Nikon D3100-Can't change my aperture in manual mode
Started Aug 15, 2012 | Discussions
DesertRose New Member • Posts: 7
I am a beginner in photography and I started using manual mode recently, from past 2 days I am unable to change my aperture in manual mode even after pressing the exposure compensation button. I can change only the shutter speed.
I can change aperture settings in Aperture-priority and Shutter speed-priority but not in Manual mode. I have pressed the AE-L button on and off, and tried every menu setting I could find. I still have no clue what is wrong.
Can somebody help me?
 DesertRose's gear list:DesertRose's gear list
Nikon D3100 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR
Nikon D3100
Kvenna Contributing Member • Posts: 625
Re: Nikon D3100-Can't change my aperture in manual mode
Are you actually holding the exposure compensation button down as you turn the command dial?
Chris
DesertRose OP New Member • Posts: 7
No I just press it
Mako2011
Mako2011 MOD Forum Pro • Posts: 19,999
DesertRose wrote:
No I just press it
Try holding it down while turning and see what you get. Report back
intensity studios Contributing Member • Posts: 668
For the D3200, when in manual mode, you hold down the exposure compensation button and turn the dial to change aperture.
I assume it's the same for D3100
 intensity studios's gear list:intensity studios's gear list
Nikon D3200 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Nikon AF-S Nikkor 50mm f/1.8G Canon Pixma Pro9000 Mark II Adobe Photoshop CS6 +4 more
Glen78 Contributing Member • Posts: 704
I have a D3100 and can confirm that you have to hold down the + - exposure button and turn the dial at the same time to change the aperture in manual mode. I can understand why this might be confusing since in aperture priority mode this changes exposure compensation and aperture is changed in the same way you change shutter speed in M mode. It is also annoying because as far as I can tell, you cannot change exposure compensation in manual mode. I usually swith the A mode, change exposure comp., and then back to M mode which maintains the exp. comp. settings of A mode.
-Glen
 Glen78's gear list:Glen78's gear list
Nikon D600 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon PC-E Nikkor 24mm f/3.5D ED +5 more
baloo_buc Veteran Member • Posts: 8,032
That's why people prefer two dials cameras. Sometimes is confusing but after a while it will be automatic for you.
You can change EC before entering M mode or using Info Screen afterwards.
Victor
Bucuresti, Romania
http://picasaweb.google.com/victorpetcu69/
http://picasaweb.google.com/teodor.nitica/
http://picasaweb.google.com/vpreallize/
http://picasaweb.google.com/v.petcu.gci/
http://picasaweb.google.com/vpetcu.gci.arhiva/
http://s106.photobucket.com/albums/m268/victor_petcu/
 baloo_buc's gear list:baloo_buc's gear list
Nikon D5100 Olympus PEN E-PL5 Nikon D7200 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Tokina AT-X Pro 12-24mm f/4 DX II +13 more
Thanks Everyone I can change my aperture by holding the exposure compensation button
My Soul
My Soul New Member • Posts: 2
Dear Friends,
Can anybody help me out to adjust aperture and shutter speed in my Nikon D3200 as am also a beginner.
Ragsphotography New Member • Posts: 1
Press the "Exposure compensation button/Adjusting aperture button/Flash compensation button +/-" and then use the command dial to adjust aperture. For shutter speed press "FN" button and use the command dial to adjust it. Link to all those buttons is given below
http://imaging.nikon.com/lineup/dslr/d3200/compatibility03.htm
