G1X vs RX100 at 3200ISO
Started Aug 20, 2012 | Discussions
mailman88
Veteran MemberPosts: 5,520Gear list
Aug 20, 2012
G1X
RX100
My take...the G1X has more detail...
 mailman88's gear list:mailman88's gear list
Canon EOS 30D Canon EOS 7D Canon EF 50mm f/1.8 II Canon EF 200mm f/2.8L II USM Canon EF-S 10-22mm f/3.5-4.5 USM +4 more
Sony RX100
Absolutic
Veteran MemberPosts: 4,963Gear list
Re: G1X vs RX100 at 3200ISO
In reply to mailman88, Aug 20, 2012
You should be comparing G1x to something like Sony NEX 5n, they are the same size-wise and their sensors are of similar size.
RX100's sensor is not just smaller, it is less than half of the area of G1x sensor, as can clearly be seen in the chart on this site in RX100 preview:
 Absolutic's gear list:Absolutic's gear list
Sony RX1 Sony Cyber-shot DSC-RX100 III Canon EOS 30D Nikon D800 Sony a6000 +15 more
godzen
Forum MemberPosts: 73
okay...
but while you're at it, want to compare the G1x to a full frame camera which has bigger sensors and see which come out on top? Rx-100 is truly pocketable btw. G1x is not. different market
are some people really that st*pid around here?
rondom
Senior MemberPosts: 1,899
Hard to judge high iso performance under studio lighting. More interesting to see how they perform in low light situations, which is what high iso is meant for...
caboe
New MemberPosts: 7
The RX100 has a much faster lens. So for real life use, you should compare the Canon ISO6400 to Sonys ISO3200.
tbcass
Forum ProPosts: 22,536Gear list
If the G1X didn't have more detail at iso3200 I would be very surprised because it has a much larger sensor. For someone who doesn't have a DSLR and if the lens zoom range is adequate the G1X is a great choice. Since I already own an A55 and A65 a camera Like the G1X doesn't interest me. Instead I am opting for the RX100 for it's smaller pocketable size.
Tom
Look at the picture, not the pixels
http://www.flickr.com/photos/63683676@N07/
http://www.flickr.com/photos/25301400@N00/
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony SLT-A77 Tamron SP AF 90mm F/2.8 Di Macro Sony DT 35mm F1.8 SAM Tamron SP 70-300mm F/4-5.6 Di USD +7 more
EinsteinsGhost
Forum ProPosts: 11,977Gear list
In reply to tbcass, Aug 20, 2012
You should have also tried to equalize the focal lengths, shutter speeds and apertures and that you did not. In other words, pick a logical mid focal length (use 35mm equivalence for both, and keep them same), keep aperture same (pick f/5.6 for both), keep shutter speeds identical, and of course, keep both at ISO 3200.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
mailman88
In reply to Absolutic, Aug 20, 2012
...yes, I know! You are correct
mailman88
In reply to godzen, Aug 20, 2012
godzen, lets not talk foolish in here. Nobody will POCKET a RX100!
They might use a camera case used with belt. But nobody will pocket the RX100.
Just watch in this forum...Someone will TRY to pocket a RX100 and will drop it.
He'll ask questions in this forum about what happened and repair.
Someone will reply..."not a good idea to pocket an expesive camera (RX100), you were asking for trouble."
mailman88
In reply to caboe, Aug 20, 2012
great point...
mailman88
....pocketable, if you say so!
About 99% of RX100 owners will not pocket. They use a belt camera case.
The 1% will pocket the camera and most will drop the camera...
Dan1964
Regular MemberPosts: 216
I guess I'm part of the 1%, I don't baby my camera just because it cost a little more than other compact cameras..some people on here talk like they are afraid to get a finger print on it...:)
Ryan Williams
Contributing MemberPosts: 592
I think you're very wrong on this. Indeed, I'd go so far as to say that most people do pocket the RX100 — that is, after all, the main reason why many would choose it over a larger camera that would also fit in a belt case.
If it weren't the RX100's small size and it'd be fairly unremarkable as a camera. The main reason people are drawn to it is because it delivers superb quality in a camera they can truly just throw in a pocket and forget about rather than having to consciously be carrying a camera.
Of course, neither of us have actual statistics so who knows how many people pocket it. Any owners want to chime in?
Ryan Williams
In reply to Ryan Williams, Aug 20, 2012
Also, unless you're wearing formal trousers with shallow, silky pockets I don't see how the RX100 could possibly get dropped just from being in there. Not unless you've got crazily slippy hands, in which case you're not going to be much safer with a case.
Absolutic
you are joking right? the Reason I got RX100 is that it is a pocketable camera and I carry it in my pocket/pockets, just like other compact cameras, except that RX100 is smaller than my previous LX3 that I used to carry in my pocket. Other than that I have my DSLRS and also NEX-7, but none of them are pocketable.
The RX100 comes with a strap like all compact cameras, I've grown a habit over the years to also put the strap around my wrist when using a small camera, and I've never dropped any of my 30 or 40 compacts I'd gone through over the last 10 years.
Just Yesterday I put this little camera in my shorts pocket, and went out with my wife and my 3-month-old, with nothing on my shoulder, or on my belt, etc.... i placed it in my pocket and forgot about it, until I need to reach for it to take a photo of my infant:
EinsteinsGhost
Again....
Since you didn't respond to my post above...
Why did you not keep all settings identical in your comparison? If I were you, I would probably select:
35mm (35mm equivalent)
ISO 3200
f/5.6
1/500s
In both cameras. The only thing identical in your comparison is... ISO. For that matter, I would also do this comparison using same ISO, same focal length (35mm equivalence) and in aperture priority mode (say, f/5.6) and see if there are discrepancies in shutter speed (which may also indicate that indicated ISO 3200 on one might be different from the other).
Eliminate your variables when making such comparisons.
Michael Thomas002
Junior MemberPosts: 35Gear list
G1X has more detail at ISO 3200. Agreed. I've been a big fan of the Canon G line. I auditioned it before buying the RX100. If it weren't for the fact that the G1x performed so sluggishly during auto-focus I would have bought it for the larger sensor. But the Sony is much faster. That was the deciding point for me.
I don't find that either camera falls comfortably into the pocket camera profile, so size didn't count for me.
 Michael Thomas002's gear list:Michael Thomas002's gear list
Canon EOS 7D Fujifilm X-T1 Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-105mm f/4L IS USM +4 more
EinsteinsGhost
In reply to Michael Thomas002, Aug 20, 2012
It is why I have NEX. Want to compare G1X to NEX now?
But, at least pay attention to settings used in the comparison.
EinsteinsGhost
That nobody will put the RX100 is merely an assumption on your part. So, let us leave it at that. However, I would either pocket it, or it fits perfectly as the third camera in my sling bag, which means, the four lenses I pick for my other two cameras could involve something other than a range covering 28-60mm. Won't that be great?
PaulRivers
Veteran MemberPosts: 7,419
Exactly, comparing at the same iso doesn't matter when the lens is so different.
