!EMERGENCY! 'No card in camera' error in 60D
Started Jul 7, 2012 | Discussions
jordy2324 Regular Member • Posts: 182
Just spent an hour googling and searching the forums, didn't find a real great answer.
In short:
Getting 'no card in camera' error in 60D and weird grinding noise
  • Canon 60D
  • 7 different memory cards (old and new)
  • 7 different batteries (OEM and off-brand)
  • With and without battery grip
  • With 17-55mm 2.8 lens set to AF and MF
  • All batteries and SD cards have worked previously
  • Formatted all cards
  • Reset 60D to factory settings
More details:
So I'm getting this error in my 60D "No card in camera" and my 60D is making some strange grinding noise. Obviously I've never had a single problem with this camera until 8 hours before a big wedding. We have 4 cameras total, but that's split between 4 people (2 photographers and 2 videographers). There's no rental shops that open in Chicago until 9 a.m, and our shooting starts before then.
Here's the specifics. We just randomly got this message tonight while formatting a 16gb card. We tested 7 different cards and 7 different batteries. We have a few Transcend cards (2x16gb and 1x8gb, all Class 10 cards) 2 32 gb SanDisk Ultras (Class 10... these are brand new and never used) and a few old Optimas we really don't use anymore. We have 2 or 3 OEM Canon LP-E6 batteries and 4 or 5 off-brand batteries. We tested with and without our third-party battery grip, but still got the error and grinding noise regardless.
Tried formatting all cards. No dice. Removed and replaced batteries. Nothing. Reset 60D to factory settings. Still nothing. I'm stumped. I've done nothing different or new with my camera. It's been working flawlessly all week.
Here's where it gets weird. We're getting the "No card in camera" error at random times. It doesn't appear to be any one certain battery or one certain SD card that is triggering this error. Some of the cards have been used dozens of times without fail while the 2 32 gb Sandisk Ultra cards are brand spanking new. We've tried a bunch of different combinations or cards and batteries, yet we're still getting the error at random (and often.... about 75% of the time we're getting the error).
There's also a crazy grinding noise coming from the camera. This happens when the lens is set in manual and autofocus modes. Tried with and without the battery grip.
I'm guessing it might be the camera's SD card reader connectors? If so, what can I do aside from spraying air in it? Anything else it could be?
I'm really looking for battle-tested options. Time is ticking, but my 60D is not.
Thanks!
Canon EOS 60D
bigdaddave Senior Member • Posts: 1,163
Send it to Canon
ASAP
nedelcho Regular Member • Posts: 396
Re: !EMERGENCY! 'No card in camera' error in 60D
The battery has nothing to do with this. Unfortunately your camera is faulty and have to go to the service. Maybe the contacts in your camera SD slot are dirty or oxidized. You can try to blow in the card slot with a blower (if there is something that is blocking the SD card to contact with the "pins"), but I don't think it will help for this case.
My gallery:
http://4coolpics.com/author_pics.php?aut=21355
 nedelcho's gear list:nedelcho's gear list
Canon EOS 60D Canon EOS 6D Canon EF 17-40mm f/4.0L USM Canon EF 85mm f/1.8 USM Sigma 105mm F2.8 EX DG OS HSM +1 more
AC1 Senior Member • Posts: 1,171
Sounds like you need to plan for wedding without this camera. And post another thread begging for anyone in Chicago who can lend you a 60D immediately!
 AC1's gear list:AC1's gear list
Canon PowerShot S95 Canon EOS 7D Canon EF 70-200mm f/4L IS USM Canon EF 50mm f/1.4 USM Canon EF-S 10-22mm f/3.5-4.5 USM +2 more
ESfishdoc Senior Member • Posts: 1,567
It doesn't help today but...
The lesson for others.... no matter how many cameras or shooters.... every camera that is important needs a back up... I wouldn't consider going on vacation without a backup.
