The forth D800E, should I accept it?
Started Aug 30, 2012 | Discussions
henry wl
Regular MemberPosts: 241
Aug 30, 2012
I know I know, some people will be furious about threads like this. But as long as Nikon keeps in silence and keeps shipping out D800s with left focus issues, customers have the right to know the fact. And I don't care if you are angry or not about my thread.
Some of you might see my posts about my first D800E. I was actually in denial of left focus issue and didn't want to test it until one day I shot my six year old daughter's activity using left focus point and realized focus landed on her left shoulder instead of on her eyes. As it's almost impossible to use focus-recompose technique on a constantly moving child, I decided I'd better test it. Since then my nightmare began.
I sent my d800e back to Nikon Mississauga, and it came back in one week. I first tested left focus, yeah! They fixed it! I was so exited but then I realized my center focus point had very bad front focusing. (it was actually -12 backfocusing before I sent it in). So I had to sent it back to Nikon for a second service just for center focus front focusing. Guess what? Front focusing got much worse, literally unusable at 24mm even at +20 AFT...
I eventually got refund from Nikon and immediately ordered one from a local camera store. It came in last Friday. Unfortunately it also had left focus issue, I quickly exchanged it for another one, front focusing was worse, I also got a ugly dead pixel right in the middle of the frame on this second body. Yesterday I exchanged it again for the third D800E from the same store, but it seems it also has the same focus problem.
Here are the test samples:
(More and original images can be seen here:
http://www.pbase.com/henrylw/d800e_left_focus_problem )
I tested it on both my 14-24 and 24-70. All shots taken using the same way I shoot landscapes: Gitzo tripod, mirror up, remote shutter release. Among around 200 test shots, the pattern is the same and typical: center focus is tack sharp, right focus a bit soft, left focus quite bad.
Please note these three cameras all came in last Friday, they should be the same batch. (last 4 digits of serial number all ended with 19xx), I think there is no point testing more cameras within the same batch. Now my question is, should I keep it? Return means I'll have to wait at least another one month or two and miss our beautiful fall season.
Believe me, I LOVE this camera. I switched from Canon to Nikon just because of its great dynamic range which, in my opinion, is most important feature a landscape photographer would ask for. But I also shoot my family events especially my kids activities, I want its focus functioning as advertised.
For landscape, even with its faulty left focus, it is still be best DSLR money can be now. These are what I got from D800E:
Nikon D800 Nikon D800E
unknown member
(unknown member)
Return it
In reply to henry wl, Aug 30, 2012
Try another brand and another forum.
Or, put on your big boy cap and make your own decision.
Good luck.
Roy
Great British Landscapes
Regular MemberPosts: 321
Re: Agreed
In reply to BackInTheGame, Aug 30, 2012
These threads are a joke.
Good luck.
Roy
Leos
Senior MemberPosts: 2,066
Re: The forth D800E, should I accept it?
I think you really need to decide what is more important to you: the benefits that the D800 gives you in your landscapes or would you be happier with a better focussing and more "forgiving" camera (in terms of magnification).
When employing the D800 as a "general purpose camera" (handheld, wide open, PD autofocus, less than ideal light etc) you should learn to accept that you're not getting the full 36mpixel worth of resolution or should we say "magnification potential". At least not every time.
Some years back, Canons definition of autofocus tolerance was measured on the full frame print at A4 size. (Just to put things in perspective). Spend a minute thinking about what kind of magnification you are evaluating the autofocus precission at when viewing 100% crops.
That said, I think it would be a safe bet by now to conclude that Canon got it right with their new cameras AF this time around. While obviously, it cannot be judged at the same enlargement as the D800, at least when it comes to fast glass (The "Digillooyd" case - not the left AF point) it seems Canon doesnt miss as often and as severe as the Nikons.
Good luck in your chase for the perfect compromise for you.
stany buyle
Senior MemberPosts: 1,957Gear list
Wow, that's a beautiful picture! Congratulations.
Kindest regards.
