1 GB MicroDrive Write Time Comparison (D1)
Started Sep 1, 2000 | Discussions
MattTheHat© Contributing Member • Posts: 510
Howdy Folks,
I just picked up one of the new 1 GB MicroDrives today and thought I would test the write times between it and my 340 MB MicroDrive as well as my 160 MB Lexar 8x Compact Flash card. I charter my results, which you should be able to see below. All times are in seconds. The tests were run with my D1 in continuous shooting mode, using manual focus, with the lens cap on (so there should be no differences in JPEG processing times) at 1/500. Each card was formatted immediately before each run. The times shown were started immediately after the camera fired the last shot, so they don't include the time required to take the 10 or 21 shots.
Interestingly, the 1 GB MicroDrive significantly outperformed the 340 MB MicroDrive in the NEF mode (HI RAW in the chart). This was the only place where the 1 GB model outperformed the 340 MB model, so I double checked it several times, with the same results every single time! Perhaps IBM has optimized the sector size or buffer size (or interleaving or other some such magic) with Nikon D1 RAW transfer in mind? Sneaky devils!
I hope some of y'all will find this un-scientific test useful.
-MattTheHat
Uwe Steinmueller
Uwe Steinmueller Veteran Member • Posts: 3,414
Re: 1 GB MicroDrive Write Time Comparison (D1)
What about heat with 1GB drive?
Uwe
MattTheHat wrote:
Howdy Folks,
10 or 21 shots.
-MattTheHat
Stan Disbrow Senior Member • Posts: 2,935
Matt,
Nice job. I haven't picked one up - yet.
Uwe,
The 1GB MD has a lower current demand (from IBM spec sheets) than the 340MB one does. That will automatically mean less heat generation. Part of this is refinement of the drive controller in the MD and part of this is the closer track spacing a 1GB has over a 340MB. The heads don't need as much current to move a shorter throw.
I've not understood the MD heat issue. All three of my MD's run cooler than either my SanDisk or Lexar flash cards. I can only surmise that there were variations in some MD's, perhaps earlier ones. I can recall such variations in larger drives in the past, so it wouldn't surprise me one bit.....
Stan
Uwe
Richard Parkinson Regular Member • Posts: 345
Many thanks for the info Mat.
I would guess that the 1GB microdrive has a faster write speed, due to the higher recording density, but also higher seek time (possibly due to the lower power consumption?). This would explain the slower times for smaller files and faster ones for larger files as when you create a file you have to seek to the file directory to write an entry and then seek to the start of the file and write it, so with bigger files the seek/data size ratio is larger.
If this is true then it is possible that it may become very slow if it is not formated regularly to prevent fragmentaion.
MattTheHat wrote:
Howdy Folks,
10 or 21 shots.
-MattTheHat
MattTheHat© OP Contributing Member • Posts: 510
Hey guys,
I haven't shot with the 1 GB MicroDrive enough to commment ont the heat, but
Stan is spot-on about the current consumption vs heat issue (even if he's not a
professional photographer ;-> ). My 340 MB MicroDrive DOES get hot, perhaps it's
an earlier model, but I did not notice excessive heat from my test runs. If it's
important, I'll run themm again and try to guesstimate the heat level of the drives.
-MattTheHat (rank amateur)
Stan Disbrow wrote:
Matt,
Uwe,
one bit.....
Stan
Uwe
Glenn New Member • Posts: 2
Hey Guys,
Where did you buy your 1gb Microdrives from?
I'm stuck in the UK where stocks are non-existent and they will charge about 40% more (which sucks).
Looking forward to using one in my canon and my ipaq...
Glenn
MattTheHat wrote:
Hey guys,
but
he's not a
perhaps it's
If it's
the drives.
Stan Disbrow wrote:
Matt,
Uwe,
one bit.....
Stan
Uwe
Mike Kelley Senior Member • Posts: 1,445
Of course, the real issue is not whether the 1gig drive is faster than the 340 but whether it is fast enough . Depending upon camera used, you may very well not be able to shoot faster than the drive can store images, or the drive lag may be well within acceptable tolerances.
I'd be more curious of your (and others') non-scientific impressions of how the drive performs in the camera. That is, do you feel that you're spending too much time waiting for it to write? I'm planning on using such a drive in the Canon D30, so if it doesn't seem fast enough for the D1 that may or may not be indicative of how happy I'd be with the performance, but it would still be interesting to read people's opinions.
Hello Glenn,
I got mine from Imaging Spectrum here in Dallas
http://www.imagingspectrum.com > . I'm not sure if they export or not. Good luck.
-MattTheHat
UPSGlenn wrote:
Hey Guys,
Glenn
MattTheHat wrote:
Hey guys,
but
he's not a
perhaps it's
If it's
the drives.
Stan Disbrow wrote:
Matt,
Uwe,
one bit.....
