RX1000 ARW files
Started Aug 28, 2012 | Discussions
DavePlugh
Senior MemberPosts: 1,421Gear list
RX1000 ARW files
Aug 28, 2012
I'm trying an experiment. But I don't have access to any RX100 ARW files.
Anyone know where I can download one or two?
Dave
 DavePlugh's gear list:DavePlugh's gear list
Canon EOS 450D Canon EF-S 55-250mm f/4-5.6 IS Canon EF-S 18-55mm f/3.5-5.6 IS +1 more
Sony RX100
EinsteinsGhost
Forum ProPosts: 11,977Gear list
Re: RX1000 ARW files
In reply to DavePlugh, Aug 28, 2012
I've found this so far: http://www.imaging-resource.com/PRODS/sony-rx100/RX100hSLI0080NR1.ARW.HTM
And hoping if any RX100 owners would provide a sample or two to play with.
PS. If anybody would like to, you could use "drop box" to share a file or two. You will have to sign up however (or any other safe approach you may already be aware of).
https://www.dropbox.com/home
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
DavePlugh
In reply to EinsteinsGhost, Aug 28, 2012
Thank you for that link to an RX100 ARW file. I downloaded it,
So, here is what I did...
1. I downloaded from Adobe the (latest) DNG Converter V7.2 and installed it on my computer.
2. I started DNG Converter and selected Change Preferences.
3. In Preferences I changed Compatibility to "Camera Raw 6.6 and later".
4. I then told DNG Converter to convert the ARW file to DNG format.
5. I then opened up the DNG file in Adobe Camera Raw plugin under Photoshop CS5.
Enjoy
Dave
PGR streetshooter
Contributing MemberPosts: 973Gear list
Enjoy
Dave
Brilliant!
Cheers, Don
 PGR streetshooter's gear list:PGR streetshooter's gear list
Canon PowerShot G9 Ricoh GR Digital IV Fujifilm X100S Nikon Coolpix A Olympus PEN E-P5
rava777
Regular MemberPosts: 356Gear list
Enjoy
Dave
Just tried all that Dave, but DNG not viewing the ARW file (for CS5 as well)
 rava777's gear list:rava777's gear list
Sony RX100 Canon PowerShot SX50 HS Sony a5100
RX100
Junior MemberPosts: 43
In reply to rava777, Aug 28, 2012
Enjoy
Dave
Try selecting a earlier version of the raw converter when in the preference menu, at first it didn't work for me, but I selected 2.4 and later and Photoshop opened the converted DNG files.
DavePlugh
Did you download and install DNG Converter version 7.2 from here?...
http://labs.adobe.com/downloads/cameraraw7-2.html
Dave
DavePlugh
When changing Preferences in DNG Converter... When you select an item in the Compatibility dropdown list, pay close attention to the comment lines just below it.
These tell you what version of both Photoshop and Lightroom will be compatible with each item.
I never select the Custom option, simply because I haven't a clue what it does. This is the Compatibility setting I selected. Check the comments below the dropdown. Its says Photoshop CS5.
DavePlugh
Remember, you want to take a RAW file - an RX100 ARW file in this case - and convert it to a Digital Negative (DNG) Raw file. And then you want an Adobe product (Photoshop, Lightroom or Elements) to be able to read it in so you can work on it.
May the force be with you.
Dave
rava777
Dave
Thanks Dave (RX100 too) did try again but still no file being found - even shot a couple off from the camera this time just in case a problem with the downloaded one.
I've used DNG before so seems as if something isn't right.
I'll give it another go later sometime.
ericN2
Forum ProPosts: 16,340Gear list
In reply to DavePlugh, Sep 5, 2012
There are some good RAW shot pics here from the RX100..both jpg's and RAW...
http://www.photographyblog.com/reviews/sony_cybershot_dsc_rx100_review/sample_images/
and the RAW (or the one I tried as an example) worked out very well indeed with the (free) Sony Raw Converter ..
http://www.graphicregion.com/ablerawer.htm
On the one I did try out though..there's a shocking amount of distortion on the original Raw !! .. very 'barrelised' ... (pic..dsc_rx100_15.arw)
Somebody give it a try and see if you get it also .. ?
eric
Staffordshire, UK
