If you shake your RX100 (lightly), does it rattle?
Started Sep 6, 2012 | Discussions
sb_in_nc New Member • Posts: 11
Mine does, and I'm trying to figure out if this is normal.
Sony RX100
dalemccl Regular Member • Posts: 470
Re: If you shake your RX100 (lightly), does it rattle?
I had never shaken it before, but just did after reading your post, and I do hear a light rattle.
David ap Junior Member • Posts: 29
mine does.
RX100 Junior Member • Posts: 43
It's probably caused by the orientation sensor.
Julie Sinar Regular Member • Posts: 239
Just checked, mine does as well
Julie
Amateur Sony Shooter Veteran Member • Posts: 5,417
Because of Steady Shot
(NT)
 Amateur Sony Shooter's gear list:Amateur Sony Shooter's gear list
Sony RX100 Sony a77 II Sony 70-200mm F2.8 G Sigma 10-20mm F4-5.6 EX DC HSM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +5 more
tbcass
tbcass Forum Pro • Posts: 23,230
YES, normal
Yes mine does and I suspect it's the movable lens element for image stabilization.
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony SLT-A77 Tamron SP AF 90mm F/2.8 Di Macro Sony DT 35mm F1.8 SAM Tamron SP 70-300mm F/4-5.6 Di USD +7 more
islandphotos Regular Member • Posts: 122
Re: YES, normal
could also be the drop sensor.
 islandphotos's gear list:islandphotos's gear list
Sony Cyber-shot DSC-T9 Sony RX100 II Sony Alpha NEX-7 Sony Alpha 7R II Sigma 35mm F1.4 DG HSM Art +3 more
tbcass
Re: YES, normal
I forgot about that. You are probably right.
peener New Member • Posts: 17
Don't worry, it's normal
Take a look at this thread: http://forums.dpreview.com/forums/read.asp?forum=1009&message=42355418
It is probably the same to what you experience. It is the whole lense unit that can move to allow the stabilization system to work.
Carl bcn
Carl bcn New Member • Posts: 15
Re: Don't worry, it's normal
I guess it is the same thing I asked about here (the last of my questions): http://forums.dpreview.com/forums/readflat.asp?forum=1009&thread=42236702
At first I thought something was wrong (and I still do sometimes, because it's annoying), but the camera works great so... if it ain't broke, don't fix it.
Anyway, even with the explanations I've read so far, I still believe the barrel should be tighter, not absolutely tight since it must have some play to avoid unnecessary friction, but neither so loose. I would like the barrel play to be dampened somehow as other compacts seem to do (then again, they don't have such a big lens, that might be the reason).
http://www.flickr.com/photos/67723928@N06/