Stany Buyle
http://www.nikonuser.info/fotoforum
I like better one good picture in a day than 10 bad ones in a second..
 stany buyle's gear list:stany buyle's gear list
Nikon D1
jonnyz2
Forum MemberPosts: 84
I would return it. Also, why are these posts/threads being attacked?
I don't think that is acceptable performance if you expect to use the left focus point.
I do use the non-center focus points frequently on my on my D300 and do often use the extreme side focus points. So, I expect to use them on a D800/800E and want them to work well.
At this point I have returned one D800 and one D800E due to this issue. The D800E also had a broken remote trigger connector.
Worse yet, I have just tested two new ones received last week. One D800E and one D800 (Serials 300479x and 3003436x respectively) and both do not meet my expectations. My tests (multiple lenses, multiple side by side comparisons (4 per focus point, AF vs LV)) show that the D800 is way off on the left focus point and the D800E is so/so.
Now that I’ve tried four of these without success, I was thinking of giving up for a while and trying again in a few months. The only reason I've been pushing this is an upcoming trip where I would really like to have the D800/E instead of the D300.
So, I was really pleased to see some people now posting here that their newly received D800s seem to be OK. So, despite the folks criticizing these threads, I personally find them very helpful as they are helping me to decide whether I should bother to try again right now or wait for some time.
If other posters out there haven't experienced these problems, that's fantastic! If you fall in that category, please just ignore these threads. For some of us right now, these threads are very useful.
For those of us who have had these problems, we're frustrated and trying to find a way forward.
I really doubt that anyone has put out $3,000+ on a new camera and perhaps much more on new FX lenses without truly wanting it to work. For that reason, attacking such threads and posters, in my opinion, is unreasonable.
Hopefully, NIKON will get this fixed soon and all of these threads/posts can go away!
RumpelHund
Regular MemberPosts: 161
Keeper threads coming to see where we are
In reply to jonnyz2, Aug 30, 2012
Same with me, testing D800s in shops with my most problematic 1.4/24 to finally get a good copy. No success yet. Seems to me either it's an all cams at all times issue or the bad samples keep reappearing on the shelves all the time until someone buys them.
Once these threads stop I'll take the next try, so keep them coming to show the status, please.
djedi
Senior MemberPosts: 2,761Gear list
Judging by your photos...
...you obviously have no idea what you are doing. And your tests are just irrelevant. At least that's what some of the posters here will tell you.
Personally, I feel your pain and hope Nikon service in Melville takes care of me when I send mine in for similar issues. I figured if I send it back to the seller, I may just get another customer's returned product, so I'll take my chances with the big N.
Seriously- great shots BTW.
Wolfgang
Old timer
 djedi's gear list:djedi's gear list
Sony Cyber-shot DSC-V3 Panasonic Lumix DMC-FZ150 Sony Cyber-shot DSC-HX20V Nikon D300 Olympus PEN E-PL3 +12 more
TDong
Senior MemberPosts: 1,780
return it until you get the good copy. will let you know tomorrow to see if Nikon Mississauga actually fix mine. so far two said Nikon Mississauga fix their.
http://photokaz.com/2012/08/d800-autofocus-repair-testing/
Todd Hargis
Senior MemberPosts: 2,293
Re: The forth D800E, keep it.....
I would keep that one for that is barely noticeable. If that test was wide-open then at F/1.4? @ 2.8 it should go away completely. And do you actually use the extreme left AF point at all? However I guess if you're just kind of looking for floorman you might be looking too hard I don't know. But I would definitely keep that one because most of the time you're going to be using the center AF point anyway. I think you need to evaluate your style of shooting and base it off of that. If you shoot mostly landscapes you don't even need to use autofocus, but if you're doing sports ballet or anything with a lot of movement, then maybe so. Anyway I think that's probably the most important question… What is your shooting style? then you can determine rather you keep the camera not after that.
http://www.toddhargisphotography.com
http://toddhargisphotography.com/Weddings
http://www.pbase.com/todd991
Joe Porto
Senior MemberPosts: 1,008Gear list
How many TVs, or cars, or major appliances would you exchange...
