Competition for X-S1 ?
Started Jul 17, 2012 | Discussions
SHood
Senior MemberPosts: 3,755Gear list
Jul 17, 2012
Looks like Panasonic decide to go with a fast constant f2.8 lens instead of a larger sensor. Announcement coming in 6 hours.
 SHood's gear list:SHood's gear list
Sony RX100 Panasonic Lumix DMC-GH3 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
Fujifilm X-S1
labe
labe MOD
Senior MemberPosts: 2,568Gear list
Re: Competition for X-S1 ?
In reply to SHood, Jul 17, 2012
But still no manual zoom. Manual zoom and good colour are why fuji are still selling bridge cameras even when the IQ is much less.
new to technology,always learning
 labe's gear list:labe's gear list
Fujifilm FinePix IS-1 Panasonic Lumix DMC-FZ200 Sony Cyber-shot DSC-RX10 Sony Alpha NEX-3 Olympus OM-D E-M5 +2 more
isb_deep
Regular MemberPosts: 163
In reply to SHood, Jul 18, 2012
If they did this, it is incredible! However, I believe it is a 28-600, 2.8 to 4.5 lens, as can be seen from the inscription on front of the lens element. Even then, 4.5 at 600 is not bad at all.
unknown member
(unknown member)
In reply to isb_deep, Jul 18, 2012
No, the aperture is constant at f/2.8. What you are seeing there is the low end of the zoom range, 4.5 mm.
http://fujifilmimages.aminus3.com/
 rattymouse's gear list:rattymouse's gear list
Fujifilm FinePix F10 Zoom Fujifilm FinePix F20 Zoom Fujifilm FinePix F70EXR Fujifilm FinePix X100 Fujifilm X10 +9 more
Larry Winters
Veteran MemberPosts: 4,825
In reply to labe, Jul 18, 2012
And don't forget the better viewfinders.
I won't bother with all the other negatives of the Fuji's besides the resolution.
lw
isb_deep
In reply to rattymouse, Jul 18, 2012
well, I'll be... this is good!
Larry Winters
How soon we forgot the FZ3
with a constant f/2.8 at 420mm from 2004. Yep, eight years ago.
http://www.dpreview.com/reviews/panasonicfz3/
Of course the FZ200 will be miles ahead in all areas but the constant f/2.8 in a super zoom really isn't all that new.
lw
Larry Winters
I'm probably in the minority
but I'm hoping for a 18mp or so X-S2. Enough increase to add a noticeable acuity improvement. There is no doubt the X-S1 has MUCH to offer but the current lack of visible detail is the deal breaker for me.
Also, I won't be interested in the new FZ200. But, if Panny can maintain the speed, accuracy and IQ of the FZ150 I'm sure it will be a big seller.
lw
Larry Winters
And the FZ20 at f/2.8 432mm...
In reply to Larry Winters, Jul 18, 2012
unknown member
(unknown member)
Re: I'm probably in the minority
I agree. The 6mp of the X-S1 is just embarrassing. Shooting the EXR sensors at full rez offers very little if any improvement.
jcmarfilph
Senior MemberPosts: 7,329Gear list
Re: Competition for HS30?
That is good and will certainly be an advantage in low-light scenes.
HS30 can only do F/5.0 at 600mm but still 5x faster to get to 600mm+ FL than FZ200.
Still fast lens physically .
-=[ Joms ]=-
 jcmarfilph's gear list:jcmarfilph's gear list
Fujifilm FinePix HS50 EXR +1 more
Larry Winters
In reply to jcmarfilph, Jul 18, 2012
Joms:
Sure the manual zoom is much preferrable but wouldn't it be nice to supplant those noisy ISO 1600 bird images with mostly noise free ISO 400 shots?
lw
Rachotilko
Contributing MemberPosts: 529
Guys, the problem is LENS !!! LENS !!!
I read some review where they measured the resolution. The result was much higher resolution obtained from X10 than X-S1. And as you surely know, the sensor is the same .
Moreover, my observation tells me the resolution drops dramatically with the subject distance. That's hardly a sensor problem.
The sensor resolution of 6mp would be acceptable, had it been sharp & information rich 6mp. Unfortunatelly, that is not the case for X-S1.
unknown member
(unknown member)
In reply to Rachotilko, Jul 18, 2012
We know. DROOPAGE!!! DROOPAGE!!!
DROOPAGE!!
Rachotilko
Sorry for the capitals ! But I wanted to make sure everybody understands the increased sensor resolution would not result in increased amount of information contained in the output.
Wrt DROOOOPAGE : I'm not sure about it ! Because:
  • the output is lacking resolution (despite extensive sharpening halos) even with zoom only half-extended (ie. in the middle of the focal range). The droopage is only significant with zoom fully extended.
  • did the shimming made the X-S1 output equivalent to X10's ?
Larry Winters
The HS10/20/30 all have the same lens but when sensor resolution was increased for the HS20/30 the amount of visible detail or acuity INCREASED which is what I'm talking about. And its obvious, so I firmly believe the acuity of a 18mp X-S2 sensor would be obvious as well. I don't necessarily care about how much info is contained in the file output, only what my eye can ascertain in the image.
lw
Rachotilko
Larry, to get good resolution, both sensor and the lens have to be able to resolve the detail. When one of them is lacking resolution, the detail is lost, and the improved resolution of the other one would not redeem the situation.
Furthermore. The 'X10 argument' shows, that the sensor is not the guilty one of the lack of resolution in the X-S1's output. X10's provides very detailed landscape shots, X-S1 does not. With the same sensor.
Eigenmeat
Regular MemberPosts: 433Gear list
Well the X10 might be better than the XS-1, but it's still firmly in the crappy regime in terms of resolution. I mean literally ANY current generation digi cam will out resolve it, even the Iphone.
http://www.flickr.com/photos/25457298@N04/sets/
Larry Winters
Well of course they work together but increasing megapixels within the same physical size sensor, changes the pixel pitch and therefore can increase acuity.
Of course a zoom lens with less range will likely resolve more, but that doesn't mean the X-S1 lens has reached its visible limits. It will never resolve the same as the X10 lens but the acuity can be improved with more and subsequently SMALLER megapixels. Provided the S/N ratio remains adequate that is.
lw
Rachotilko
In reply to Eigenmeat, Jul 18, 2012
1, In terms of resolution X10 is yielding results substantially better than X-S1. And I find X10 resolution perfectly acceptable for me.
2, I don't care if X10is outresolved by any current digicam, as X10 will demolish almost all of them in lowlight & DR performance.
