RX100 - Filter?
Started Jul 11, 2012 | Discussions
nikonp1
Forum MemberPosts: 65
RX100 - Filter?
Jul 11, 2012
Is it possible to mount a CPL on the RX100? Is an adapter needed?
Sony RX100
travelshots_dpr
Regular MemberPosts: 219Gear list
Re: RX100 - Filter?
In reply to nikonp1, Jul 11, 2012
Unfortunately, RX100 has no filter thread, which is the biggest disadvantage of this camera. You either have to handold the filter (no problem on a tripod but difficult in handheld operation of the camera), or buy an adaptor.
I have found the following solutions:
Adaptor mounted on the lens
http://www.lensmateonline.com/store/s90v2.php
Adaptor mounted at the tripod mount. Note that the front diameter of the versions for 43mm filters do have an inner diameter of 41mm, while the diameter of the RX100 front lens segement is about 43mm. The distance from the centre of the tripod mount of RX100 to the front of the lens is about 58mm (ruler held diagonal)
http://www.amazon.de/B-I-G-Filterhalter-f%C3%BCr-Kompaktkameras-Durchmesser/dp/B001S23J4S
http://www.riccos-camera.de/product_info.php/cPath/102_191_296/products_id/4930
http://www.riccos-camera.de/product_info.php/cPath/102_191_296/products_id/3781
http://www.youtube.com/watch?v=QSDQ5EzFhak
 travelshots_dpr's gear list:travelshots_dpr's gear list
Sony RX100 Sony Alpha DSLR-A700 Sony SLT-A77 Sony SLT-A99 Sony DT 18-55mm F3.5-5.6 SAM +15 more
nikonp1
nikonp1 OP
Re: RX100 - Filter?
In reply to travelshots_dpr, Jul 11, 2012
It's a shame that it can't take a filter but definitely not a deal breaker for me.
millsart
Senior MemberPosts: 2,771
Re: RX100 - Filter?
I'm sure Lensmate will have a front filter thread solution like they do for the Canon S series
It could mean gluing a little connector tab for the front of the lens barrel which would add about 1mm of depth to the camera, but for the serious shooter who wants to be able to use filters, it should work well
I plan on getting one if/when they offer one
Heck, I might even glue a filter step up/down ring I file down thin as possible onto there myself LOL
Or for a less permanant solution, I think finding the right size PVC tube with a filter ring glued to the end that just slides over the extended lens would also work well enough. Have to take it on/off but be a bit quicker than the tripod mounted filter holders
DigiDan
Contributing MemberPosts: 575Gear list
Re: RX100 - Filter?
In reply to millsart, Jul 11, 2012
They make a magnetic filter holder that goes on the front and holds filters. Like this one
http://www.bhphotovideo.com/c/product/387314-REG/Cokin_CBA400MM_Magnetic_Filter_Holder_A.html
Danno
 DigiDan's gear list:DigiDan's gear list
Samsung TL500 Panasonic Lumix DMC-LX5 Sony Cyber-shot DSC-HX30V Olympus E-1
travelshots_dpr
Re: RX100 - Filter?
In reply to millsart, Jul 27, 2012
I have inquired at lensmate and they confimed that there will be a filter holder for RX100. Meanwhile, another holder might be available:
http://cheesycam.com/nd-or-cpl-filters-for-sony-rx100/
jscolton
Junior MemberPosts: 33
Re: RX100 - Filter?
In reply to travelshots_dpr, Jul 27, 2012
The cheesycam one doesn't seem to be available yet either.
papabr
New MemberPosts: 4
Re: RX100 - Filter?
In reply to nikonp1, Jul 27, 2012
Here is my very temporary solution using foam and electrical tape. It's not a tight fit so I can rotate this CPL filter. You can't beat the price though, eh!
Amateur Sony Shooter
Veteran MemberPosts: 5,415Gear list
Re: RX100 - Filter?
In reply to papabr, Jul 27, 2012
Very cool idea! What size is the filter?
 Amateur Sony Shooter's gear list:Amateur Sony Shooter's gear list
Sony RX100 Sony a77 II Sony 70-200mm F2.8 G Sigma 10-20mm F4-5.6 EX DC HSM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +6 more
papabr
New MemberPosts: 4
Re: RX100 - Filter?
In reply to Amateur Sony Shooter, Jul 27, 2012
43 mm Tiffen CPL. But only yellow tape can work!
Re: RX100 - Filter?
Thanks for the info. I might give it a try too!
RX100
Junior MemberPosts: 43
Re: RX100 - Filter?
In reply to papabr, Aug 7, 2012
Great idea!
