Clearviewer and RX100
Started Aug 16, 2012 | Discussions
André BARELIER Veteran Member • Posts: 7,173
Hello,
Very impressed with the RX100. I don't own one yet, because I'm a VF guy, and I really don't like holding my camera at arms length for framing. That's why I bought a Nikon P7100 to complement my DSLR. The 7100 has a VF (very small, inaccurate, with no information, but it's here). I know the RX100 has an excellent LCD, but that's not enough for me.
IMO, the RX100 is in the DSLR category, image quality wise, way better than the 7100. Should it have a VF, I would buy one immediately.
I'd like to know if some of you tried the Clearviewer with the RX100 (or another camera before), and would be so kind as to share their impressions.
Thanks in advance.
André
http://a.barelier.free.fr/
 André BARELIER's gear list:André BARELIER's gear list
Nikon Coolpix P7100 Nikon Coolpix P7800 Nikon 1 V1 Nikon D7100 Nikon D3300 +8 more
Nikon Coolpix P7100 Sony RX100
tomhongkong Veteran Member • Posts: 3,035
Re: Clearviewer and RX100
I am with you on this. I would buy one in a flash if it had a VF or facility to add a Nex style EVF.
I cannot understand how folks get on trying to use an LCD in bright sunlight, let alone manage with the problems of holding at arms length, and of difficulty of spec usage.
It is time the camera manufacturers realise that even if the P&S brigade can manage with hit and miss shots, the rest of us want a VF of some sort (I could manage with EVF or optical)
tom
ET2 Veteran Member • Posts: 3,933
Don't speak for "the of us".
RX100 is a pocket camera. Anything added to comprise that would have been a horrible idea.
RX100 Junior Member • Posts: 43
I don't understand why people hold P&S cameras out at arms length, I find I hold the camera closer and use the rear LCD as kind of like a big viewfinder and it makes the camera more stable, but I think its because I'm so use to shooting SLR's it's become second nature.
A optional EVF would have been nice though, Olympus and Panasonic give you the option of using the EVF's from their MFT cameras, so it would be nice to see Sony offer the EVF from the NEX 5n on the next RX camera.
Ryan Williams
Ryan Williams Contributing Member • Posts: 598
People actually hold compacts out in front of them at arm's length? I've always held it close to my head, with my arms locked while bent — the same kind of technique I used to do when painting to keep my arms steady. I can't imagine how you'd keep it satisfactorily stable otherwise.
Liz Z.
Liz Z. Senior Member • Posts: 1,267
You might try asking this in the the Panasonic forum. There are lots of folks there that have used the Clearviewer very happily, and I think it was originally designed for the LX3.
andrbar wrote:
Hello,
Thanks in advance.
Liz
 Liz Z.'s gear list:Liz Z.'s gear list
Fujifilm FinePix F31fd Sony RX100 Adobe Photoshop CS6 +1 more
elliottnewcomb Forum Pro • Posts: 10,955
rx has a setting for lcd, 'sunny weather', just used it at the beach. awesome, could see, compose, shoot, see what I got. worthless without that setting but quite usable.
it is a process of getting used to using a lcd. my r1 has both optical vf and lcd, and an old 2005 lcd at that. It automatically switches to optical if you bring your eye to the viewer.
I hardly ever use the optical. lcd tilts and swivels, so those advantages got me used to lcd.
not arms length, you need to get it closer, I have progressive lenses in my glasses, so I can use it close, 8 or 9" away. perhaps some people try to use them with distance glasses on, and that is why they hold them out so far.
such a small and light camera needs to be held closer to be steady, especially when zoomed, and when using extended 'near optical' clear zoom which is quite good.
 elliottnewcomb's gear list:elliottnewcomb's gear list
Sony RX100 Sony RX1R Olympus Stylus 1 Sony Cyber-shot DSC-RX100 III +1 more
André BARELIER OP Veteran Member • Posts: 7,173
Thank you for your answers so far.
But don't try to convince me to get used to the LCD. The P7100 has a nice LCD, but I can't get used to use it, even when I can perfectly read the info and see the subject.
So, I'll change my question: before the RX100, some of you were probably using a VF camera (electronic or optical). Do you plan to try the clearviewer on the RX100, or will you use it as it is, ie with the LCD only?
Liz, you're right. I'll ask in the Panasonic forum.
André
Rick Evertsz
Rick Evertsz Regular Member • Posts: 267
I never hold my camera at arm's length. I liked the NEX-5N because I could shoot from the waist, and thought I would miss the articulated LCD when I sold it to buy an RX100.
Surprisingly, the RX100 lends itself to shooting from the hip. The LCD is really clear when viewed at an angle. I hold the camera about 20cm from my body with my elbows locked into my sides. The camera is cradled in my left hand so I can operate the control ring, and I press the shutter button with my right thumb. Hope that's clear. Try it!
Mostly, I don't miss my DSLR's VF, nor do I miss the 5N's articulated screen. Obviously it's a compromise, but I find it works well for me and allows me to hold the camera nice and steady.
I'd prefer to have an EVF, but the RX100's viewing options are a lot more versatile than I had expected.
