Sony RX100 filter adapters?
Started Aug 17, 2012 | Discussions
cdp8 Forum Member • Posts: 99
Re: Jens Faerber's adapter ring.
Liz Z. wrote:
What I don't understand about Jens' setup is how it takes both 52mm and 43mm filters. Or are there two different setups, depending on which size filter you want to use?
If I receive anything from Jens other than a 52mm filter adapter, I'm going to be very disappointed. Here is what he wrote to me:
Thank you for your interest.
Yes, I do for an adapter ring for Sony RX100 make.
It can all filters (UV, Pol, Sky, Star, infrared etc.) with a diameter of 52 mm or
Macro lens Raynox DCR-150 or 250 record.
The adapter is easy with tools (tube) is bonded perfectly to the lens (with double adhesive tape).
It hinders anything - the lens can move freely and also turn off the camera poses no problem.
Price range: 29,50 €
Shipping (International) by certified mail costs 5.50 €
If you're happy with the price, I'll give you my PayPal account.
After receipt of the money part will be shipped immediately.
Of course, I need your mailing address.
It makes me wonder if there are different setups as well as different prices.
Liz Z.
Liz Z. Senior Member • Posts: 1,267
On the video page ( http://www.youtube.com/watch?v=ZYRsNiIz1bk ) it says "Filtergröße: 43mm bis 52mm" which Google tells me means Filter size: 43mm to 52mm.
Liz
 Liz Z.'s gear list:Liz Z.'s gear list
Fujifilm FinePix F31fd Sony RX100 Adobe Photoshop CS6 +1 more
faerberj New Member • Posts: 17
Well, I'm here now.
It is true that I offer from 43mm to 52mm Adapter for RX100.
Only the size you want to contact me at faerberj@gmail.com.
It is true that in a small 52mm adapter lower right shading.
At 43mm there is no problem with the flash.
There are pictures:
https://picasaweb.google.com/104966931773245075713/AdapterringFurSonyRX100
Thank you! Jens from Germany
FramerDave Contributing Member • Posts: 634
Re: I'm in!
Al_10D wrote:
When is it going to be available?
Thanks.
TomBergman wrote:
I wrote to Lensmate about a week ago asking about this. This was their response.
We have just begun machining a filter adapter system for the RX100. It will be similar to the ones we make for the Canon S100 and G12 - http://www.lensmateonline.com/store/G12QC.php
The filter size will be 49mm, large enough to stack filters and combine filters and hoods without vignetting. To get on the interested parties list, just let us know.
Got an email reply from Lensmate on 20Aug. regarding the filter adapter for RX100:
"Yes we will add you to our list and email you as soon as we have our new accessories up on our website. Hopefully up for pre-order in the next week.
Regards Susan"
I offer 43mm to 52mm Adapter for RX100.
At 43mm there are no problem with the flash.
Examples Pictures :
Thank you Jens
I wish I knew which one I was receiving from Jens. I did not know there was a choice when I ordered. 52mm is nice because its the old standard Nikon size, but not at the expense of shadows or vignetting.
Liz Z.
How important is the optical quality of the filter itself? I wouldn't want to put something in front of the lens that would degrade the image quality, but nor am I up for adding another $100+ to the cost of the RX100.
I have seen Tiffen and Hoya filters for about $25 to $35 each, and then there's this set of five filters on Amazon for $13.95:
http://www.amazon.com/gp/product/B0054RJ3HK/ref=ox_sc_act_title_1?ie=UTF8&smid=A1P9QRDRYY6FXL
Not being sure how much I would actually use filters, I am tempted to start cheap, but if that would be like taking pictures through dime store glass, then it's money thrown out....
Liz
stk4007 Junior Member • Posts: 46
Jens,
It is nice of you to provide an alternative. My concern is whether the attachment/s will put stress at the tip of the lens that eventually it would alter the light path, even if so slightly. The lens extension is not rigidly held to the camera body because it is moving. Movement of the camera may produce the biggest torque at the end where the attachment is. Even when it is closed, the protruding part can scratch the side of the bag and destablized the lens column.
Is there a way to attach a tube to the body of the camera instead of the lens?
Thanks,
Sam
ianimal Senior Member • Posts: 1,054
Step-up ring glued to lens barrel
I bought a Heliopan 35.5mm --> 39mm step-up ring.
Then removed the 35.5mm thread part and glued the rest to the front of
the RX100 lens barrel.
So I have a permanent 39mm filter thread on my RX100 now.
I will start a thread with some images and info later.
I use it with a 39mm rubber lens hood and 39mm filters.
One filter is ok, but if you use a pol. filter and a ND filter at same time
there is some vignetting. Again, more info coming later.
This is a cheap and "dirty" solution.
But the lens barrel is not very solid, so I believe I have to be very careful
when adding the lens hood and filters. Hold the lens barrel with one hand etc.
RX100 Junior Member • Posts: 43
Re: Step-up ring glued to lens barrel
The Cheeseycam CPL filter should be available soon, here are a few more pics of the production filter:
https://twitter.com/cheesycam/status/237677192534970370/photo/1
https://twitter.com/cheesycam/status/239500885615595520
andres76 Forum Member • Posts: 54
Very useful info Tom. I've been looking for some sort macro lens adapter for my RX100. Looks like this ring along with a Raynox DCR-150 or 250 might be what I need.
Are you familiar with the Raynox 150/250? And if so, any preference between the two and why?
Thanks for your valuable input.
Tom Hoots
Tom Hoots Veteran Member • Posts: 6,072
Unfortunately, no -- I'm not familiar with either of them. I think they've been used by plenty of folks on other Sony cameras, though -- if you post a new thread asking about them, I'm sure you'll get replies from folks who are very familiar with them.
Tom Hoots
http://www.pbase.com/thoots
http://www.dpreview.com/galleries/4330317199/albums
Marti58
Marti58 MOD Forum Pro • Posts: 20,190
dangerous approach
what will happen if you need a warranty repair.
All my Post Processing is done with Capture NX2
http://www.flickr.com/photos/marti58/
 Marti58's gear list:Marti58's gear list
Nikon 1 Nikkor 10mm f/2.8 Olympus M.Zuiko Digital 45mm F1.8 Samsung HZ35W Nikon Coolpix P500 Canon PowerShot S95 +35 more
ManuH
ManuH Veteran Member • Posts: 3,898
Even with the 250 the magnification is not that high @100mm so I'd say the 150 is not really useful on the RX100.
luigibozi Junior Member • Posts: 35
Re: Sony RX100 filter adapters?
Check this 49mm homemade (non-CNC)
http://luigibozianu.blogspot.ca/2013/01/sony-rx100-filter-adapter-49mm.html
very happy with it and very proud
 luigibozi's gear list:luigibozi's gear list
Sony Alpha 7 II Epson Artisan 835 Apple iPhone SE +1 more
Ricardo Pocci New Member • Posts: 1
Hello
Please I would like opinions about which filter adaptor is the best to buy. I bought some days ago a Sony VFA 49R1 for my filter Tiffen 49 and it just released. The glue is very bad and the salesman didn't know what to do.
So that I'm in a hurry to buy another one because I'm in a trip.
I have been reading your reviews but I appreciate what you experienced and what is the best in terms of sticking as well, once the superficie of this camera is very complicated to stick.
Thank you very much
R
