Warning: Weak plastic buckles on E-5 strap
Started Aug 12, 2012 | Discussions
philosomatographer
philosomatographer Contributing Member • Posts: 530
Hi All,
With no warning, and no apparent reasons, the plastic strap buckle on my E-5 disintegrated (almost sending my camera crashing, luckily I caught it). On inspection, the other one was also cracked.
This was after a couple of weeks of carrying around the 7-14 and 35-100 on the camera. Clearly the cheap buckles were not made for any form of stress.
I replaced them with metal strap buckles from an OM-1 strap, and I'm sure they'll last (they already lasted 30 years
Be warned... check your E-5 strap if you carry it over your shoulder with heavy lenses, before it surprises you.
Quite disappointing on this otherwise tank of a camera. I'm sure they put this same strap on the E-450 etc?
 philosomatographer's gear list:philosomatographer's gear list
Nikon Df Nikon AF-S Nikkor 50mm f/1.4G Carl Zeiss Makro-Planar T* 2/100 +3 more
Olympus E-450 Olympus E-5
eaglevshawk Forum Member • Posts: 57
Re: Warning: Weak plastic buckles on E-5 strap
I've always thought camera companies include those cheap stock straps just in case the buyer doesn't already have a decent strap. I would not use one for any extended period, especially with the amount of the weight you're carrying, if only because it would be uncomfortable for me.
I've tried a few straps on my E3 and like my latest from Ape Case the best. It's a good size for the camera and my biggest lens (50-200 swd) and it doesn't have those quick release latches, which make me nervous and are unnecessary for my needs.
Link: http://www.amazon.com/Ape-Case-DSLR-Strap-AC00236/dp/B003BEDRJS/ref=sr_1_1?ie=UTF8&qid=1344791061&sr=8-1&keywords=ape+case+strap
Torlang
Torlang Regular Member • Posts: 161
http://www.upstrap-pro.com/product/SLR-QR-H/SLR-QR-K.html
I also use a Black Rapid Strap, but can't use it when I have the tripod plates installed. That's when I use the Upstrap (on an E-5)
 Torlang's gear list:Torlang's gear list
Olympus 12-40mm F2.8 Olympus E-M1 Olympus 40-150mm F2.8 Pro
nyfalls Contributing Member • Posts: 792
I actually had this issue last fall with my E5 and the stap let lose and my E5 and 12-60 fell, snapping the hood. The buckles are defective and should not be used.
Upstate NY Waterfalls and Photography
My Galleries: http://www.nyfalls.com
My Niagara Falls Gallery: http://www.nyfalls.com/niagara/niagara-main.html
odla New Member • Posts: 3
Same thing happened to me 10 days ago. I was lucky, apart some scratches on the lenshood of the 12-60 lens and another one on the E-5, everything was fine. Better check those straps! aldo
Roger Engelken
Roger Engelken Veteran Member • Posts: 4,280
Now that is a strap...rated to 200lbs..
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 +2 more
Scanlon Regular Member • Posts: 191
Mine have broken twice, and Olympus sent me replacements, but I think I need to look seriously at another, heavier strap. Seems like its a real problem. I was also lucky that I caught the camera.
andix Regular Member • Posts: 154
You can use it with plates, only if you have a Manfrotto RC-2 system. Black Rapid is making this:
http://www.blackrapid.com/product/hardware/fr-t1/
You're welcome
indecision may or may not be my problem...
http://www.americandusk.com
facebook.com/americandusk
 andix's gear list:andix's gear list
Fujifilm X10 Fujifilm X100S Olympus PEN E-PM1 Olympus OM-D E-M5 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake +15 more
winddancing Contributing Member • Posts: 556
Thanks for the warning and suggestions
I have a weak heart. : )
Clueless
philosomatographer
philosomatographer OP Contributing Member • Posts: 530
I'm quite amazed at the number of people with this issue! Definitely a serious oversight on an otherwise well-constructed camera.
Glad nobody suffered serious damage (from what I can see in this thread so far, in anyway).
Torlang
Don't think that plate will fit on my Kirk BH-3 though. Wish it did.
You're welcome
DPetitme New Member • Posts: 2
Near accident for me too a few days ago during a travel in Austria.
I replaced the plastic buckles with the metal ones of my very old argentic Minolta...
It is not acceptable with a so pricy camera.
 DPetitme's gear list:DPetitme's gear list
Panasonic Lumix DMC-LX100
UncleLJ Contributing Member • Posts: 893
Love my Black Rapid. Best of all, easy access and no strain around your neck.
Lawrence "Uncle LJ" Sauter
http://lawrencejsauter.smugmug.com
http://ljsauter.zenfolio.com/
 UncleLJ's gear list:UncleLJ's gear list
Nikon D800 Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Nikkor 70-200mm f/4G ED VR
Jay Jenner
Jay Jenner Contributing Member • Posts: 742
Standard straps by all the majors are rubbish. Plus I prefer them plain. I have tried many straps and what I currently hang my E3 from is a Crumpler Industry Disgrace. Its really tough and comfortable to wear.
