How to salvage once-in-a-lifetime shot
Started Sep 15, 2012 | Discussions
ott77n
Contributing MemberPosts: 959
Sep 15, 2012
It was shot facing south (give or take), at around 2pm. Had a Nikon CPL on the lens. What I think is wrong here is the white balance. Could a CPL interfere with the wb?
I spent hours working on this photo, with little to show for it. Part of the problem is my lack of expertise, specifically I only think WB is the issue, but have no idea, really, how to tackle this problem.
Any ideas?
dj_paige
Regular MemberPosts: 286
Re: How to salvage once-in-a-lifetime shot
In reply to ott77n, Sep 15, 2012
Hard for me to imagine what you would like to see here. Was the sky blue on this day? Was the sky gray? Describe what you want to see, and maybe we can get you there.
Please define CPL.
Paige Miller
Maxxuman
Senior MemberPosts: 1,499
In reply to dj_paige, Sep 15, 2012
Please define CPL.
A CPL is a circular polariser filter. It does have an effect on the colors but I'm not sure to what extent in this case and agree with Paige that it's hard to judge. Aren't those aircraft grey? It looks that way on my screen anyway so I'm not sure if white balance is the problem. Of course contrast and such can be improved on it and I'm sure others will do so. The shot was certainly well timed!
Another question is did you shoot RAW? That give more options to achieve the results you're after.
Barry
Toermalijn
Forum ProPosts: 12,418Gear list
In reply to Maxxuman, Sep 15, 2012
A cpl (circular polarizer doesn't have that much effect on colours. It makes then more contrasty and eliminates reflections.
As for the picture, you can replace the dull sky with one of clouds or a background of people and clouds.
Maxxuman wrote:
Please define CPL.
Barry
asoftwind
Veteran MemberPosts: 4,131
Claude
ott77n
Maxxuman wrote:
Please define CPL.
Thanks for taking the time to look at the shot
Thanks for taking the time to look at the shot.
Yes, greyish-silvery.
Yes, it sharpens very nice and all. Just the colors
Thanks. Pure luck. I did know what they (the pilots) were after - it is called the vapor cone. I was shooting at 6fps, and the previous and next frame have hardly any condensation visible. This is why I need help salvaging this frame.
Yes, I did shoot raw. I used a Nikon D7000. The image is sooc jpg, in a sense, that it is the "raw", "saved as" jpg in ViewNX - without any manipulation.
For the reference, here is a shot taken one hour earlier, but same hardware (CPL and all):
sooc (saved as) jpg
and what I think I remember the weather was like:
The colors may not be 100% accurate, but it is not what I am after. The image is the original read into Nikon CaptureNX2, white balance set to day/full sun, and contrast bumped somewhat in 'quick fix'. Took all of 15 seconds.
So absolutely no problem with the second image. No problems with most. But serious problems with quite a few.
What is different? I think I was facing south-south-west, and it was some 2 hours before the Super Hornet.
Other than that? Same camera, lens, CPL.
Clues/suggestions greatly appreciated.
Toermalijn
ott77n
In reply to asoftwind, Sep 15, 2012
asoftwind wrote:
Looks good, but I want it to be a sunny day, as it was
Here is my best try so far:
Perhaps too much contrast (no biggie), but sharpened quite ok. It is just that awful blueish cast on the aircraft. The sky - also awful, but at least it is somewhat blue
fuego6
Senior MemberPosts: 1,601
In reply to Toermalijn, Sep 15, 2012
Toermalijn wrote:
Perfection!
Jim B (MSP)
Veteran MemberPosts: 6,400
raw ?
Can you share the raw file somewhere for us, like on dropbox?
The CPL will have an effect on the sky as a function of angle to the sun.
The blues should be able to be pulled out, however.
Jim
ott77n
Toermalijn wrote:
Considering you had access to the jpg only, I must conclude, that you did not attempt to fix the colors in the original image, but cut out the Super Hornet and placed it against different background.
Looks stunning though!
Thanks for taking the time.
ott77n
Re: raw ?
In reply to Jim B (MSP), Sep 15, 2012
Most certainly, except might need some help here: what is a dropbox?
Jim B (MSP)
dropbox
you can get 5 G free for file sharing. I find it useful.
https://www.dropbox.com/downloading
Jim
RayGuselli
Forum ProPosts: 13,169Gear list
Toermalijn just salvaged it for you!!!
Brilliant edit...excellent.
I would be more than happy with that!
Best wishes
Ray
VISIT MY WEBSITE HERE...HOPE YOU LIKE
http://www.flickr.com/photos/77568703@N03/
 RayGuselli's gear list:RayGuselli's gear list
Nikon D300 Nikon D700 Panasonic Lumix DMC-GF5
Jim B (MSP)
jpeg try
here is my 1st effort on the jpeg using Capture One. I primarily brightened and saturated the blues.
It looks better on my screen than when displayed form pbase
I may try with LR
Jim
ott77n
Re: dropbox
Got it.
Here is the link:
https://dl.dropbox.com/u/105651468/DSC_9749.NEF
tony brown
Senior MemberPosts: 2,842Gear list
From the jpg, ...
... could do better with the RAW.
Cheers, Tony.
 tony brown's gear list:tony brown's gear list
Sony Alpha 7S
ott77n
In reply to RayGuselli, Sep 15, 2012
Got you point. The image looks stunning.
But at the same time trying to learn something as well.
Jim B (MSP)
from the raw
I took this into Capture One, reset the wb to "daylight", darked the exposure a bit, and bumped the blues a bit, decreased contrast a little for
I could play more, but I think this is heading where you want.
The body of the jet is in the shadows, so is probably a touch bluer than it should be. I'd selectively warm it up when I had time.
Jim
tony brown
And from the RAW ...
In reply to tony brown, Sep 15, 2012
Sky to taste. Only you know how it looked at the time.
Cheers, Tony.
Sony Alpha 7S
