Is I.S. really necessary?
Started Aug 18, 2012 | Discussions
LincolnB
Senior MemberPosts: 3,659Gear list
Aug 18, 2012
Handheld, 1/125th of a second with a 200mm lens. No I.S., manual focus. I used to shoot with an E-P1 and thought that I.S. was really helpful but I'm not so sure anymore. Now I think it's a minor feature that I can do without.
 LincolnB's gear list:LincolnB's gear list
Olympus PEN E-P1 Panasonic Lumix DMC-G3 Fujifilm X-E1 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +4 more
Olympus PEN E-P1
Detail Man
Forum ProPosts: 14,950
Re: Is I.S. really necessary ?
In reply to LincolnB, Aug 18, 2012
That is a really nice, steady, well-focused capture, Lincoln (particularly if derived from a crop of the full image-frame)! Is it from a crop, and what (roughly) was the percentage of cropping going on ?
In an attempt to perhaps explore possible answers to the question that your thread-title poses, I would ask you what percentage of your (non-stablised in any way) hand-held, manual focused shots come out as well as the one that you have displayed here ? How would that percentage compare to any stabilized shots attempted ?
An additional matter - and one that is implicitly involved in answering such a question - relates to the effectiveness in performance of the particular image-stabilization system(s) being referred to (in the particular range of Shutter Speeds within which such a determine of IS efficacy is being made)
Clayton1985
Veteran MemberPosts: 3,788
Re: Is I.S. really necessary?
There are lots of "minor features" in today's cameras that I could live without but I don't want to.
LincolnB
In reply to Detail Man, Aug 18, 2012
I'm not good at percentages - this was 3000 x 4000 cropped down to 3362 x 2521. So about 75% ?
I would say I haven't seen a big difference in keeper percentages between IS and non-IS. I think my percentage of keepers may be about the same. In fact, I'd say a lot of the stabilized shots seem to add a tiny bit of shudder that might not have been there if IS had been turned off. I'm guessing the I.S. would often try too hard. In other words, I.S. seems to help improve the keeper rate if your standards are less than super sharp but not if you're looking for that super crisp shot. Good for street shots, not so good for ersatz Nat'l Geographic shots.
If there is a need to turn on I.S. then it's already acknowledged that the shutter speed is marginal. So already the odds are the shot will be marginal. I've found several other techniques more effective than turning on I.S. in those situations -- better bracing against the body, pulling out a tripod, bumping the ISO, switching to a faster lens, focus on breathing, trying burst mode, etc. -- that should be tried first.
lol
Is that a question?
Handheld I often get keepers when the shutter speed is half the focal length. It's a low percentage but I do get some. That seems to be about the limit. I can't remember any keepers with this 200mm lens at 1/80th for example. But as a rule of thumb I find that shutter speed needs to be at least equal to focal length or better if I want a reliable % of keepers.
MAubrey
Senior MemberPosts: 1,479Gear list
Well...on the OMD, you could have shot at 1/50...
--Mike
 MAubrey's gear list:MAubrey's gear list
Olympus OM-D E-M5 Sony Alpha 7 Olympus M.Zuiko Digital ED 9-18mm 1:4.0-5.6 Voigtlander 58mm F1.4 Nokton SL II Voigtlander 35mm F1.2 Nokton +7 more
jkrumm
Veteran MemberPosts: 8,043
IS at telephoto lengths with the older pens is pretty much like shooting without IS. If you have stronger IS like with the OMD or even the E5 or E30 you start to see a clear difference.
John Krumm
Juneau, AK
tjuster1
Senior MemberPosts: 1,434
I'm sorry, but this is bad logic.
1) As others have noted, nailing one sharp picture doesn't prove much . . . it's the percentage of keepers you get at this FL/shutter speed. Even IS doesn't give you 100% results, as tests have repeatedly shown. But it sure as hell improves your odds. Again, testing has proven this beyond a shadow of a doubt; there is no argument here.
2) If, by some chance, you were able to consistently get sharp pictures at this FL/shutter speed combination (which I honestly doubt), then you have some rock-steady hands and I congratulate you. However, this doesn't obviate IS--it only means that WITH IS you'd be able to go even slower. IS is a relative advantage, not an absolute one. So under those (hypothetical) conditions although IS wouldn't be needed forTHIS picture it certainly would be the only way you could capture others using a slower shutter speed.
LincolnB
In reply to tjuster1, Aug 18, 2012
You think that I.S. introduces no aliasing errors, as it tries to correct for movement?
TheEye
Veteran MemberPosts: 3,100
A necessary as testicles on a cow.
I can only speak for the E-620's IS and my experience with what I shoot. At 12 mm I use IS if the shutter speed drops below 1/8 second. I stopped using IS with longer focal lengths, because I consistently got better results without IS.
s_grins
Veteran MemberPosts: 8,475Gear list
I.S. does not work for me. Since my camera is Panasonic, I need OIS , but I have only 14-45 lens. And even this lens has IS switch "OFF" all the time.
Monopod is my IS, and tripod is my IS square
I’m surprised how much Wikipedia contributes to the forum.
 s_grins's gear list:s_grins's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Sigma 30mm F2.8 EX DN +2 more
Detail Man
So about 75% ?
Percentage = (100) x (1-B/A), so (100) x (1-3000/3362) = 10.8 % crop to 89.2% of original size.
And what is that percentage ? Let B (above) equal successes, and A (above) equal total shots.
