RX 100 Grip, Richards Vs Flipbac
Started Jul 30, 2012 | Discussions
Nikguy Regular Member • Posts: 191
Has anyone compared the Filbac G2 to the Richard Franiec grip on the RX100. I love the camera and the overall feel is good. I did notice my finger touches the wheel which has small teeth which I feel. Not a big issues but I would like a grip that would help move my finger away and add to holding.
In the pictures the Richard F. grip looks better for that purpose. Maybe he can give me his assessment.
 Nikguy's gear list:Nikguy's gear list
Nikon Coolpix P7700 Nikon Coolpix S9100 Sony Cyber-shot DSC-TX7 Sony Cyber-shot DSC-RX10 II Sony Cyber-shot DSC-RX100 IV +3 more
Panasonic Lumix DMC-G2 Sony RX100
Jarola Regular Member • Posts: 329
Re: RX 100 Grip, Richards Vs Flipbac
I have the flipbac g2 on my RX100. I am thinking about ripping it off as my fingers keep turning the mode wheel around the lens and changing my settings. I actually have the grip hanging off the camera a bit above the curve on the left side. Richards grip looks like a much better fit.
Nikguy OP Regular Member • Posts: 191
Thanks! I thought that maybe the case. My finger hits it now I don't want to move it closer. I have found out how to hold it without hitting the ring but would rather have it move into a position as I grab it that puts it a little away from the ring
I am considering buying the sony case for the RX which will improve the grip, but I also just discovered the faux leather stick on grip.
Meganrogers Regular Member • Posts: 250
None of the Flipbaks have enough clearance between the hump and the lens. They look nice but you won't be able to fit your fingertips between the lens and grip unless you do some trimming to reposition. The franic grip is a custom fit but the surface is smooth an less "grippy" than rubber. Other options are "egrip" which works well without adding a hump on the front or "Sugru" which will allow you to custom mold the shape you want. If you use Sugru, mask around the area you want with tape which you can remove after the silicone is hard. The Sugru hardens smooth and somewhat slippery but if you have the impression of a couple finger or concave shape then it will work well.
http://www.ebay.com/itm/PROTECTIVE-EGRIP-STICKER-FOR-CELL-PHONE-REMOTE-GPS-CAMERA-MP3-PLAYER-PDA-BLACK-/350496564395?pt=PDA_Accessories&hash=item519b3924ab
http://www.ebay.com/itm/New-SUGRU-3-pk-sampler-HOT-PRODUCT-Make-BUMPERS-Fix-CABLES-/251117214914?pt=PDA_Accessories&hash=item3a77c09cc2
Liz Z.
Liz Z. Senior Member • Posts: 1,267
I have used Sugru for other things. It's very useful, but it seems really hard to get it smooth enough to look anything other than jerry-rigged. That might be fine for a hammer handle, but I would hate to have a lumpy piece of black putty on my beautiful RX-100!
Meganrogers wrote:
The Sugru hardens smooth and somewhat slippery but if you have the impression of a > couple finger or concave shape then it will work well.
Liz
 Liz Z.'s gear list:Liz Z.'s gear list
Fujifilm FinePix F31fd Sony RX100 Adobe Photoshop CS6 +1 more
ericwestpheling Forum Member • Posts: 57
I have the flipbac g1 and it fits nicely, you do end up with your fingers against the wheel, but ive never inadvertently moved it, and I rarely use the wheel anyway.
Thanks to all for the tips I like the neetness of Richards grip and want my rx100 to look and feel like what is added keeps it looking good. I think I will try the Richard F grip. Again thanks for your input I will look into all of the suggestions
KwhyChang Veteran Member • Posts: 3,525
I'll bet Richard's grip is better, after all his are custom designed, but I got the Flipbac. I like the Flipbac G1 for the RX100 and put it right on the edge of the curve so there is more room next to the lens. Works great for me. An added bonus is that the length of the Flipbac is exactly the same as from the bottom of the RX100 to the line that goes across the camera, so it looks like it was made to fit. The Flipbac is only $10 here in the states, which is about half the price of the other.
Dave
 KwhyChang's gear list:KwhyChang's gear list
Nikon Coolpix P900 Sony Cyber-shot DSC-RX100 III Sony Alpha 7
Evadremlu
Evadremlu Regular Member • Posts: 136
My strip of Velcro still works extremely well for a grip:
See:
http://forums.dpreview.com/forums/read.asp?forum=1009&message=42119380
In reality its almost invisible on the camera only this flash shot makes it visible.
 Evadremlu's gear list:Evadremlu's gear list
Canon PowerShot SX210 IS Sony RX100 Sony Cyber-shot DSC-HX50V
Do you have a picture of g1 showing it on your rx100?
Thanks for the picture and your idea. Velcro is my best friend but not in this case
I don't like the look but you did come up with a solution that works... And that deserves a congrats
John McCormack Veteran Member • Posts: 5,033
Re: RX 100 Grip, Richards Vs Flipbac - Egrips Also
maestro55 New Member • Posts: 9
I added the flip bac G3. It fits perfectly below the 'belt' and above the battery door. I placed the edge just where the flat front face of the camera curves to the side. This leaves a tight space between grip and lens control ring, but it's just enough to 'hook' my middle finger yet not accidentally turn the ring after hundreds of shots. The rubber texture is not identical but feels very similar to the thumb rest on the back. The added bulk does not seem to have any negatives on my pocket ability. Not as visully elefagant as Franiec's sculptured beauty, but for $15 and a minute to apply its a darn easy way to dramatically improve the grip on this superb camera.
Liz Z.
And here they are on my camera:
John McCormack wrote:
Someone mentioned Egrips in another thread. They look good. Here's a link:
Liz
Isfandiyar New Member • Posts: 1
I have the Franiec grip and after I installed it I took a video. I must say it felt so natural I forgot that it was there - in my view that's a great achievement as it felt completely natural in hand. No finger touching the lens ring. No regrets.
 Isfandiyar's gear list:Isfandiyar's gear list
Sony RX100 Canon EOS 500D Canon EF 50mm f/1.8 II
Peter v.d Werf Contributing Member • Posts: 688
Personally that looks like a small piece of tape, and I find it an ugly addition to this camera. If you don't want to attach a separate grip, I'd look at tis one:
http://forums.dpreview.com/forums/readflat.asp?forum=1009&thread=42241400
That looks beautiful and enhances a bit of grip.
I received Richard Franiec's grip for my RX100 a few days ago and it's a perfect fit, just like the ones for the S90 and S95 were.
Liz Z.
It is kind of tacky, I agree. I may well get Richard's grip, but in the mean time this is functional, and actually far less noticeable in real life than in the image. The other add-on only covers the front of the camera, so to me it looks a bit like a façade that is trying to make the camera look like a Leica.
Liz
david seto New Member • Posts: 15
I'm intending to buy a RX100 and hope someone produces a grip similar to those available for Nikon J1 and Leica compact digital cameras. Can anyone confirm these do or do not fit the RX ?
Cheers David.
Walt Bilofsky
Walt Bilofsky Contributing Member • Posts: 594
Custom Leatherette
That's the one I got. $17 and took four days to arrive from Japan.
I just used the bottom panels but there are strips for the top also. Holding the camera with middle finger under the lens gives all the support I need, but the extra grip makes it feel secure.
I haven't noticed a problem with accidentally turning the lens ring. I've got it set for exposure compensation, and it takes more than a little movement to invoke the function.
 Walt Bilofsky's gear list:Walt Bilofsky's gear list
Panasonic Lumix DMC-ZS3 Sony Cyber-shot DSC-RX100 IV