 Rick Evertsz's gear list:Rick Evertsz's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha 7S Sony FE 55mm F1.8 Sony FE 24-70mm F4 OSS Sony FE 70-200 F4
HankK
HankK Regular Member • Posts: 389
Clearviewer works great on RX100
I have a Clearviewer that I had been using on my NX200. I have tried it on my RX100. It works GREAT! I want to leave it on all the time because it allows you to see the image so much better for composition. It even works in the sun. It also allows you to hold the camera up to your face which for me improves camera stability.
The one thing, is that if you leave it on the camera, it adds just enough bulk that it does not fit in my RX100 belt case. It does fold flat and has a nice felt stop to prevent scratching of the LCD. I still need to solve this small case related problem so I can keep it on all the time.
Hank K
Nikon D800E, Sony RX100, Samsung NX20 (former 5DM2, GH2 Kit, and Fujifilm X100 shooter)
Thank you guys!
Very informative and useful answers.
I just have to wait for Photokina. If nobody comes up with a RX100 contender, then it will be the RX100.
See you soon!
André
JacquesC Senior Member • Posts: 1,864
Re: Thank you guys!
Like you I prefer a viewfinder and that's why I've been ogling the Nikon V1.
Have you given it any consideration ?
Jacques
Apple & Eve website and blog : apple-and-eve.com
Re: Thank you guys!
Hi Jacques,
Yes, I for sure would like the Nikon V1 EVF and fast AF. But it's not a compact camera, even with the 10-30 only. And I don't like the lack of dedicated buttons.
I have a D90 for when I need to change lenses.
What I'm looking for is a travel camera to replace the P7100. I'm tired to have no information in the VF, which means I'm forced to use the LCD if I wanna know what I'm doing.
The RX100 is much smaller than the V1. Even with a clearviewer, it is a very small camera, perfect for travelling. I don't shoot many pictures at long focal lengths, so I won't miss the 200mm of the P7100 very much.
But I'll wait to see what Nikon comes up with at Photokina.
André
Re: Thank you guys!
I know the feeling all too well - what a pity the manufacturers are so reluctant to add viewfinders to the small cameras, The RX100 sounds like a real gem and if it had a VF I would not hesitate in getting one. I had a look at the Clearviewer but am not very thrilled by it, I think it will make the camera more bulky and not a pocket camera anymore, in which case the V1 starts looking more suitable again.
Jacques
JohnWho Contributing Member • Posts: 853
Hi -
We discussed the Clearviewer for the HX9V here:
http://forums.dpreview.com/forums/read.asp?forum=1009&message=38907977
Seems the same info would be appropriate for the RX100.
My comments in that thread still stand after using it for awhile. It resolves virtually all of the "washed out screen" problem in bright sunlight.
Thanks! Very useful (nt)
NIK11 Senior Member • Posts: 2,827
Limited options
I have a 'clearviewer' on my S95.
It more or less solves the viewing problems in harsh light and allows better tracking of moving subjects. It's a cheap solution although not a particularly elegant one - it adds about 8mm(1/3") to the camera thickness and the close view is very pixelated.
Until manufacturers cotton on to the pent up demand for small cameras with EVF/OVF then the clearviewer is currently the only option. Try it.
I will likely buy the first decent small compact with built-in EVF, even if a different model increases on the S100/RX100 size to something else around 40mm thick. That's still pocketable fo me. And throw in a tilting lens please, NEX7 buyers are not the only ones wanting better handling from small cameras.
Nick
Re: Limited options
Thanks Nick for the info. I'm exactly in the same boat. I'm still waiting for an advanced compact with buit in usable VF...even if it is a bit larger than the RX100.
By usable VF, I mean a VF which displays the main parameters.
It could be a high quality EVF, or an OVF with shooting info overlayed, (very expensive, I'm afraid...)
Tilting lens? Do you mean tilting LCD?
Nick
Re: Limited options
Oops! Yes, I meant tilting LCD . Can't imagine a compact with tilting lens.
Nick
Nick
millsart Senior Member • Posts: 2,771
Question for the VF essential crowd...
I'm all for VF's whenever possible, don't get me wrong. Couldn't work without the nice big bright optical finders on my D3s's, and I've certainly enjoyed the finders on my M9 down to the Fuji X100 and have surprisingly found EVF's work pretty darn well on the NEX7 and EM-5.
Useful to have, but a true "must have" ??? I just don't get it, especially on a pocket camera.
Make the camera bigger and sell it for $1000 and it won't be a pocket point and shoot, it will be the rumored NEX6 which is a scaled down NEX7 as I understand it
Likewise, if I wanted to put a $400 add on Sony EVF onto it, then its a going to be rather unpocketable, just like the NEX5n with the add on EVF
For that matter, good as the RX100 is, I'd prefer the NEX5n IQ if I'm going to spend that type of money on the add on EVF.
RX100 is simply a pocket camera, that is supposed to be as compact as possible.
Unless your totally nearsighted I can't imagine why anyone would really hold a camera at arms length away.
Again, I'm not saying I'd want to shoot a wedding or football game without my OVF bodies, but I just don't see how its so impossible to use a LCD only option as well
Heck, I probably shot my Fuji X100 using the LCD about 50% of the time. Further, assuming you've got an iPhone or other smartphone, and take some photos with it as most smartphone owners do, serious or otherwise, how can you get on with that ?
