LIghtroom 4 problem
Started Aug 16, 2012 | Discussions
lou Capeloto Contributing Member • Posts: 655
LIghtroom 4 problem
HI I have lightroom 4 and when in the library mode the photo I have selected will move to another photo by itself without me doing anything with my mouse and I dont have auto advance selected very frustrating any suggestions how to fix
Thank you
http://www.corot.smugmug.com
 lou Capeloto's gear list:lou Capeloto's gear list
Fujifilm X-E1 Fujifilm X-M1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 35mm F2 R WR
Chris R-UK Forum Pro • Posts: 15,121
Re: LIghtroom 4 problem
Are you looking at the Navigator Pane at the top left of the screen?
This shows the image under the mouse pointer in the film strip at the bottom of the screen and changes as you move the mouse pointer.
If this isn't your problem, can you give some more details. Do you have the screen in Grid, Loupe, Compare or Survey mode? Which image changes? Does it change when you do nothing at all? No you have any filters turned on?
Have you initiated the Slide Show?
Chris R
 Chris R-UK's gear list:Chris R-UK's gear list
Panasonic Lumix DMC-GH2 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
lou Capeloto OP Contributing Member • Posts: 655
Hi Chris
Thank you for your reply
I do have the navigator pane open however I am referring to the image in the strip mode that moves apologize I wasn't explicit enough
The screen is in loupe mode and it wont necessarily go to the next image but may jump to three or four images away from the image I have selected in the film strip mode
My pointer is resting over the photo and not along the film strip when this happens
No filters are on however about 10 minutes ago I locked in the side panels and that seems to help
I have never encountered anything like that. It sounds like a bug in LR.
It might be worth posting on the adobe LR forum:
http://forums.adobe.com/community/lightroom
I think that there is a list of known bugs in LR somewhere on the Adobe site.
Chris R