Linkage here:
http://www.crumpler.com/us/Camera-Bags/Camera-Straps-Accessories/Industry-Disgrace.html
 Jay Jenner's gear list:Jay Jenner's gear list
Fujifilm X10 Olympus E-M1 Olympus OM-D E-M10 Panasonic Lumix DMC-GH4 Olympus M.Zuiko Digital 45mm F1.8 +2 more
rev43 Regular Member • Posts: 128
Linkage here:
I am looking for one for my E-5 but without a quick release, would this fit the bill and did you buy it in the UK.
Timskis6 Veteran Member • Posts: 9,562
Same thing on my E-3 and 150/2
I had this issue as well when I was using my E-3 quite frequently with heavy lenses. I noticed it while on some remote islands in Panama, and luckily had a sewing kit with me. I just sewed the strap in a semi-permanent fashion until I return home a few weeks later.
I now use the Crumpler Industry Disgrace and really like it. Above all else, it is extremely comfortable and makes "wearing" heavy lenses more doable.
Tim
http://www.developemotion.com
'I haven't been everywhere, but it's on my list.'
E3/7-14/12-60/35-100/150/EC20
http://www.flickr.com/photos/timskis6/
CollBaxter
CollBaxter Forum Pro • Posts: 12,724
Thanks for the Heads up.
I have stopped using the neck strap with My E-5 and heavy lenses . I use a hand grip which I find far more secure.
I do use a Strap on the E-620 but that more for hanging it over my shoulder.
Collin
(Aficionado Olympus DSLR )
http://collinbaxter.zenfolio.com/
http://www.pbase.com/collinbaxter
Life is not measured by the number of breaths we take, but by the moments that take our breath away. (George Carlin)
New Seventh Wonder of the World.
 CollBaxter's gear list:CollBaxter's gear list
Canon PowerShot SX230 HS Olympus E-500 Olympus E-30 Olympus E-620 Olympus E-5 +15 more
TorsteinH
TorsteinH Senior Member • Posts: 1,091
My E-5 falled to the ground for the same reason, that crappy plastic bucle on the strap broke and down on the ground my E-5 with the 12-60 fell. I find it quite irresponsible by Olympus to sell their camera with such a lousy strap.
Luckily the ground was not hard and my E-5 works as it always has.
http://www.ohb.no/foto
Torstein
 TorsteinH's gear list:TorsteinH's gear list
Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Corel PaintShop Pro X4 +2 more
Marathonianbull
Marathonianbull Contributing Member • Posts: 561
Scarry thread indeed, I'll seriously consider a new neckstrap... But the quest for perfection isn't obvious either!
 Marathonianbull's gear list:Marathonianbull's gear list
Panasonic Lumix DMC-L10 Olympus E-620 Ricoh GXR A12 50mm F2.5 Macro Olympus E-5 Ricoh GXR GR Lens A12 28mm F2.5 +23 more
dave gaines
dave gaines Veteran Member • Posts: 9,183
Keep my E-5 & strap in a pouch
Thanks for the warning. I checked my strap sinch/keepers really closely yesterday before going out on a hike. They look fine for now but I will consider what Tim suggested, sewing the straps and tossing the buckles. All they do is keep the strap from slipping. I like the Olympus strap because it's less bulky, it doesn't have big hard buckles that scratch the camera and it can fold up into a pouch easily when I'm not shooting.
Most of the time I carry my E-3/E-5 in a Tamrac camera pouch. I have one that fits the camera with grip and lenses up to & including to the 50-200. The Tamrac pouch # is 5627. I also have a Lowepro pouch that fits the camera, grip and 35-100 mm f/2 lens, but that pouch does not get used a lot because of the way I use the camera with that lens.
I carry the camera slung over one shoulder in the pouch when I'm hiking, biking or out on the beach in the sun. It keeps the camera safe from scratches, bumps, dirt and damage when I'm bushwacking or if I fall on the trail.
The pouch carries the weight most of the time. I have the camera and pouch straps adjusted so the weight is on the larger pouch strap, on my shoulder, not on my neck. I also removed the big metal pouch QR buckle and just threaded the strap through the bid D loops with a couple of strap keepers. Why have hard buckles on a camera strap or case?
I'm going to check those Olympus strap keepers more carefully and may replace them with a metal version soon. Thanks again. The are lots of good tips here on alternate straps.
Dave
No thought exists without an image. Socrates
http://whaleshark.smugmug.com
 dave gaines's gear list:dave gaines's gear list
Olympus C-8080 Wide Zoom Olympus E-330 Nikon D800E Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED +7 more
