650D: Disadvantage of replacing bad rubber grips? Locked
Started Aug 7, 2012 | Discussions
This thread is locked.
DSHAPK Contributing Member • Posts: 782
Re: 650D: Disadvantage of replacing bad rubber grips?
Call canon tech support.
 DSHAPK's gear list:DSHAPK's gear list
Canon EOS 550D Canon EOS Rebel T4i Canon EF 50mm f/1.4 USM Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF 55-200mm f/4.5-5.6 II USM +3 more
dgzakin New Member • Posts: 18
Anybody has a 10 digit serial number on his T4i?
John Usa Regular Member • Posts: 202
Please tell us from which dealer did you buy your T4i?
 John Usa's gear list:John Usa's gear list
I bought my camera in Israel from the largest dealer in our country.
They were not aware of the problem at all.
Canon told to look for the number on the original box.
I found a 12 digit number that's not affected.
The number is totally different from the one with 10 digits on my camera.
I'll call them again to sort this out. The camera is for my son.
I do not want to see him allergic.
matthias jurisch
matthias jurisch Contributing Member • Posts: 946
all of my EF-S lenses have turned white...
...love that freebe L look...
Can you verify you got a t4i and not a t2i or t3i with a switched label or serial number on the bottom?
Stakeouttoo
Stakeouttoo Contributing Member • Posts: 856
 Stakeouttoo's gear list:Stakeouttoo's gear list
Canon EOS 60D Canon EF 400mm f/5.6L USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-300mm f/4-5.6L IS USM +5 more
Mustafa Senior Member • Posts: 1,305
Re: Registering beforehand or not; Re: 650D: Disadvantage of replacing bad rubber gri
Mustafa wrote:
I called one of the two service centres here in the UK yesterday. The man said that units are sent to Germany for repair. But when I asked how long that will take, he said he didn't know as I was the first case they'd had!
I'll take it in this coming week and keep you posted.
I took it in last Monday (13th) and it has come back today (21st). It is the same body I took in, not a new replacement. The parts replaced are as follows (sic):
TAPE, DOUBLE SIDE
COVER ASS'Y, FRONT RUBBER
TAPE, DOUBLE SIDE (GRIP)
COVER, GRIP HOLDING
The repair is imperceptible, and I'm happy. I've even entered the survey prize competition that was included!
sverts New Member • Posts: 3
Hi,
Has anyone else managed to get the grips replaced within Brussels, or withing Europe?
I want to get mine replaced as well, but I tend to use my camera often and I wanted to see on average how long it takes for the replacement.
Thanks and good luck to everyone with this issue.
dbannerz71 Junior Member • Posts: 28
No problems so far...one of the "bad ones"
Bought mine when they first became available. It's part of the first batch from the recalled list of serial numbers. Still absolutely no problems with grips turning white, rash etc. My take is that canon is being overly cautious about the recall. Just thought I'd post this to let others know.
Eric
 dbannerz71's gear list:dbannerz71's gear list
Canon EOS Rebel T4i Canon EF 70-300mm f/4-5.6 IS USM Canon EF-S 18-135mm f/3.5-5.6 IS STM Apple iPad WiFi
For those in Europe, or in Belgium, I just asked how long it will take to have the rubber replaced and they informed me 2 weeks roughly. I might take it in next week to get it over and done with I just hope they do a good job...
Just wanted to share with everyone that the replacement took just under 10 working days, seems to be a good job done, but I don't think anything can compare to factory standard.
recdiy New Member • Posts: 1
Hi, after almost 1 year still affected cameras on the market !
Read more about 650D rebber grips issue
Olga Johnson MOD Forum Pro • Posts: 22,365
Thread is being locked
This issue is handled by Canon as a recall issue.  If a vendor still has a camera that has the bad rubber, you should either have the vendor replace it, or have Canon fix the problem.
Olga
 Olga Johnson's gear list:Olga Johnson's gear list
Canon PowerShot G3 X Canon EOS Rebel T4i Canon EOS M Canon EOS Rebel SL1 Canon EF 15mm f/2.8 Fisheye +17 more
