No PC Socket on the D600
Started Sep 14, 2012 | Discussions
Marvin Horlick OP Regular Member • Posts: 404
Re: No PC Socket on the D600
olyflyer wrote:
Marvin Horlick wrote:
Have you noticed there is no PC socket on the D600?? What is Nikon thinking??
I am a wedding photographer and I shoot the D300 with an off camera TTL cord in the hot shoe and a PC cord going to a pocket wizard to fire a remote flash.
So without a PC socket I cannot use the D600. I know there are some adapters that go into the hot shoe of the camera and have a hot shoe on top and a PC socket on the side. But I cannot use these because of the aforementioned TTL cord in the hotshoe.
Does anyone have a solution for syncing the remote flash with a pocket wizard?
Thanks - Marvin
The D600 is obviously not a camera for you. Besides, not only is it missing the PC contact but also the sync speed is slower as well as the maximum shutter speed, not to mention some other bits and pieces. It is a low budget FX for low budget. For that price no wonder there are limitations and it is clear that it is an entry level camera in the FF format.
Wow! I didn't know the sync speed was slower on the D600. Definitely a deal breaker for me.
Nikon - We need the D400 ASAP!!
Marvin
olyflyer
olyflyer Forum Pro • Posts: 23,914
Thanks - Marvin
Also the 1/4000s as maximum speed means more use of ND filter. I think that is as serious as the sync speed. I may even regard this as a bigger problem since the sync speed isn't a big issue because you can always switch to FP flash if you have one, and in that case you can use any shutter speed available.
D Clarke Evans New Member • Posts: 2
Marvin, I velcro a Pocket Wizard to the top of my flash, then run a cord from the PW to the flash PC socket. Works great.
Yes, but how do you send a sync signal to the Pocket Wizard to fire the flash?
Marvin
He was using a TTL cord from the camera to the flash. Run a cord from the Pocket Wizard Velcroed to the top of the flash to the PC terminal on the flash. When you press the shutter, the TTL cord running to the flash causes the flash to fire. When the flash fires a signal is sent from the cord attached to its PC socket to the Pocket Wizard causing the PW to fire. The PW will then send a signal to other PW's causing them to fire. I do it all the time.
