Tamron "Legacy" SP 90mm f/2.5 Macro Is A Winner!
Started Jul 12, 2012 | Discussions
fotowbert
Senior MemberPosts: 1,910Gear list
Tamron 01F aperture readout
In reply to declan79, Aug 18, 2013
I believe you are referring to the two aperture readouts, the one on the lens and the other on the 01F.
The Tamron 01F aperture readout shows the effective aperture when using the tele converter with its 2 stop light loss.  When the lens aperture set at f/4 the converter's aperture readout indicates f/8.
The Tamron extension tube 18F for the 90mm f/2.5 adaptall lens does not have its own aperture readout or glass elements.  (I have both the 01F and 18F)
With either of these units TTL exposure metering compensates for the light loss and then you fine tune the exposure based upon the histogram.
  • John
declan79 wrote:
[IMG]http://i6.photobucket.com/albums/y205/Declan_26/20130818_161243_zps03c546c3.jpg[/IMG]
I tried to get some quality macro just before heavy rain, then I figured it out that at this moment I've tried to put it right twice but it seems stay the same... When the aperture is set to 2.5, the 01f combo is on 1stop after (4).
Is it right?
 fotowbert's gear list:fotowbert's gear list
Canon PowerShot A20 Canon PowerShot SD870 IS Fujifilm FinePix F31fd Panasonic Lumix DMC-LZ8 Canon PowerShot S95 +15 more
declan79
Regular MemberPosts: 366Gear list
Re: Tamron 01F aperture readout
In reply to fotowbert, Aug 19, 2013
  • John
Is it right?
Yes JOhn, great detailing explanation so it is normal and yes it giving the 2:1 macro, great combo set
 declan79's gear list:declan79's gear list
Olympus E-3 Olympus OM-D E-M5 Samsung NX300 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II Panasonic Leica D Summilux Asph 25mm F1.4 +6 more
martindesu
Senior MemberPosts: 1,245Gear list
Re: Tamron "Legacy" SP 90mm f/2.5 Macro Is A Winner!
In reply to Bill McClung, Aug 19, 2013
Am I right in thinking it's the "adaptall" mount? If so, I may pick up an adaptor and buy a copy of this lens, as the results look pretty nice indeed!
Is there much difference between the 72B and 52B? Is there any disadvantage in my buying the 1:1?
 martindesu's gear list:martindesu's gear list
Sony RX1 Sony Alpha NEX-C3 Voigtlander 35mm F1.4 Nokton Sony FE 55mm F1.8 +1 more
declan79
In reply to martindesu, Aug 19, 2013
Mine the original Adaptall mount, I believe there's several in the market that has been changed the mount.
The 72b is totally different lens with 52b,never tried before but for the 01f it can be used with several Adaptall lens mount... You can check www.adaptall2.com
martindesu
In reply to declan79, Aug 19, 2013
I'm thinking that the native 1:1 would be the way to go, as I would like the option to easily do close-up macro work. It seems to be plastic too, which is good for weight on NEX.
These lenses appear to be really sharp and have great bokeh, as well.
Rich O
Regular MemberPosts: 385Gear list
The second 01F won't show the effective aperture because its not coupled to the aperture ring like the first 01F.   The first 01F correctly shows f/5 , which is 2x f/2.5.  You'll just have to remember that your shooting at 4x from whatever aperture you select on the lens itself.
 Rich O's gear list:Rich O's gear list
Sony Alpha 7 II Sony FE 28-70mm F3.5-5.6 OSS +12 more
declan79
In reply to Rich O, Sep 1, 2013
Noted, thanks for the explanation so I decided not to sell any
