This is very weird, need help !!!
Started Sep 3, 2012 | Discussions
Pradipta Dutta
Veteran MemberPosts: 9,749Gear list
Sep 3, 2012
I have been using NX2 Win7 64 bit PC for a while now. But when I tired to launch it yesterday, it just wouldn't come up. No error - just the program won't start. No new software was added since I used it the last time (Aug 26th). No hardware added either. What I suspect is probably some registry change happened or Windows update occurred. On Aug 27th I did update the driver for the NVIDEA display adapter. I tried to revert back to the old driver. But it did not help.
I tried uninstalling and reinstalling every Nikon software. I even cleaned up the .NET framework and reinstalled it. Swept the registry using Nikon's "Registry Sweeper" but to no avail.
BTW, even Capture NX wouldn't start even though View NX2 starts fine. But I really NX2 to start to work again.
PS3 works fine.
Help !!!!
 Pradipta Dutta's gear list:Pradipta Dutta's gear list
Nikon D2X Nikon D3 Nikon D800 Nikon D3200 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
Kerry Pierce
Forum ProPosts: 17,196Gear list
Re: This is very weird, need help !!!
In reply to Pradipta Dutta, Sep 4, 2012
Sorry, I can't help directly, Pradipta. I'd suggest that you contact Jason Odell about the issue. He's an NX guru and probably has seen this issue in the past and would be most likely to have a fix, IMO.
good luck
Kerry
my gallery of so-so photos
http://www.pbase.com/kerrypierce/root
 Kerry Pierce's gear list:Kerry Pierce's gear list
Nikon D300 Nikon D700 Nikon D3S Nikon D7000 Nikon D5100 +11 more
craig
Senior MemberPosts: 1,926
You might also try posting this over at the PC talk forum. Hope you get it resolved.
http://www.pbase.com/crs
Pradipta Dutta
Thanks, Craig and Kerry
Just posted on the "PC Talk" forum as well. I will also follow up with Jason.
nikonsrme
Senior MemberPosts: 1,391
Did you try a restore point to the day before the problem happened?
That usually will fix most anything as it puts eeverything back to the way it was when the restore point was created. Has saved me many times. In fact its a good idea to just create one right before you install something new just in case it blows up. Only takes a few seconds to create one.
Anyway hope it works for you.
'You can observe a lot just by watching.' YOGI BERRA
Photography by Jerry Faircloth
http://www.jerryfaircloth.com
Kerry Pierce
Re: Thanks, Craig and Kerry
FWIW, I had some similar issues a couple of years ago, with NX and ViewNX, but the programs never worked, unlike with your situation. A fix was never found. It wouldn't work until the next version came out.
Since yours worked at one time, at least you know you don't have to wait for the next version. Nikon support wasn't all that helpful to me. Mostly, they just wanted me to remove and reinstall everything, and I mean everything Nikon related. But, the way windows works, there are usually residuals left in the mix somewhere. I hate to bear bad news, but you might be looking at a complete re-installation of windows and everything else, just to have a clean registry.
Hope that it doesn't come to that for you.
Kerry
Sagittarius
Senior MemberPosts: 2,857
PS3 works fine.
Help !!!!
Hi,
I do not know if you alredy done this. Find capturenx.exe file under C/Program/Nikon/CaptureNX and see if you can open it from there. If yes, there is a problem with a path in the icon you open it with. Right click on the icon and make sure the path is correct.
Best regards
Joe Porto
Senior MemberPosts: 1,008Gear list
This might be obvious but...
Are you opening NX with a shortcut icon, or actually going to the program folder and opening it from there.
 Joe Porto's gear list:Joe Porto's gear list
Canon PowerShot G15 Nikon D7000 Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 28mm f/1.8G
Pradipta Dutta
In reply to Kerry Pierce, Sep 4, 2012
I am hoping I will be able to find a resolution. The key is that mine worked until the 26th.
Man, that will be a bummer if it comes to that. Keeping my fingers crossed. Will keep you guys informed as it comes along.
Pradipta Dutta
Re: Did you try a restore point to the day before the problem happened?
In reply to nikonsrme, Sep 4, 2012
That was one of the first things I tried to do. For whatever reason, no restore points were available prior to 9/2. Murphy's law :-(.
I am definitely hoping it will get resolved.
Pradipta Dutta
In reply to Sagittarius, Sep 4, 2012
Yep, tried that too. Same response though - simply nothing happens.
Pradipta Dutta
Re: This might be obvious but...
In reply to Joe Porto, Sep 4, 2012
Tried both.
Lance B
Forum ProPosts: 26,779Gear list
Was there a Windows automatic update in that time frame? I had trouble downloading some automatic Windows updates via the auto function and had to do a manual one by one update and that fixed the issue with downloading them. What was happening was, whenever I shut down the computer, it would do the "auto update" and try to download the 8 updates that were available but when I would boot up the computer, it would say that the updates failed. By going into the "Windows Update" program, I ascertained what the latest updates were and then did each one individually and that fixed the issue.
However, I do not know if this is your problem. The thing is, you may not know that your computer has done an automatic update and this may have caused a conflict.
Lance B
http://www.pbase.com/lance_b
 Lance B's gear list:Lance B's gear list
Nikon D800E Nikon AF-S Nikkor 16-35mm f/4G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 500mm f/4G ED VR +12 more
Sagittarius
Hi,
When you uninstalled CNX and cleaned registry, have you also deleted it's folder from program folder and from C/users/User name/appdata?
Best regards
Pradipta Dutta
Sagittarius wrote:
Hi,
Didn't do that. I will try that as well.
Pradipta Dutta
In reply to Lance B, Sep 4, 2012
Just checked, there were no windows update since 8/15.
Pradipta Dutta
Only updates since 8/26 are ...
1. NVIDEA Graphics Driver 268.45 and
2. Mozilla Firefox 15.0
3. Registry Cleanup using Norton's PC Tuneup
I already tried reverting back to the previous version of the NVIDEA graphics drivers. So, I am eliminating that to be the problem.
Now, going over the details of the registry cleanup.
Pradipta Dutta
Re: Only updates since 8/26 are ...
As I mentioned earlier, I tried restoring the previous version and that did not help.
I can't believe this could be causing it. Can't see the connection between Firefox and Capture NX.
I looked at every registry entry that was removed. It only removed those that referred to a non-existing file.
So, I am at a total loss as to what happened.
Mako2011
Forum ProPosts: 14,952
event viewer
A thought. Go to task manager and make sure it's not listed as running. Then go to event viewer and clear the widows logs so you have a fresh log to look though. Now try to start the program again. When it does open, go back to event viewer and check the widows logs for a hint as t why.
Alejandro Daz del Ro Fery
Veteran MemberPosts: 3,720
It looks like stupid, but ... Did you execute some video troubleshooting (control panel) as well as delete the contents of the cache folder? (C:\Users\pradipta?\AppData\Local\Nikon\Capture NX\Cache)
Hope you do not have to format C:
http://www.pbase.com/pradipta
Un saludo.
