (Typ 109) Leica M9-P Leica M Typ 240 Leica Tri-Elmar-M 16-18-21mm f/4 ASPH +5 more
JasperD
Senior MemberPosts: 2,662
I like that flash too but unlike you, it sits mostly in the bag, I don´t use it that much.
That notwithstanding, I´m considering adding a second one to be triggered by the first.
You can avoid the DIY transformation by just putting it on a flash cable, that will let you shine it in whatever direction you want it too. I´ve read the Canon OC-E3 works perfectly, ordered it and should receive it tomorrow. After checking it, I will probably order the second EF-X20 just before FW upgrade 2.0 and the XF 14/2.8.
boinkphoto
Contributing MemberPosts: 944Gear list
It is the lack of bounce that is my big problem (that and the price, which is pretty dang high). To me it's almost not worth using flash if it isn't bounce (except for daytime fill).
In any case, Demb makes some "Rube Goldberg" devices that might do the trick:
http://www.dembflashproducts.com/flipit/
Though whether there's enough power to get bounce is another question...
 boinkphoto's gear list:boinkphoto's gear list
Fujifilm X-T1
jimmyca1219
Regular MemberPosts: 205Gear list
In reply to boinkphoto, Sep 16, 2012
Its a nice looking flash indeed... but how does it compare to the cheaper ef-20? Does it worth the extra money?
 jimmyca1219's gear list:jimmyca1219's gear list
Fujifilm FinePix X100 Leica M8 Fujifilm X-Pro1 Carl Zeiss Biogon T* 2,8/28 ZM Voigtlander 35mm F2.5 Color Skopar +5 more
TThorne
Senior MemberPosts: 2,986Gear list
In reply to jimmyca1219, Sep 16, 2012
I went through this a while back and settled on a combo of the ef-x20 and a EF-42.
The x20 for the obvious fill flash, and the 42 for bounce. I was using the bounce feature so seldom that I thought it might be convenient one day to be able to bounce in any direction and just keep the 42 as a backup for that.
Of course now I use pocket wizards a lot and it doesn't matter what flash I use, to an extent.
A lie gets halfway around the world before the truth has a chance to get its pants on. - Sir Winston Churchill
 TThorne's gear list:TThorne's gear list
Leica M Monochrom (Typ 246) Leica M Typ 240 Pentax 645Z Leica Summilux-M 35mm f/1.4 ASPH Leica Summilux-M 50mm f/1.4 ASPH +9 more
Scott McL
Regular MemberPosts: 249
Thanks - "read the Canon OC-E3 works perfectly"
In reply to JasperD, Sep 17, 2012
One more checklist item - extension cord enabled "off camera" flash (flash bracket or hand held) I can check of for the X-E1! One step closer to purchase! Thanks!
"Photography is not about the thing photographed. It is about how that thing looks photographed." - Garry Winogrand
Scott McL
Might you elaborate more on Pocket Wizard setup?
In reply to TThorne, Sep 17, 2012
I currently shoot a Nikon via PC sync with a couple of AB-800 studio strobes, and am looking for similar/better configurations for the X-E1. Another "buy decision checklist item" I am researching.
Could you describe your Fuji + Pocket Wizard setup?
Many thanks in advance!
