Leica EVF-2 and Olympus VF-2: Are they identical?
Started Aug 28, 2012 | Discussions
StillsHunter Forum Member • Posts: 53
OK I can see that the chassis is shaped a little different and the scribble out front betrays different branding, but my question is whether the internals are the same?
Primarily I am keen to know which way Epson has compromised. Noting the VF-2 came first, it was designed and manufactured with the 4:3 image aspect ratio in mind. Meanwhile the Leica format is 3:2. So does the EVF-2 possess the same screen with some of the top or bottom display disabled, or the VF-2 always had excess pixels each side. Or does the newer EVF-2 have a new - 3:2 aspect - screen inside?
Keen to know as my order arrived today and I have the EVF in the mix. Be more than happy to opt for the VF-2 instead, as this would 'free up' funds to buy a CV OVF as well. But I'll only dump the Leica offering if they are the same....
TIA
 StillsHunter's gear list:StillsHunter's gear list
Ricoh GR
Godfrey Forum Pro • Posts: 28,977
Re: Leica EVF-2 and Olympus VF-2: Are they identical?
I looked through both of them at the store, and they looked to be identical. I bought the Olympus.
G
TIA
PHelton
PHelton Regular Member • Posts: 128
I think there both made off the panasonic one.
My gear: 5DmkII,7D,300mm2.8Lis,Zeiss 21 2.8 and 35 1.4 distagon,70-200 2.8Lis,,851.8,100 2.8L macro, 580ex flash,twin macro flash,G1x
 PHelton's gear list:PHelton's gear list
Canon PowerShot G1 X Canon EOS 5D Mark II Canon EOS 7D Canon EF 35mm f/1.4L USM Canon EF 85mm f/1.8 USM +6 more
StillsHunter OP Forum Member • Posts: 53
I believe the Panasonic GX1 finder does not fit either the Leica X2 or any of the PENs. Thought both the EVF-2 and VF-2 are made by Epson....if not they are certainly sourcing the base plate moulding from the same place?
Ricoh GR
The Panasonic EVF in their G1/G1H, etc models is a different technology.
The optional one for the GF1, et al, is also a lower rez, different technology.
Olympus was the first company to use this technology and it is super.
Godfrey
http://godfreydigiorgi.posterous.com
(unknown member) Senior Member • Posts: 2,216
Olympus VF-2 and Leica EVF-2 are both essentially the same, and both made by Epson AFAIK...
Joe
 Joe Pineapples's gear list:Joe Pineapples's gear list
Ricoh GR
Yes. That is what I said befor, in not so many words.