Let's put this in perspective. If you bought a defective tv, or car, or major apliance and it was defective, and you returned it for another which was defective, how many exchanges would you do before you gave up and bought something else. For me, ANY company gets one chance. If the second is defective, I'd move on. I've seen people stating that they are on their 4th, 5th, even 7th camera.
Einstein said that the definition of insanity is doing the same thing over and over again and expecting a different result.
 Joe Porto's gear list:Joe Porto's gear list
Canon PowerShot G15 Nikon D7000 Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 28mm f/1.8G
henry wl
In reply to TDong, Aug 30, 2012
Returning it means I'll have to wait for next batch to come in. That would be a couple of months, and I'll miss the fall season shootings.
Please do update your fix result. Last time they screwed up mine to the extend it was not fixable. Hopefully they have new cure and technicians are well trained now.
Steve Bingham
Forum ProPosts: 20,091Gear list
Re: How many TVs, or cars, or major appliances would you exchange...
In reply to Joe Porto, Aug 30, 2012
Joe, I believe the quote came from Benjamin Franklin, not Albert Einstein.
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon D300 Nikon D7100 Nikon D610 Nikon D5300 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +19 more
sfnikon
Senior MemberPosts: 1,940Gear list
Go back to Canon
...and bother them. Your life is a "nightmare" since the extreme left focal point is a bit off - are you serious??
No the D800 is not a perfect camera but it's got the most amazing IQ this side of medium format and most of us happily live with it.
Jake
amobi
Senior MemberPosts: 2,740
Re: Judging by your photos...
In reply to djedi, Aug 30, 2012
Don't do it. Nikon Melville has no clue. I wish I had returned mine to the seller and keep trying different copies. Nikon Melville has screwed mine up so badly that I have since stopped using it for now.
Right now I will be glad if they can get the center to work.
Wolfgang
Old timer
henry wl
I see your point. Cameras are not like cars. You cannot just buy a camera of another brand and mount your current lens on it, Can you?
Like I already said, D800/E is a great camera for landscape, probably the best DSLR. It was the pure reason I switched from Canon. I didn't say it is a bad camera, but it has quality issues that need Nikon's attention and action. It's hard to believe after 5 month of production, they are still shipping out those defective ones, and there is still no single word from Nikon to address this issue.
PhD4
Senior MemberPosts: 3,616
In reply to Steve Bingham, Aug 30, 2012
Not to flame this into a discussion or even take a side, but actually there is no real clarity where that quote came from, interestingly enough.
http://en.wikiquote.org/wiki/Talk:Benjamin_Franklin#The_definition_of_insanity ...
Apparently both have been credited with it, and so have others.
My guess is, one of you is correct
henry wl
Re: Go back to Canon
In reply to sfnikon, Aug 30, 2012
When I said nightmare, I didn't mean the left focus issue itself. I meant multiple trips to Nikon service and eventually the camera was "fixed" to "unfixable". It stayed much longer time in Nikon service center than in my hand. I had to cancel a few of my shooting plans, and later I had to order another one, which was not available until last Friday, but then I saw the same problem.
Jake
kayaker353
Regular MemberPosts: 430
I chose to keep it
I faced the same dilema and chose to keep it and have it repaired. I knew there was some risk that "repair" would be ineffictive or make it worse. I thought that I could wait for another body and have it be defective, also. So, I chose to have it repaired, which was successful on the first try. This whole process took several weeks and was frustrating. I also had to swallow hard in accepting a repaired new camera. However, I am now on my way with the camera and have retired the D300 to backup status.
ukat123
Contributing MemberPosts: 761
Re: I chose to keep it
In reply to kayaker353, Aug 30, 2012
Reading this forum, there are truckloads of D800 which are returned to vendors...and I doubt very much that they are returned to Nikon. Instead, they are put back on sale or at best reconditioned, for just another person to have the same problem. I wonder if there are still genuine new and un-boxed D800, with all these people who have tried 4-5 bodies. Just a thought.
Anyway, if the problem is as widespread as people are stating on this forum, I suggest the best action is to abandon Nikon once and for all. This is the only way Nikon can learn a lesson.