I remember you posting a similar successful low Shutter Speed hand-held shot on June 17, 2012:
http://forums.dpreview.com/forums/readflat.asp?forum=1041&message=41812297
The usefulness of IS is a statistical matter. It can perturb things - or make them stunningly good. That's why evaluating the overall success rates (with and without) is the most meaningful.
Such situations do arise when shooting hand-held.
If no IS system that you have so far used helps matters, that is an understandable viewpoint.
Never hurts a bit.
pulling out a tripod, ...
Ugh. If you insist. How spontaneous for birding ! ...
... bumping the ISO,
There goes your Signal/Noise Ratio as you use a lower valued Exposure for the same light-level.
If you have to switch, why not just use a fasre lens in the first place, then ?
... focus on breathing, ...
Yup. I always hold my breath. It matters.
... trying burst mode, etc. -- that should be tried first.
What is your percentage success rate for those endeavors ? Why would more shots be better?
lol
Is that a question?
Perhaps so ? Knowing how well an IS system tends to perform at the Shutter Speed used helps.
How people assess success makes a difference. Lens softness; sensor resolution; RAW/JPG; NR/Sharp; print/display size; display resolution, luminance, and contrast-ratio, viewing distance, ambient lighting, and individual viewer acuity tend to make one viewer's "good enough" not very translatable to the eyes of other viewers. The lower the quality, the less camera-shake is noticed.
morepix
Veteran MemberPosts: 7,925Gear list
Depends
Focal length. Shutter speed. What year you were born.
http://www.pbase.com/morepix
 morepix's gear list:morepix's gear list
Panasonic Lumix DMC-LX7 Olympus Stylus 1 Olympus OM-D E-M10
3DrJ
Senior MemberPosts: 1,027Gear list
OK then, let's see what's true
Oh really? I've always had the ability to hand-hold the camera steady, much better than the average photographer. In fact, I regarded it as a kind of sport to see how slow I could go.
Back in the ancient days of film photography, you know, at the end of the previous century, I was often able to get a pretty sharp photo with a 50mm lens at 1/8 or even sometimes 1/4 sec. on a good day. Today, maybe I'm not quite as steady, but still not bad at all.
Two months ago when the EM-5 finally arrived, among the first things I did was test the super-IBIS.
It was midnight, almost all the lights in the house were doused. I mounted the 45mm f/1.8 on the EM-5. I aimed it at the barely visible coffee table ~3 m away in my dark living room. At ISO 3200, the shutter speed was 1/2 sec.
The image turned out much sharper than I'd expected. With IBIS off, nothing but mush. I've repeated the experiment several times, and 75% of the IBIS-enabled images were acceptable or better. Without IBIS, none were acceptable.
Remember, I'm an experienced and talented practitioner of this sport, yet I don't believe I could ever have successfully hand-held a shot at 1/2 sec. with a 90mm eqv. lens on the camera. But I could do it with IBIS.
How about you ? Go ahead, try this test yourself, and let us know how well you fare.
JRA
Artists must not only see, but see what they are seeing.
 3DrJ's gear list:3DrJ's gear list
Olympus E-1 Olympus E-3 Olympus PEN E-P3 Olympus OM-D E-M5 Olympus E-M1 +5 more
Bob Tullis
Forum ProPosts: 25,901Gear list
Oh, You Don't Know, The Shape I'm In
And IIRC, you take good care of yourself, and work at it. Physical tone and strength is an asset in this regard. Even without having a lot of mass to wield.
I'm sure of two things, though - your technique isn't haphazard (and it shows - brilliant capture, BTW), and you WILL be using OIS, thankfully, some time soon (when you least expect it [g])
...Bob, NYC
http://www.bobtullis.com
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Olympus E-M1 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Rokinon 7.5mm 1:3.5 UMC Fisheye CS Voigtlander Nokton 17.5mm F0.95 Aspherical Olympus 12-40mm F2.8 +18 more
3DrJ
You might be interested in my post below. Within it, I suggest a test for the OP that could be made to address some, or all, of your points, but perhaps that wouldn't be necessary for the simple purpose of verifying the OP's original hypothesis.
JRA
highwave
Senior MemberPosts: 1,041Gear list
I tried I.S. at 150mm (300mm Eqv.) and the benefit of I.S. is as real as a slap in the face.
two to three full stops unquestionable. Five stops arguable.
But then again, we had an earthquake once in the office and one of my colleagues didn't sense it. So I guess everything is arguable.
 highwave's gear list:highwave's gear list
Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm 1:1.8 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +3 more
illy
Forum ProPosts: 12,160Gear list
no anti wobble here
anti wobble can be great for static objects, but once things start moving it becomes a bit useless, so i find it's actual usefulness a bit overstated.
now with extra added dancing girls
 illy's gear list:illy's gear list
Nikon D200 Panasonic Lumix DMC-GF1 Nikon D5100 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +4 more
Detail Man
Re: no anti wobble here
In reply to illy, Aug 18, 2012
For motion-blur you'll need a "scene-stabilization" system. They are only in preliminary development.
my body simply pulses gravitons to actually stabilise the world to my motion
Why am I not surprised ? You might trade-mark the system with the name "Cerebral Fixation" ?
illy
Detail Man
For an amusing/entertaining study in the human "oh my oh so rock-steady hands" syndrome, see:
http://forums.dpreview.com/forums/readflat.asp?forum=1041&message=40197527
