How to download Photofunstudio software for Panasonic Lumix Lx5?
Started Aug 13, 2012 | Discussions
SimpsKwan New Member • Posts: 3
Hello,
I bought a Pansonic DMC Lumix-LX5 a year ago in Japan and installed Photofunstudio that came with the camera on my computer. However, last month I have to reinstall window so the Photofunstudio was gone. I want to reinstall Photofunstudio to my computer but unfortunately, I still can't find the CD-rom that came with the camera.
What should I do? Is there a way to download Photofunstudio online? Or do I have to buy a cd-rom again?
I have visited this page ( http://panasonic.net/avc/lumix/photofunstudio/index.html ) and still can't find the download link anywhere. I only found the links to update the existing software. Where exactly should I click to download it?
Also, as I bought my camera in Japan, would the english version of Photofunstudio be compatiable with my camera?
Thank you very much.
PC Wheeler
PC Wheeler Forum Pro • Posts: 16,029
Re: How to download Photofunstudio software for Panasonic Lumix Lx5?
Look for Panasonic Support site.
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-ZS100 Sony Alpha a6300 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 50mm F1.8 OSS +5 more
tom1234567
tom1234567 Senior Member • Posts: 1,041
 tom1234567's gear list:tom1234567's gear list
Nikon D7200 Tamron SP 70-300mm F/4-5.6 Di VC USD Sigma 105mm F2.8 EX DG Macro Sigma 17-50mm F2.8 EX DC OS HSM Nikon AF-S Nikkor 50mm f/1.8G
SimpsKwan OP New Member • Posts: 3
I tried to download it but it just said that Photofunstudio 5.1 HD has not been installed..
tom1234567 wrote:
you could try here
http://panasonic.jp/support/global/cs/soft/download/pfs51hd.html
Cheers Tom G
tom1234567
Hi again do a serch for it on your computer look in program files if it is not listed on the add remove list then it could have partial loaded lookin program files
if it is there delete it then try again hav u been able to download it
cheers Tom G
Tucana New Member • Posts: 1
I have the Panasonic Lumix CD to download on my computer. Nothing happens when I insert the disc.
Please help me to download this software for my Luminex camera.
Thanks,
YR
windmillgolfer
windmillgolfer Forum Pro • Posts: 11,989
Assuming this is Wndows PC, XP/W7, you may have autorun disabled. Just had a look at my disc; it is a DVD not a CD. Assuming you actually have a DVD drive, if it will still not autorun, then put DVD in, use Windows Explorer/My Computer to look at the DVD, you will see  InstMenu, double click on it and things should start to happen.
Stuart
Also at http://www.flickr.com/photos/dieselgolfer/
Mr Ichiro Kitao, please upgrade the FZ50
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GM1 +1 more
Sassi4 New Member • Posts: 1
I bought a new PC with Windows 8, soon to be windows 10 on it.  I tried moving photos from the old PC but the Panasonic software does not work on windows 8. Is there a panasonic version out for windows 8?
Nells250
Nells250 Junior Member • Posts: 32
I know this is an old thread, but I MIGHT have some info to help folks.
The used DMC-FX45(40) I bought used didn't come with the PhotoFun software.  The Panasonic website is rather useless.
So what I did was find the CD that came with my old FZ28, installed the old version of the program, and tried it out.
It acted up a bit on Windows 7 Pro, even in Compatibility Mode. I searched and searched and finally found a link that has a patch for the program:
http://av.jpn.support.panasonic.com/support/global/cs/dsc/download/index.html
SO FAR it seems to make the program work with newer versions of Windows.
Hopefully this helps someone, somewhere...
 Nells250's gear list:Nells250's gear list
Panasonic Lumix DMC-FZ40 Canon PowerShot SX40 HS
edhume
edhume Regular Member • Posts: 383
What use did you get out of this software?
 edhume's gear list:edhume's gear list
Sony Cyber-shot DSC-V1 Panasonic Lumix DMC-LX5 Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-LF1 +3 more
Nells250
Was looking for an answer to why accessing the camera like a USB drive wasn't working properly.  Also to see if it was like Canon's file transfer software.
edhume
I use a USB3 card reader. They plug into your USB, and they are cheap. Windows asks me every time if I want the download the pictures, what to call them, and do I want to erase the pictures from my card. Works well for me.
