CF cards vs. SD cards in an SD-to-CF adapter
Started Jul 10, 2012 | Discussions
fraserhadden Regular Member • Posts: 291
I currently have 2 E-510s, each fitted with a 4GB CF card and a 2GB xD card. I shoot RAW.
I am about to go off to Canada and feel I will need greater storage capacity.
With an eye to future trends in storage, am I better to buy 2 SD-to-CF adapters and fit these with SD cards, rather than buying large-capacity CF cards? Intuitively, it seems so, but are there any drawbacks to the adaptor approach?
Thanks for any guidance
Fraser
Olympus E-5
herebefore
herebefore Veteran Member • Posts: 3,296
Re: CF cards vs. SD cards in an SD-to-CF adapter
I have several CF-SD card adapters that I purchased a couple of years ago when Olympus started putting SD slots in their cameras.
I have a couple of m43 cameras and I knew I would want to be able to use the SD cards I purchased in my Olympus DSLRs.
The adapters work very well, and over 2 years, shooting every day, I think I may have had 3 incidents where the camera would tell me there was a "card problem".
Each time, the "card problem" was fixed by taking out the cf adapter, removing the SD card and re-inserting it.
I buy my memory cards at local stores and every time I look, the SD cards are less expensive than the CF card of the same capacity, so I think it was a good decision for me.
I have even shot with a micro SD card in an SD adapter, and the SD adapter in a CF adapter (but I dont recommend this as a rule... just too much "stuff" to keep track of).
This wont work for everyone, but if you tend not to shoot in the "spray and pray" mode, you will be OK. The SD cards are a little slower than the fastest CF cards I have.
The SD in an adapter is MUCH MUCH faster than any iteration of XD card.
Larry Lynch
Mystic, Connecticut
I figured out why I cant lose weight! The only exercise Im good at is CHEWING
Don't take yourself so seriously. No one else does
In all matters of opinion, our adversaries are insane.
Oscar Wilde
19andrew47
19andrew47 Forum Pro • Posts: 21,694
I didn't even realize this was an option. Dah! I haven't purchased any compact flash cards in about two years as I had many, but reasonably small capacity. The fastest were only 4 Gb cards. I need to look into this. Since I have been using micro SD cards in adapters I should have realized there would be one for SD to compact flash. Thanks!!
fraserhadden OP Regular Member • Posts: 291
Many thanks for your extensive reply.
I shall duly go down the route you have pioneered.
Fraser
Charlene_S Senior Member • Posts: 1,822
This one only works with certain cameras. See link below
 Charlene_S's gear list:Charlene_S's gear list
Olympus E-330 Olympus E-510 Olympus E-30 Nikon D600 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +6 more
declan79
declan79 Regular Member • Posts: 366
Re: This one only works with certain cameras. See link below
I find this n interesting adapter, and is there a suspicious delay in terms of transfer speed? Let say from micro sd+adapter
 declan79's gear list:declan79's gear list
Olympus E-3 Olympus OM-D E-M5 Samsung NX300 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II Panasonic Leica D Summilux Asph 25mm F1.4 +6 more
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 12,275
I've got a pal who has used an SD to CF adaptor on his Sony A700 and definitely notices deterioration in performance, nothing to worry about when taking single shot jpgs but much more so when bursting esp in Raw and when bracketing
My Galleries are at
http://picasaweb.google.com/trevorfcarpenter
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S
Thanks to all
I think that if there is a questionmark over performance using an adaptor, I will reverse my earlier decision and stick with CF cards.
I am only protecting an 'investment' of maybe £60 all in and have discovered that the current top-of-the-line Canons and Nikons are still using CF cards, so obviously they believe that there is life in this format yet.
Fraser
