Canon 1DX dynamic range and banding measurements
Started Jul 8, 2012 | Discussions
Thierry Legault
Junior MemberPosts: 48
Jul 8, 2012
hello, here is a chart showing the dynamic range of the 1DX compared to 5D mark II and III (it's consistent with the DxO Labs dynamic range charts in "screen" mode).
Thanks to a special processing, I also have isolated the banding pattern and compared its level beween 1DX, 5DII, 5DIII and 7D.
All charts and comments in this page: http://legault.perso.sfr.fr/1DX.html
The 1DX looks like a good continuation of its predecessors, without big surprise (good or bad) or technological break.
thierry Legault
http://www.astrophoto.fr
Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EOS 7D Canon EOS-1D
jffielde
Regular MemberPosts: 341
Re: Canon 1DX dynamic range and banding measurements
In reply to Thierry Legault, Jul 8, 2012
Thanks. I'm pretty impressed with the dynamic range if it holds up as well as it appears. That would make the 1Dx king of the hill above ISO1000 or so (looking at the sensor database of the best sensors at DxO's website), would it not? I admittedly know nothing about this, so perhaps I misunderstand.
Thanks for doing the work.
AC1
AC1
Senior MemberPosts: 1,171Gear list
So is this showing the 5D2 has better DR through much of the range than 5D3?
 AC1's gear list:AC1's gear list
Canon PowerShot S95 Canon EOS 7D Canon EF 70-200mm f/4L IS USM Canon EF 50mm f/1.4 USM Canon EF-S 10-22mm f/3.5-4.5 USM +2 more
jeminijoseph
Veteran MemberPosts: 5,385Gear list
Do you have the chart for noise?
Thanks for the effort. How's the high ISO noise compared to 5d III?
Jemini Joseph
http://www.wildbirdimages.com
KewlEugene
Regular MemberPosts: 306
In reply to Thierry Legault, Jul 9, 2012
at ISO 25k 52k 104k 208k ?
Thierry Legault
In reply to jffielde, Jul 9, 2012
I think so. It seems equal to D4 at 1600 iso and higher above 3200
Thierry Legault - http://www.astrophoto.fr
Thierry Legault
In reply to AC1, Jul 9, 2012
Yes, this is confirmed by Dxo Labs charts. This is due to the higher readout noise of the mark III (34 electrons vs 25 electrons at 100 iso), a very unusual evolution!
However, banding must be taken into account because even if its amplitude is much lower than readout noise (5 to 10 times), human vision is extremely efficient in lines detection and in practice, banding often limits dynamic range more than background noise. And the mark III shows comparable vertical banding but lower horizontal banding than mark II.
Thierry Legault
In reply to KewlEugene, Jul 9, 2012
The rule of thumb for most DSLRs (including Canon and Nikon ones) is to decrease the DR by 1 Ev for each iso step at high iso. This is nicely shown by DxO Labs charts which generally become linear above 1600 or 3200 iso (the D800 even shows a linear chart on the overall iso range).
For the 1DX, this leads to a bit less than 8 Ev at 25k, 7 Ev at 52k, 6 Ev at 104k and 5 Ev at 208k (at this level, is it still photography? ;-))
Earthlight
Veteran MemberPosts: 3,178
Thank you so much for sharing this Thierry!
Pattern noise is and has been for years my biggest complaint as a Canon shooter. Topaz denoise helps some though. I wish they could get rid of it but as I have been waiting for that to happen ever since the 20D I do not have my hopes up.
Earthlight
Ps. eagerly awaiting for your shots of the ring of the atmosphere of Venus and shots after the transit.
photorama
Junior MemberPosts: 43Gear list
Bonjour Thierry,
Thanks a lot for sharing these interesting results.
I read that the Nikon D800 has a much wider dynamic range than the 5D III and I wander why because if you compare pixel size it should be the contrary; Is this a matter of read noise or something else?
Jacques Joffre
 photorama's gear list:photorama's gear list
Canon EOS 5D Mark III Nikon 1 V2 Nikon 1 Nikkor 11-27.5mm f/3.5-5.6 Canon EF 24-105mm f/4L IS USM Canon EF 300mm f/2.8L IS USM +1 more
Keyser Sze
Regular MemberPosts: 478
Thanks for the analysis.
Who's Keyser Soze?
Thierry Legault
In reply to photorama, Jul 9, 2012
photorama wrote:
Bonjour Thierry,
Jacques Joffre
Hello Jacques!
Indeed, the DxO chart shows a very high dynamic range for the D800 at low iso (at high iso, other DSLRs catch it up). Although I can't measure easily the same parameters as I did with Canon (because the Nikon firmware sets the offset level to zero before recording the raw file, leading to the loss of small negative variations of noise), I think that it is due to a very low readout noise at all iso settings, contrary to other Canon and Nikon DSLRs whose readout noise starts at a high level and decreases with iso setting.
For example, the 1DX starts at 34 electrons at 100 iso and ends at less than 2 electrons at high iso. If we suppose that the D800 electronics offer 2 electrons of noise regardless of iso seeting and that the pixel capacity at 100 iso is about 25000 electrons (considering their smaller size), this leads to a DR of 13,6 Ev (DxO chart shows 13.2 Ev).
This important difference in the charts is the evidence that the technology of the sensor and/or electronics of the D800 is significantly different.
Mikael Risedal
Veteran MemberPosts: 4,049
In reply to Keyser Sze, Jul 9, 2012
Same old story, pattern noise and high read out noise
Life is a battle wishes aunt Titti
David Hull
Veteran MemberPosts: 5,915Gear list
In reply to Earthlight, Jul 9, 2012
Earthlight
Nik Define 2.0 also does a nice job on the 5DIII vertical noise so there is another option as well.
 David Hull's gear list:David Hull's gear list
Canon EOS 50D Canon EOS 5D Mark III
victor china
Forum MemberPosts: 86
great work ! is it normalized for the same pixel size?
great work
interesting findings
did you normalize for the same pixel size or is it the full rez results?
Mikael Risedal
if the figures are right above 1600isoit means great QE
hmm
Thierry Legault wrote:
photorama wrote:
Bonjour Thierry,
Jacques Joffre
Hello Jacques!
unknown member
(unknown member)
Looks like it's going to kick the Nikon D4's a$$ to the curb! nt
no text
Mikael Risedal
Re: Looks like it's going to kick the Nikon D4's a$$ to the curb! nt
In reply to Apewithacamera, Jul 9, 2012
Not so sure about that.
Apewithacamera wrote:
no text
Thierry Legault
Re: great work ! is it normalized for the same pixel size?
In reply to victor china, Jul 9, 2012
No normalization, everything is full size (anyway pixel size is very close between 1DX, mark II and III)
victor china wrote:
great work
rwbaron
Veteran MemberPosts: 8,948Gear list
My guess is the D4 will be noticably better in the shadows at ISO 100 to 400, about equal at 800 to 1600 and the 1DX will have a slight noise and DR advantage at 3200 and above. The higher ISO's is where this type of camera is most often used but I doubt either will be a "system changer" for any pro heavily invested in one system or the other.
Both are great tools and in the right hands will produce identical results.
Bob
http://www.pbase.com/rwbaron
 rwbaron's gear list:rwbaron's gear list
Canon PowerShot G1 X Canon PowerShot G9 Canon PowerShot S90 Canon EOS 7D Canon EOS 50D +23 more
