Monitor Calibration question
Started Jul 19, 2012 | Discussions
digitalshooter
digitalshooter Forum Pro • Posts: 19,604
OK as I understand it, if you have a dark print and your monitor pic looks GREAT your monitor is too bright, corrrect?
So here is my question: What do you do if your monitor is set to 0 brightness?
Thanks,
Digitalshooter
PS: all posts are just my opinion!
 digitalshooter's gear list:digitalshooter's gear list
Sony Alpha DSLR-A700 Canon Pixma Pro9000 Mark II
Dennis Lathem Veteran Member • Posts: 3,705
Re: Monitor Calibration question
You answered you own question in the title of your post. You need to calibrate your monitor and use a printer profile to ensure your prints look like the monitor you have edited the photo on. Color management is not really difficult and will save you lots of time.
CDL
http://photobama.com
See Profile for gear stuff (including stuff I have beta tested)
http://www.photobama.com/
http://www.photobama.zenfolio.com
digitalshooter
digitalshooter OP Forum Pro • Posts: 19,604
Yeah I guess I did, currently my spyder 3 pro is reaking
havoc on my systems, cant get it to calibrate correctly. Working with them on this but I think a new calibrating system may be in order.
I quess I was looking for some reassurance that calibration would resolve, since calibration is touchy.
Thanks,
Digitalshooter
digitalshooter
Thanks (nt)
Thanks,
Digitalshooter
Bob Collette Veteran Member • Posts: 3,830
If the print looks good, as does the monitor, however the monitor is too bright, you need to reduce the monitor luminance (as you noted). If the Brightness control is already at zero, try reducing the Contrast control setting. The Contrast control has a large effect on the luminance.
 Bob Collette's gear list:Bob Collette's gear list
Canon PowerShot G3 +4 more
digitalshooter
Thanks will check that also (nt)
Thanks,
Digitalshooter
Re: Yeah I guess I did, currently my spyder 3 pro is reaking
Sorry, I could not tell from your post that you had already attempted to use a hardware calibration system. I have had two different SYPDER devices over the last 5 years. The both worked well. Good luck on getting everything straightened out. I know how madding it can be.
CDL
NewsyL
NewsyL Veteran Member • Posts: 5,676
Increase the ambient lighting a bit.
Btw... what monitor do you have?
Supr X
Supr X Veteran Member • Posts: 4,956
-what I would suggest . . .
Yes, what are you working on?
David~
WSSA Member #90
. . . shoot like there's no film in the thing!
digitalshooter
monitor
How will increasing the ambient help?
Viewsonic VP950B
Thanks,
Digitalshooter
Pictus
Pictus Veteran Member • Posts: 5,570
Re: monitor
To view a print as you can see in the previous links, is much better to just light the print and not the whole area, look at the Colour Confidence GrafiLite http://www.dpreview.com/articles/0967807691/buyers-guide-10-essential-color-management-devices/2
NewsyL
Re: monitor
Viewsonic VP950B
re: Viewsonic VP950B
I was hoping it would be something more recent with test results from a review site that documents the back light brightness.
What I do know is that it uses a 19" "TN" tft LCD panel which offers a simulated 8bit color depth - it's actually a 6bit panel that uses an older version of Frame Rate Control (FRC) to simulate a color depth in excess of 16.2 million colors. The stated maximum brightness is 280 cd/m2 which is far far too bright for image work so like most monitors you need to adjust this into an area most appropriate in balance against the ambient lighting of the room you edit in.
A number of recently tested budget class monitors were shown to be unable to adjust their brightness below 130 cd/m2 of white luminance which is still too high for most home office dens/offices where people edit in the evening (i.e. no sunlight streaming in through windows) using one or two 800 lumen bulbs to light a room. Typically, most people will want a level between 100 and 120 cd/m2 though for a very dark room, maybe as low as 80 cd/m2.
The room you edit images in should have controlled lighting - i.e. no open windows that allow random light in from outside. Blinds are essential so that the ambient light in the room remains about the same as per when you calibrate your monitor.
You can use extra lamps to bring the ambient light level up to help prevent dark prints because what you are doing is addressing a perceptual weakness of the human eye/brain.
re: raising ambient lighting
You're likely aware of how the human eye can be fooled into thinking that certain shades of color or gray are different even though they are the same, depending on the shade placed alongside the swatch that you're examining. So it is with the brightness of your monitor in relation to the room around it.
Think of your back lit monitor as being something like a 19" diagonal spotlight shining in your eyes. If the room around the monitor is very dark, the monitor will appear brighter to your eye and any images on it will be perceived to be too bright so that they require that their levels be adjusted lower - hence when printed, you get dark prints.
If you raise the ambient light level, it will seem that the monitor is not as bright as before even though you have not touched the monitor's controls. If you raise the ambient room lighting too much, the monitor will appear dark in relation to the room lighting and you may actually be tempted to raise the levels of the image. If printed these images would appear too light.
