canon 7d shutter count
Started Aug 20, 2012 | Discussions
Kanji Senior Member • Posts: 1,565
Does the app on the website "camerashuttercount" work accurately for the canon 7d?
Cheers
 Kanji's gear list:Kanji's gear list
Canon EOS 6D Nikon D610 Canon EF 24-105mm f/4L IS USM Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +1 more
Canon EOS 7D
Karl Gnter Wnsch Forum Pro • Posts: 11,408
Re: canon 7d shutter count
Since it's now quite costly I would advise you use gphoto2 on a Linux system, there are plenty of live DVD's so that you don't even have to install it...
regards
Karl Günter Wünsch
 Karl Gnter Wnsch's gear list:Karl Gnter Wnsch's gear list
Canon EOS 7D Mark II
W5JCK
W5JCK Senior Member • Posts: 1,979
The site won't work at all on my 60D or my T1i (500D). Since it takes the info from a photo, I'm guessing it will only reflect how many shutter actuations since the last time the file numbering was reset.
An astrophotography hobbyist and amateur radio instructor and examiner. Canon EOS 60D and Canon Powershot G1 X. http://www.w5jck.com
 W5JCK's gear list:W5JCK's gear list
Sony Alpha 7 Sony a6000 Canon EF 400mm f/5.6L USM Canon EF 70-300mm f/4-5.6 IS USM Sony E 55-210mm F4.5-6.3 OSS +13 more
Randy Benter
Randy Benter Veteran Member • Posts: 3,145
regards
Karl Günter Wünsch
That site does not work for the Canon 7D.
You have 2 choices:
1. You can go to eoscount.com and pay $1.50 via Payal. This is the one Karl described as "quite costly". I think it is "quite" reasonable.
2. You can use gphoto2 (a linux program). If you are currently running linux, then this one is the obvious choice. If you have never used linux or vmware, then I highly recommend you just go to eoscount.com. Cost is not just a measure of cash, but also of time and effort. For the linux novice, this option can be "quite costly".
 Randy Benter's gear list:Randy Benter's gear list
Fujifilm X100T Nikon D7200 Fujifilm X-T10 Carl Zeiss Touit 1.8/32 Apple Aperture +18 more
Jay S. Senior Member • Posts: 2,895
Anyone try this lately? - Re: canon 7d shutter count
Free, but dated... Not sure what it does or doesn't support.. Windows only.
http://astrojargon.net/EOSInfo.aspx
Cheers
Jay S.
Fuji 7000 / Canon 40D / Canon 7D / Canon 5D mkII
With multiple camera bodies and a desire to check the counts from time to time, I'd sign up for a reasonable "one time" charge to allow me to check cameras from time to time, etc. Starts to add up if you have multiple bodies and you want to check them once a quarter or so. If the author offered a one time $15 fee, for example, I think it would be more appealing.
regards
Karl Günter Wünsch
You have 2 choices:
Jay S.
George Spencer Senior Member • Posts: 1,079
If you have a Leica M8 or M9 and you know the "secret code" you can punch a few buttons in the right order and the camera will tell you how many shutter activations you have. It's a shame that Canon doesn't do the same thing.
 George Spencer's gear list:George Spencer's gear list
Canon EOS 50D Canon EOS 6D Canon EOS 7D Mark II Panasonic Lumix DMC-GX8 Canon EF 50mm f/1.2L USM +12 more
Habemus_Canon Senior Member • Posts: 2,437
How do you know they don't?
 Habemus_Canon's gear list:Habemus_Canon's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD600 Canon PowerShot S90 Canon EOS 350D Canon EOS 7D +14 more
Justme Forum Pro • Posts: 21,394
Where does it say you have to pay?
I just took a visit to that site. It is trying to run an add-on. You mean after you connect the camera to a USB port, it will ask you to pay $1.50 via PayPal...to me the $1.50 is very reasonable as I would seldom need to read the shutter actuation.
I know you mean well but please do not embed my images into the forum. Thanks for respecting that.
http://www.pbase.com/golfpic/some_recent_shots
http://www.pbase.com/golfpic/a_red_fox_family
 Justme's gear list:Justme's gear list
Y0GI Veteran Member • Posts: 5,228
regards
Karl Günter Wünsch
You have 2 choices:
I am a "Linux novice" and I found that gphoto2 was easy to run (as long as your computer has a wired connection to the internet). Here are the step by step instructions: http://photography-on-the.net/forum/showthread.php?t=1058019
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
Randy Benter
regards
Karl Günter Wünsch
You have 2 choices:
Yogi
I didn't say it would be difficult. I said it would COST time. You can either spend $1.50 of your money and 3 minutes of your time OR you can spend $0 of your money and about 60 minutes of your time. How much is 1 hour of your time worth?
Randy Benter wrote:
regards
Karl Günter Wünsch
You have 2 choices:
Yogi
Since I am retired, not much!
Yogi
