problems with my EVF...any suggestions?
Started Jul 20, 2012 | Discussions
wpdoyle New Member • Posts: 4
Hi folks. I have been a happy X100 user for the past two weeks, but I now have a problem. Something seems to be amiss with the EVF, which had been brilliant. This afternoon, when I turned the camera on and switched over to EVF, the EVF image was probably 60-70% transparent.
This holds for both taking photos, and reviewing them in the viewfinder. It seems to be much worse in brighter light outside, less so indoors. Again, it had not been a problem at all until now.
Does anyone have any suggestions for what I could do, short of sending it in for a factory repair?
Any help is extremely appreciated!
Thanks so much.
Bill
 wpdoyle's gear list:wpdoyle's gear list
Fujifilm X100T Canon EOS 7D Mark II Canon EF 50mm f/1.8 II Canon EF 70-200mm f/2.8L IS II USM
Keith Jefferies Regular Member • Posts: 154
Re: problems with my EVF...any suggestions?
Bill, here is a suggestion.
When you switch to EVF a shutter moves into place in the OVF to block off light
from entering the EVF. You may care to check this is OK.
regards
 Keith Jefferies's gear list:Keith Jefferies's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-LX100 Panasonic Lumix DMC-ZS50 Fujifilm X-Pro1 Fujifilm XF 18mm F2 R +1 more
Felipe Rodríguez
Felipe Rodríguez Veteran Member • Posts: 3,015
Hi!
I have the same problem, and it is quite annoying under bright sunlight. Any idea/suggestion?
http://www.felipe-rodriguez.com
Bokeh
Dadme un mundo sin contornos,
Un espacio feliz que ignore los perfiles.
Concededme, sí, la dicha redonda
De flotar sin conciencia en el fondo
Desenfocado de mis fotografías.
Give me a world with no edges,
A happy space knowing nothing about outlines.
Grant me, please, the round joy
Of thoughtlessly floating on the blurred
Background of my photographs.
 Felipe Rodríguez's gear list:Felipe Rodríguez's gear list
Fujifilm FinePix X100 Nikon D4 Nikon D810 Nikon AF-S Nikkor 50mm f/1.4G Nikon AF Nikkor 135mm f/2D DC +13 more
Jose V. Sumaquial, MD Regular Member • Posts: 181
It sounds to me like the shutter Keith had spoken of is not deploying. I had a problem with my X100 where it would partially deploy. You could see half of the screen in the viewfinder, looking at it from the front of the camera.
I sent it back to Fuji and they fixed it for me.
Joe
http://docjoe.smugmug.com
jiri bernovsky
jiri bernovsky Regular Member • Posts: 125
I had the same problem. I dropped the camera and since that ugly moment the curtain got stuck and would not close anymore. Until the time I dropped it again. Now its working perfectly (for half a year or so).
I do not suggest to throw your camera on the ground.
In my case it worked. Of course I did not do it intentionally:).
J.
 jiri bernovsky's gear list:jiri bernovsky's gear list
Fujifilm FinePix X100 Canon EOS 7D Fujifilm X-T1 Fujifilm X-Pro2 Canon EF 17-40mm f/4.0L USM +4 more
Felipe Rodríguez
Hi Jose
Many thanks for your reply! I can also see half of the screen or so... The problem is that the warranty is expired... Any guess about how much would the repair be?
Joe
Bokeh
Felipe Rodríguez
Thanks for the reply!
So it seems I'll have to play some basket with the X100, won't I?
J.
Bokeh
57even Senior Member • Posts: 9,476
Just try flipping from OVF to EVF a few times - seems to cure it on the Xp1.
J.
Bokeh
 57even's gear list:57even's gear list
Fujifilm X-Pro2
Felipe Rodríguez
Thanks for the tip!
Right now the camera is stuck with the EVF and refuses to flip...
J.
Bokeh
Bokeh
BurpeesAreHard Contributing Member • Posts: 521
Thanks for the tip!
Make sure the camera is not in macro mode. It won't let you use the OVF in macro mode.
(unknown member) Forum Pro • Posts: 13,144
Thanks for the tip!
Very good suggestion.
Help Fight Disease! http://folding.stanford.edu/English/HomePage
Please join and be part of the solution! Lives can be saved.
I fold under the name RattyM. > 90 Work units completed, BILLIONS of calculations done, all from a Dell laptop. Everyone can be part of the solution. You just have to get started.
 rattymouse's gear list:rattymouse's gear list
Fujifilm FinePix F10 Zoom Fujifilm FinePix F20 Zoom Fujifilm FinePix F70EXR Fujifilm FinePix X100 Fujifilm X10 +9 more
Felipe Rodríguez
Nope...
I mean that flipping from EVF to OVF didn't wrok at all...
Bokeh
Nope...
That is precisely what happens in macro mode. So you're saying it acted like it was in macro mode even though you confirmed it wasn't in macro mode I guess.
Felipe Rodríguez
Sorry! What I meant is that I was able to switch to the EVF once I set macro mode off, but flipping from the EFV to the OVF didn't fix the problem with the EFV...
Nope...
Bokeh