I know with the Spyder 4 Pro that it reports the white luminance of the monitor at one point in the "advanced" mode of calibration. I can't recall if this is also shown in the Spyder 3 Pro's software.
What you can do is the following as a rough estimate of what the "balanced" ambient light level is for your monitor.
Eyeball Technique
A rough method of setting brightness is to grab a sheaf of white printer paper (several pages thick) and hold it up next to your monitor while it is displaying a white screen (full screen Notepad works well) and while the room has its' typical lighting used while you edit. If the paper looks brighter than your monitor, then your monitor is too dark. If the paper is darker, then the monitor is too bright or perhaps you need to increase the ambient lighting of the room. Imho, it is less than ideal to edit in a near pitch black room.
Most LCD monitors have a native color temperature somewhere near 6500K in order to have whites appear like they would in natural sunlight. Most people still use incandescent or CFL bulbs with a color temperature near 2800K for their room lighting.
Under this traditional lighting the reflected room light off the paper will, in comparison to the monitor screen, appear more yellow (warmer) and this may make you think it is a little darker. You may want to buy some 6000 to 6500K compact fluorescent bulbs, of equal lumen output, for the lighting in your room and use them while attempting this paper method. If these are too blue (cool) for day to day use in your editing room, 5000K bulbs may be a workable compromise.
Try this and let us know what your initial results are.
PS... dark prints can also be the result of a mismatch with printer ICC profiles and paper and/or how the printer is set up to use these - we sometimes see the term "double profiling" use in reference to this.
bronxbombers Forum Pro • Posts: 18,226
Re: monitor
makes the prints look less dark, shadow details that were hard to see are suddenly easy to see
if no amount of ambient light increase makes things look right then either your monitor's tone response is not properly calibrated or the programs being used are not using the profile or not using it properly or the printer's profile is not so good
Pictus
**Update** Monitor Calibration question
Some interesting links: *Update*
Practical guidelines and references for digital photographers
http://www.fredmiranda.com/forum/WGuidelines.pdf
Everything you thought you wanted to know about Color Gamut and RGB Working Spaces
High resolution: http://digitaldog.net/files/ColorGamut.mov
Low Res (YouTube): http://www.youtube.com/watch?v=n0bxSD-Xx-Q
COLOR MANAGEMENT & PRINTING
http://www.cambridgeincolour.com/color-management-printing.htm
Soft Proofing with Lightroom 4
http://digitaldog.net/files/LR4_softproof.mov
http://digitaldog.net/files/LR4_softproof2.mov
Using Printer Profiles with Digital Labs
http://www.drycreekphoto.com/icc/using_printer_profiles.htm
Why are my prints too dark?
http://www.luminous-landscape.com/tutorials/why_are_my_prints_too_dark.shtml
DPI, PPI, printer resolution
http://www.l-camera-forum.com/leica-forum/digital-post-processing-forum/115989-digital-printing-pixels-resolution-resampling.html
http://www.rags-int-inc.com/PhotoTechStuff/Epson2200/
http://www.digitalphotopro.com/technique/workflow/the-right-resolution.html
http://www.luminous-landscape.com/forum/index.php?topic=54798.msg446993#msg446993
"here's a simpler guideline for Epson printers; if your image's native size is less than 360PPI, set the resolution in LR to 360 for the output resolution, if the image's native size is above 360 but less than 720PPI, set the resolution to 720PPI in LR.
For Canon and HP the numbers are 300/600PPI..."
Beyond Adobe RGB
http://www.naturephotographers.net/articles1203/mh1203-1.html
Monitor Luminance Sensitivity
http://www.drycreekphoto.com/Learn/Calibration/monitor_sensitivity.html
http://www.photofriday.com/calibrate.php
Monitor sharpness test
http://www.lagom.nl/lcd-test/sharpness.php
Lighting Your Workspace
http://www.creativepro.com/article/the-darkroom-makes-a-comeback
http://www.color-image.com/2012/02/monitor-calibration-d65-white-point-soft-proofing/
Display Calibration Hardware Capabilities
http://www.drycreekphoto.com/Learn/Calibration/MonitorCalibrationHardware.html
Spyder4 vs i1Display Pro
http://www.gamutprints.com/2012/04/i1display-pro-vs-spyder-4-and-spyder-4-quick-review/
http://nativedigital.co.uk/site/2013/04/i1display-pro-vs-spyder4elite/
skyglider Veteran Member • Posts: 4,440
Assuming that your dark print was printed on your printer, maybe have prints of the same image made at 2 commercial print labs. Compare the prints to the print from your printer. Be sure that the digital image file that is sent to the commercial printer(s) is in the sRGB format since that's what their printers are set up for. You can verify the image format that the print lab is set up for by asking the print lab's technician.
If all prints are equally dark, then the problem will be in your computer/monitor. If the commercial prints are bright, then check your printer's profile.
Just a suggested logical starting point,
Sky
