SD Card and A620 problem
Started Aug 7, 2012 | Discussions
poppa68 Regular Member • Posts: 190
Wonder whether someone could advise. I have a pretty old and trusty A620 which my wife now uses. Had it for around 8 years with no problems; a great little camera.
Still using the original SD 498 mb card and thought I'd treat it to a new one. Boughta Sandisk SDHC 4 card with 4 gb. Loaded it and get the message. "Card Error" Card locked". It is definitely not locked. The "format card" section in the Menui is greyed out.
Card works fine in my SX40.
Maybe I have bought the wrong type of card but couldn't see any other sort of SD card in the store.
Any advice gratefully accepted.
 poppa68's gear list:poppa68's gear list
Canon PowerShot A620 Canon PowerShot SX40 HS Canon PowerShot SX240 HS Canon EOS 10D Canon EOS 70D +5 more
Lenny on Ice Regular Member • Posts: 100
Re: SD Card and A620 problem
I think you need an SD card only, not SDHC. Choose a card without the "Class" qualification, the speed qualification like "133x" will work. Those SD cards have 4GB at max.
poppa68 OP Regular Member • Posts: 190
Thanks Lenny I thought it was something like that although I couldn't see that type of card in the store. I will have another look. Thanks for the help !
Geoff
RickS Veteran Member • Posts: 4,579
Lenny mentioned a 4GB SD card. While there were some non-HC 4GB SD cards made early on, they had a non-standard format and are now nearly impossible to find.
The only way you can be sure of getting a compatible card is to buy a 2GB (or less) card, which may also not be so easy to find. Even then you should probably check with Canon, or maybe another A620 user here who knows if it will accommodate a card that large. I know the A640 will but I don't know about the A620.
Good luck,
Rick
Geoff
Steve40
Steve40 Regular Member • Posts: 445
I don't imagine the old 620, is compatible with the new larger cards. In its day a 1 mb would have been a huge card, let alone anything larger. It may pay you to get in touch with Canon, and ask. Like the old PC's which can no longer keep up with modern software, and programmin. Our old cameras finally fall, before modern technology.
Steve40.
http://steveslandscapes.50webs.com
Steve40.
I have an old SD200 which came up in 2004 and it works just fine with a 4GB 133x SD card.
Thank you all for the info. I have got hold of a couple of 2gb cards from
7dayshop. Reckon they will be sufficient.
Do I need to know anything about CF cards for my old 10D ?
Yes I know I need to update ! Can't believe how long I have had these cameras!
My 10 month old SX40 is my new baby and I love it.
Thanks again and regards.
Geoff.
jsmagic New Member • Posts: 1
remove the card and slide the little yellow thingie the other way. reinsert the card.