Stan
Uwe
Bernard Carns Senior Member • Posts: 1,211
The times are in seconds, eh (sentence 3).
It takes over 6 minutes to write 21 fine images and over 2 minutes to write 10 raw images to a D1?
My 330 writes 10 raw images to my 340 microdrive in 34 seconds.
In 6 minutes I could write a lot more than 21 raw images and the die on my 330 is 10% larger than the D1.
Hmm.
BC
MattTheHat wrote:
Howdy Folks,
10 or 21 shots.
-MattTheHat
 Bernard Carns's gear list:Bernard Carns's gear list
Canon EOS 5D Mark II Panasonic Lumix DMC-GH2 Canon EF-S 10-22mm f/3.5-4.5 USM Nikon AF Micro-Nikkor 60mm f/2.8D Panasonic Lumix G Vario 7-14mm F4 ASPH +2 more
Jay Kelbley Contributing Member • Posts: 582
BTW..
The 1 GB Microdrives have been tested in and are fully compatible with the current Kodak DCS cameras.
They are an especially good match for cameras that store larger files like the DCS 330, DCS 560, and DCS660...
-Jay Kelbley
Eastman Kodak Company
jay.kelbley@kodak.com
 Jay Kelbley's gear list:Jay Kelbley's gear list
Kodak LS420 Samsung EX2F Samsung Galaxy Camera (Wi-Fi) Canon EOS D30 Kodak DCS720x +22 more
Glenn,
Let me know if you find anything, I'm in the same boat!
Glenn wrote:
Hey Guys,
Glenn
MattTheHat wrote:
Hey guys,
but
he's not a
perhaps it's
If it's
the drives.
Stan Disbrow wrote:
Matt,
Uwe,
one bit.....
Stan
Uwe
Mike,
I have the 340's. Haven't picked up a 1GB - yet. I find that I wait too long for NEF files to write, but that the Fine JPG time is more than fast enough. I shoot a lot of fast-paced auto racing action, and the D1 keeps up with me as long as I stay in the JPG mode.
For less hectic shooting, the transfer speed using NEF files is OK as long as I'm making use of the 10-shot buffer RAM.
Stan
What I can't understand is why Nikon don't let you take advantage of the D1 memory buffer when you are in single shot mode. There are plenty of times when you don't want continuous shooting but do want to be able to shoot before the last shot has been saved, especially with NEF's and TIFFs (although I never use these).
Anyone know why this is the case?
Stan Disbrow wrote:
Mike,
Stan
Sam Leinhardt New Member • Posts: 1
Interesting results especially when contrasted with IBM's published sustained write speed of 2.6-4.2 MB/s for their microdrives compared with 1.2-1.5 MB/s for Lexar's 8X and 10X CFs respectively. Matt's results seem counterintuitive.
MattTheHat wrote:
Howdy Folks,
10 or 21 shots.
-MattTheHat
Stephen Erf Forum Member • Posts: 50
Glenn wrote:
Hey Guys,
Helix in Chicago had them as of Friday last.
Steve
Glenn New Member • Posts: 1
Ended up reading another thread where you could order them from Roberts Imaging.
http://www.robertsimaging.com
Can't find the drive on the web but if you call and ask for Jody he will organize everything for you. Just need to send a money order to the states. That clears in about 5 days and then they FedEx it and you hope customs doesn't inspect it
Notified today that it's shipped so will let you UK folk know how the customs handle it and how much more I may have to pay.
Glenn
MattTheHat wrote:
Hello Glenn,
Good luck.
-MattTheHat
UPSGlenn wrote:
Hey Guys,
Glenn
MattTheHat wrote:
Hey guys,
but
he's not a
perhaps it's
If it's
the drives.
Stan Disbrow wrote:
Matt,
Uwe,
one bit.....
Stan
Uwe
Whao New Member • Posts: 17
How do you feel about the power consumption between the 340MB and 1GB drives? Is it noticiable?
Whao
MattTheHat wrote:
Howdy Folks,
10 or 21 shots.
-MattTheHat
robert i reis Regular Member • Posts: 119
Stan:
How do you set the D1 to use the 10 Shot Buffer Ram? I've currently set my D1 to Continuous, custom setting 25/1, cutom setting 26/1.
Bob Reis
reis@buffalo.edu
Stan Disbrow wrote:
Mike,
Stan
If you shoot in JPEG mode, you get a maximm of 21 shots in continuos mode. If
you shoot in RAW or any of the TIFF modes, you get 10. You choose your frame
rate for continuous mode in Custom Menu #25, and the maximum number of
shots (up to 21 or 10) in Custom Menu #26.
-MattTheHat
10 Shot Buffer Ram - How to? wrote:
Stan:
Bob Reis
reis@buffalo.edu
Stan Disbrow wrote:
Mike,
Stan
