Voigtlander Heliar 75mm f/1.8
Started Aug 1, 2012 | Discussions
Malcolm Sales Forum Member • Posts: 96
Hi,
I fancy getting the Voigtlander Heliar 75mm f/1.8 for my GX1 (and later OM-D E5).
It seems to be a Leica fit lens, so is a Leica/m43 adaptor readily available?
Or have I missed something?
Malcolm Sales.
 Malcolm Sales's gear list:Malcolm Sales's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica D Summilux Asph 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +4 more
Panasonic Lumix DMC-GX1
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,274
Re: Voigtlander Heliar 75mm f/1.8
Yes.
http://www.amazon.com/Fotodiox-Adapter-Olympus-Panasonic-Cameras/dp/B002RJFD7C
...Bob, NYC
http://www.bobtullis.com
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +16 more
Malcolm Sales OP Forum Member • Posts: 96
Many thanks Bob. Just what I needed to know
Malcolm Sales.
James Pilcher Veteran Member • Posts: 8,465
I've used the Heliar
Hi,
A friend let me try his Heliar 75mm f/1.8 with M adapter on my E-PL3 for a week. I used it quite a bit. My impressions:
  • Sharp from f/2.8 onward
  • Has "character" at f/1.8. That means the images are not perfect, but acceptable.
  • It is a front-heavy lens on an E-PL3. An OMD with grip will probably negate that.
  • I find manual focus with my E-PL3 annoying without a tripod when shooting at the 75mm magnification. I determined that the Heliar is a tripod-only lens for me. Again, the OMD with grip might solve that problem.
  • I'm thrilled that Olympus has decided to create its own version. With AF, and sharp results at f/1.8, it will be a much better fit for me.
Jim Pilcher
Bonita Springs, Florida, USA
 James Pilcher's gear list:James Pilcher's gear list
Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 Fujifilm X70 Olympus PEN-F +7 more
MAubrey
MAubrey Senior Member • Posts: 1,598
Considering that they're about the same price, I'm wondering why you're looking at the Voigtlander rather than the new Olympus.
Is there a particular reason?
Alternatively, Voigtlander also has a smaller 75mm f/2.5, too.
--Mike
 MAubrey's gear list:MAubrey's gear list
Olympus OM-D E-M5 Sony Alpha 7 Voigtlander 35mm F1.2 Nokton Olympus M.Zuiko Digital ED 75mm F1.8 +2 more
Thanks James & Mike for your comments.
Reading reviews I'd got the impression that the Voigtlander was a good lens and in the UK at least is almost half the price of the Oly model.
I shall now re-consider my options and may instead go for the 75~300 instead as it's a similar price to the Voigtlander.
I at the research stage before selling all my Nikon kit and getting an E-5.
Malcolm Sales.
El P Stern Junior Member • Posts: 35
I have the 75mm Hellar 1.8 and the 75mm 2.5 Voigtlander lenses. Get the Olympus when it is available. Based on all the reviews it is one heck of a lens. The only "mirrorless camera" I can focus manually on with a degree of accuracey is the Ricoh GXR because of its focus peaking. Olympus and Panasonic do not have that.
As for the 75mm being 150mm on the Olympus EM5 hand holding can get a little hard as far as targeting. I use it on a tripod. Of course remember you will also need the micro 4/3 to Leica M adapter.
El
Www.blueridgeworkshops.com
Adventsam Veteran Member • Posts: 4,983
Not sure about peaking, I had it on a nex5n and found it a bit of a PITA as it obscures the actual detail of the image you are trying to focus on? The oly evf is very fine and sharp, and with the magnification options seems unlikely you'll be unable to MF?
Thanks everybody for your comments.
The Voigtlander is now off my consideration list.
Malcolm Sales.
