How to turn off the built-in flash of the A77 in remote control mode?
Started Sep 4, 2012 | Discussions
greves2
New MemberPosts: 16
Sep 4, 2012
Hello,
I would like to use the built-in flash of my A77 to control remote flashes, but not contribute at all to the lighting of the image. The image is taken using a mirror so the built-in flash will be visible and should not be emitting any light in the picture.
Is this possible? If yes, how?
Thank you!
Gabor
Sony SLT-A77
Bart7D
Veteran MemberPosts: 3,974Gear list
Re: How to turn off the built-in flash of the A77 in remote control mode?
In reply to greves2, Sep 4, 2012
It is not possible, since codes in the light burst are used to trigger the distant flash(es).
But the best thing you can do is put a piece of black film (black part of a negative) over the built-in flash. It will dim most of the visible light, while allowing the needed infra-red light to pass and reach the external flash.
Bart
 Bart7D's gear list:Bart7D's gear list
Konica Minolta Maxxum 7D Sony Alpha DSLR-A700 Sony SLT-A77 Sony a77 II Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) +13 more
Cetonid
Senior MemberPosts: 2,480Gear list
Could something like this work?
In reply to Bart7D, Sep 4, 2012
http://www.lightscoop.com/buynow.html
Of course, you would need to have overhead reflective surface like a light colored ceiling.
 Cetonid's gear list:Cetonid's gear list
Minolta DiMAGE 7Hi Nikon Coolpix 950 Panasonic Lumix DMC-ZS40 (TZ60) Sony Alpha DSLR-A350 Olympus PEN E-PL1 +12 more
Edward Sargent
Veteran MemberPosts: 4,354Gear list
Unless you are less than 5ft from your subject the light from the popup should not effect the image as it is at a much lower power in wireless mode (you are in wireless mode?). As others have said you can tape exposed film to the flash or get one of the A-S1 IR Panels http://www.ebay.com/itm/A-S1-IR-Panel-camera-Pop-up-Flash-Sony-DSLR-Cameras-/230844441682
greves2 wrote:
Hello,
Sony or Minolta remotes?
It has to, the Sony wireless remote system works via light pulses
As others have said you can tape exposed film to the flash or get one of the A-S1 IR Panels http://www.ebay.com/itm/A-S1-IR-Panel-camera-Pop-up-Flash-Sony-DSLR-Cameras-/230844441682 .
Sarge
A77, A700 8mm Bower, 50mm 1.7, 35-70 F4, 90mm Tamron, 18-250 Sigma, 70-200 Sigma & 50-500 Bigma
Toys - Asus Transformer Android 4.0.3 tablet & Colorspace UDMA 500 gb
Albums at http://www.sony-snapper.com
 Edward Sargent's gear list:Edward Sargent's gear list
Sony Cyber-shot DSC-QX10 Sony SLT-A99 Sony a77 II Sony 70-200mm F2.8 G Sony 70-300mm F4.5-5.6 G SSM +25 more
greves2
New MemberPosts: 16
Thanks. The A55 could do it. I fact that's all it could do. It built-in flash could not be used for fill light because it would control the remote flash BEFORE the exposure. I was wondering if there is a setting to set that kind of behavior.
Thanks agai!
Gabor
Glenn
Veteran MemberPosts: 6,959
One other option is to set HSS mode. The on camera flash will be entirely finished it's communication and won't be visible during exposure at all. If I understand there is a mirror present in your scene and you don't want the flash seen there? this is the only way to do it besides wired or radio triggers.
http://www.daisyseyecancerfund.org/Files/Awareness/photographing_rb_poster.pdf
http://www.dailymail.co.uk/news/article-1247912/Mother-spots-cancer-babys-eye-taking-photo.html
sybersitizen
Veteran MemberPosts: 3,935
Bart7D wrote:
It is not possible, since codes in the light burst are used to trigger the distant flash(es)...
Yes, it is possible.
greves2 , I assume you are using a fully compatible remote flash that supports HSS. If so, shoot in S or M mode and make sure to set the shutter speed on the camera so that the 'HSS' indicator appears. On the A77 I think this will happen at 1/320s. Then the pop-up flash will never contribute any visible light to the scene.
Bart7D
In reply to sybersitizen, Sep 4, 2012
Thanks, Sybersitizen & Glenn - that's a good work-around I wasn't aware of!
Bart
greves2
New MemberPosts: 16
In reply to Bart7D, Sep 6, 2012
Thanks, Sybersitizen & Glenn - that's a good work-around I wasn't aware of either!
I tested it and works like a charm.
Gabor
Glenn
In reply to greves2, Sep 6, 2012
