Wisley Gardens today.....SX40
Started Aug 10, 2012 | Discussions
AndyPerry New Member • Posts: 18
A few i've taken today at Wisley Gardens,got some super shots very pleased.
 AndyPerry's gear list:AndyPerry's gear list
Canon SX220 HS Canon PowerShot SX40 HS
pineledger
pineledger Regular Member • Posts: 223
Re: Wisley Gardens today.....SX40
Lovely macros, especially that gorgeous white lily!!
BobT Forum Pro • Posts: 12,790
Very nice images. But this brings up a question about the SX40 and close-up(AKA: macro) shooting.
As I understand it, you can set the camera for "Macro", but need to have FL set for full width......no zoom? Correct? With this setting you must be VERY close to your subject.
But if you choose to use the full zoom length(150mm), you do NOT set the camera to "macro", but to "normal"?
How far back must one be for the closest that you can get to your subject when using full zoom? Will the camera fail to produce it's "focus beep" confirmation sound if you are too close?
 BobT's gear list:BobT's gear list
Olympus XZ-1 Canon PowerShot SX50 HS Panasonic Lumix DMC-FZ1000 Canon EOS 550D Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) +2 more
tonyinport Contributing Member • Posts: 567
Great work with your SX 40. Enjoy the camera! Tony
 tonyinport's gear list:tonyinport's gear list
Canon PowerShot G12 Canon EOS Rebel T4i Canon EF-S 15-85mm f/3.5-5.6 IS USM
AndyPerry OP New Member • Posts: 18
Ok BobT, I don't use macro mode at all just have camera on full zoom with 2.0 TC and aperture priority set all saved in my C1 setting.You need to be about 5 or 6 feet away for this to work well the camera just won't focus when closer and you don't get focus confirmation, I also use the evf as I,am a glasses wearer and just hate to keep swapping out to my reading glasses.
VisionLight
VisionLight Senior Member • Posts: 3,708
Just to clarify, Andy, you can use this set-up effectively from 4½ feet measured from the plane of the sensor (approximately the tripod mount on the bottom of the cam.) See my post here that shows the results at 4½ feet:
http://forums.dpreview.com/forums/read.asp?forum=1010&message=40604881
 VisionLight's gear list:VisionLight's gear list
Samsung NX1 Samsung NX 60mm F2.8 Macro ED OIS SSA Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
arrow180
arrow180 Regular Member • Posts: 146
I will have to give the 2x TC a try. Do you use the smaller focus box?
Nice shots.
 arrow180's gear list:arrow180's gear list
Canon SX220 HS Fujifilm X10 Canon PowerShot SX40 HS
Thanks Vision i hoped you would pop in and explain it all.
VisionLight
I keep the AF settings on my SX40 to Flexizone and the smaller focus frame size. It's very helpful in getting the stamens and pistils of flowers, as well as bees and other small insects in focus. For non-macro-like photography, it's also the only way I could have taken the image show here under such extreme conditions:
http://forums.dpreview.com/forums/read.asp?forum=1010&message=42212023
