First A99 RAW samples
Started Sep 13, 2012 | Discussions
George Evans Senior Member • Posts: 1,591
I don't know if this has already been posted but the first A99 RAW samples are online.
Link from SAR
http://www.sonyalpharumors.com/hot-first-a99-full-size-raw-image-samples-at-quesabesde/
George Evans
http://www.wirralpix.com
Sony SLT-A99
moimoi
moimoi Veteran Member • Posts: 3,660
Re: First A99 RAW samples
Thanks for sharing. I quickly checked the jpg they posted. At full resolution, I still don't like what I see.
Some shots are obviously suffering from motion blur. I am very puzzled how little thorough those cameras are put to test.
 moimoi's gear list:moimoi's gear list
Canon EOS 6D Canon EF 35mm f/2 IS USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 16-35mm f/4L IS USM Canon EF 35mm F1.4L II USM
Endos Senior Member • Posts: 1,232
The images are JPGs directly from the camera. RAW files are linked below each image.
renato55 Regular Member • Posts: 185
I saw the link, I do not really understand how Sony give in trial his top camera to these men, who took these pictures maybe can be a great scientist, but it's certainly not a good photographer, taking pictures are so bad that it is impossible to have a opinion of the camera
moimoi
Indeed Renato! Very disappointing to see those bad samples after bad samples.
Someday I will Junior Member • Posts: 27
Ouch!
Well, i've done some quick tests with latest version of Sony IDC. Can't post images because of bandwidth limitations, but i'm seeing some noticeable noise when lifting shadows, and the 2000 and 2500 samples are VERY noisy... the 3200 and upper performance must be to cry for...
Frankly a bad performance for a FF sensor, even with SLT light-loss penalty i'm surprised Sony did this bad. I find quite comical that Nikon does much better with Sony sensors than Sony themselves...
Yes, I know the excuses: bad photographer, wait to final firmware, etc... but folks, let's be realistic, remember what happened with first a77 samples: the exact same thing and the same excuses, but reality was clear: Sony screwed up. One year later Sony screwed up, again.
Nordstjernen
Nordstjernen Veteran Member • Posts: 6,876
Re: Ouch!
What do you exactly compare to? And how?
 Nordstjernen's gear list:Nordstjernen's gear list
Sony Alpha 7 Sony SLT-A99
Re: Ouch!
I was not satisfied with the first photos of the A77 and now, after 10 month of use I want to sell my A77 anyway, to go to FF or come back to Olympus, but if the quality of the A99 is not outstanding is very hard to me to buy one.
BTW if Olympus had already released a E7 or a professional m4 / 3 I already left my A77 (which I was very disappointed for my needs)
danny006 Senior Member • Posts: 1,079
Re: Ouch!
The JPEG's, you don't know if noise reduction is on or off. I think in the series of ISO pictures NR is turned off, so you basically have RAW performance here.
The RAW's I took a look with Sony's PMB, ISO2500 looks very good, a little noise in the out of focus parts, that's all and to be expected at ISO2500, you can't have noise free images at this point, at least not in RAW.
 danny006's gear list:danny006's gear list
Canon EOS 6D Canon EOS 760D Sigma 150-600mm F5-6.3 DG OS HSM | S Samyang 14mm F2.8 IF ED MC Aspherical
(unknown member) Veteran Member • Posts: 3,992
YAY Finally!
Downloading now
Thanks for sharing George Evans
moimoi
Tell me whether you find them sharp. There is only one that look good (the woman's profile with the hat), but that's about it.
Now off topic, just check the samples taken with the Sigma DP2 Merrill,+ and let me know about sharpness
+ The camera itself is not that interesting, but what the Foveon sensor delivers is just outstanding. Just keep in mind I am a Sony user (and not a troll for those people who believe the opposite) not a Sigma user.
Re: Ouch!
I think you'll find that any camera will show considerable noise when pulling up ISO2000 and 2500 shadows. Also did take note of the histogram on those two images?
I made a screenshot of some RAW images which I opened in Sony PMB software. Can't edit though.
First one, ISO2500 (shutter speed of 1/80s which gives motion blur, so not really sharp)
Second one, ISO2000 (shutter speed of 1/60s)
GuyMcKie Contributing Member • Posts: 596
The raw samples are horribly under exposed, and with bad color balance.
I downloaded some raw samples 2000 ISO and 2500 ISO.
Converted them to 16bit tif in the' Sony image data convertor, with sharpening, dro, and nr off.
Adjusted the exposure and color balance.
The ISO2000 needs a +1EV compensation and should be judged more as ISO4000.
The ISO2500 needs a +1,5EV and should be judged more as ISO 6400.
Processed both tiff files through ACR with process 2013 for chroma and luminance noise reduction.
My first conclusions,.
The A99 seems one step better at high iso3200 than the a900, and a 1/2 step at iso6400 than the a900.
And is probably very close to the D600, D3X and canon 5DIII.
Better exposed pictures and direct conversion through lightroom, and final production firmware, could gives a better result.
With the 1/2 stop light loss of the translucent mirror it is not a bad result.
Some results and crops:
Dustinash Contributing Member • Posts: 657
It is good to know how the sensor reacts to underexposure. Im an event photographer and it is very common to get underexposed photos when your riding the edge between ambient light and a little fill. I like to see how much noise it produces when that occurs.
So far looks a tad better then a77. holds better detail But this is so preliminary as to be meaningless. I think sony is restricting release. Ill go see what the d600 is doing and judge sonys performance from there. End of day.. same sensor.. will be within pretty similar range of each other.
Archer66 Senior Member • Posts: 2,900
I doubt that D600 is using Sony sensor, more likely a Aptina.
