Two shots with DP2M (and the same retaken with DP2)
Started Jul 14, 2012 | Discussions
hanenashi New Member • Posts: 1
...proving actually nothing. (What else expect from three minutes at Yodobashi...)
DP2M:
(everything left on auto there, nice color casts...)
DP2:
(developed on auto and tweaked a bit to taste)
X3F files here: http://www.sendspace.com/file/4taraz
DP2M actually feels quite (and having no grip it slips from hold really nicely when held only with right hand). I realised how my DP2 is small and pocketable compared to it. For now I'm staying with my DP2... (but mainly because getting DP2M means getting new computer first because those huge X3F files are too much for my MacBook, at least with current Sigma PhotoPro).
Sigma DP2
gbainbridge Senior Member • Posts: 2,762
Re: Two shots with DP2M (and the same retaken with DP2)
Hmmm. I hope that was a pre-release copy as I would hate to pay for the DP2M and get that green vignetting.
At that size the older DP2 looks better,
Thanks,
Gary.
digi2ap Contributing Member • Posts: 539
And the magenta strip lights are interesting!
http://digi2ap.wordpress.com/
 digi2ap's gear list:digi2ap's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma dp0 Quattro Sigma SD1 Merrill
carlos roncatti
carlos roncatti Senior Member • Posts: 2,662
any chance
that you might talk about AF, buffer shot to shot times and etc...thanks a lot...
To understand photography, you must understand that the experience must be much more important than the result ....
Carlos Roncatti Bomfim
http://weweh.com/
because men and women are different and we humans are the same.
Joerg V Contributing Member • Posts: 609
Hello hanenashi-san,
arigatou gazaimasou! bows
The resolution of the DP2m looks very good, I guess the color casts and pink highlights are related to a non-DP2m-ready version of SPP.
Joerg
 Joerg V's gear list:Joerg V's gear list
Sigma DP1 Nikon D800 Nikon AF-S Nikkor 50mm f/1.8G Sigma 35mm F1.4 DG HSM Art Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +3 more
PrebenR Senior Member • Posts: 3,328
Ouch
RAW files? seems to be the same bug as we had with the SD15 firmware before it was fixed.
Sharpness is really much better than the DP2 though
AF takes away the Zen in photography
Photos: http://www.flickr.com/photos/prebenr/
M42 on Foveon: http://www.flickr.com/groups/m42-foveon/
petr marek Regular Member • Posts: 179
Re: SPP fails
DPFirst of all, latest SPP5.2.1 fails with DP2M x3f. Preview is fine, even without green cast and purple highlights, than loaded for processing - image is destroyed.
Lightroom support for x3f Merrill is crucial!
Secondly, DP2 sensor is "stronger", colors of Merril sensor are weak, color palette is not accurate. Under this conditions in this test at least.
Johan Borg Senior Member • Posts: 2,323
Re: SPP fails
DP2M requires SPP 5.3.1 which it ships with.
Great to have some X3F to play with when Sigma makes 5.3.1 available for download, though!
EDIT: Regarding colors: DP2M has a full stop less exposure here, it could have used ISO 100 and keep the shutter speed of the DP2 at ISO 200.
ulfie Veteran Member • Posts: 3,299
Re: SPP fails
Something is very weird--the magenta neon lights with the DP2M. Others hues in this image look OK, good even but those neons lights are not correct. What's up with this highly-anticipated DP2M?!
Re: SPP fails
Nothing. Like every new Sigma camera it depends on a new version of SPP. Use an old version and this is what you get.
Re: SPP fails
Nothing? Duh ... spend almost US $1,000 and get weird magenta colored (white) neon lights?
Re: SPP fails
Spend $1,000 and insist on using a RAW converter not supporting the camera will give you weird colors, yes. That's not a problem with the camera, though, since it ships with a new converter.
HBowman
HBowman Senior Member • Posts: 1,213
Before pointing an eventual "problem" on a camera, ppl should try to point the real problem of their manipulation of the camera and using the proper raw converter...
So, it should be mandatory to ignore forum "tests" because they are often (99.99%) biased, and often, ppl behind the camera not skilled enough to judge a complex tech (that sound crude but it is true, sorry).
Here is some links of actual user of this camera. This is the reality with good and less good photographers. But at least they do not speak BS, they shoot, and the photos speak for themselves about the ultimate and real quality of this little camera.
http://photo.yodobashi.com/sigma/imp/dp2m.html
http://news.mapcamera.com/KASYAPA.php?itemid=15857
http://www.flickr.com/groups/sigmadpmerrill/
http://www.flickr.com/photos/ikytrkr/
... and so on ...
Gesture Veteran Member • Posts: 3,980
Thanks. Some stunning photography on that mapcamera page.
Re: SPP fails
DP2 was set to Vivid in the camera, DP2M to Neutral, so the preview JPEGs will be rather different.
More interesting is the noise in the two ISO 800 images (again out of camera preview JPEGs). The DP2 gives far cleaner results out of the camera where the DP2M is limited by horizontal magenta-green banding, presumably from AFE (since all AFE models suffer from this). Maybe the DP2M can catch up in RAW? We'll see...
Re: SPP fails
Let's see now that SPP 5.3.1 is available for download from Sigma:
Standard Color mode, medium (0.5 and 0.5) noise reduction, Auto White Balance. Still a tiny bit of banding left in the lower left, but otherwise little to complain about If I tried to maximize quality I would probably bump the Chroma NR another step.