Sounds like a fix for Canon.
http://esfishdoc.com/blog
My Flickr Photostream Slideshow
http://www.flickr.com/photos/33755787@N03/show/
My Images at Photo.net
http://photo.net/photos/esfishdoc
pcb62 Regular Member • Posts: 135
Re: It doesn't help today but...
I'm not sure about your card error, but the grinding noise could be coming from IS. If you have an IS lens, try turning the IS off and see if the grinding noise goes away.
Y0GI Veteran Member • Posts: 5,228
It looks like the SD card reader on the 60D may be a weak spot. Here is a post from another user who is getting the "Card Write Protected" error with his 60D, and one who had this problem and got it fixed by Canon: http://forums.dpreview.com/forums/read.asp?forum=1019&message=41920956
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +2 more
WilbaW
WilbaW Forum Pro • Posts: 10,738
I had something similar the other day ("no card" error with a good card in it, no grinding noise, camera went dead). I turned it off and charged the battery while I was at work. When I came home and put it back in everything was fine.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
realtor Regular Member • Posts: 236
My experience tells me everything you describe is easily solved except the "crazy grinding noise" symptom. Normally, I would suggest formatting the cards in fat32 on various computers until the body recognized the card(s). The grinding noise suggests a major malfunction in the body.
If I was in your situation and time was of the essence, I would beg, borrow, pay the retail price for a new Canon body and get the job done! You can deal with the malfunctioning 60D later.
BTW there is a reason why I think all or most pro digital bodies use CF cards and not SD cards. But, I could be mistaken.
Best of luck to you!
Opinionator Junior Member • Posts: 27
My 60D also has the mes'g "No card in camera" when I turn the power on. Occasionally it will work, but it is random. So the work around is to use the EOS Utility to download the images before importing them into LR4. Of course you can use any software for image editing or file management. LR4 unfortunately requires users to import files to a collection. It is definitely not a bent pin. There's no way a pin can bend. They're secured at the far end of the slot and lay flat. It's impossible to insert the wrong card as some think. Canon contact suggests removing the battery and card for half an error but that's BS. If it works it is coincidence. I watched a UTube video take apart a DSLR to examine and fix the reader component. Halfway thru I turned that video off. The guy takes a screw driver to everything in sight and no one could possibly remember how to put Humpty Dumpty together again. Actually Canon should have manufactured these as modular so they can be replaced w/o having to be a senior technician. I found the best thing to do to avoid frustration is to use the Canon EOS Utility. It's a bit more laborious but the camera works. All the garbage about formating or not is useless verbiage. Of course u format it when u insert it after downloading if your card reader is functioning correctly. And do the same after using the utility.
I  have an unverified theory that it may not be hardware after all. I noticed and this is a guess by a former application developer so take it w/ a grain of salt because it's merely conjecture and I can't test it. But the usual Sensor Cleaning image that shows up on start up is not performed when the "No card in reader" message appears as the first task on start up. So if I were a troubleshooter at the manufacturer not the home grown photographer, I'd suggest looking at the software start up program. If the sensor cleaning has to be performed first and if the s/w is by passing it erroneously then the error catching portion of the program would send a different message and in this case it is throwing the No card in reader message as a default which shuts down the camera image taking function. That's a lot of explanation for something entirely theoretical. You'd have to have the program to see what its performance objects are.
I noticed as have many of you perhaps that the camera won't function at all if the cover hinged to the camera reader slot is not closed. I did have a problem with that cover before this No card in camera event. I don't have a clue how the cover got jammed. But to think a $1000 camera can be shutdown uselessly because of the cover is a joke. My son had to pry the slot cover open somehow. I tried but couldn't. And btw the memory was working just fine when it was stuck in the camera and worked successfully for a while after the cover was opened, the memory removed and formatted and re inserted. Seems like a very weak link in a fairly good product.
I stand corrected. All my conjecture turns out to be idle thought. Here's a valid explanation I just found.
http://www.learn.usa.canon.com/resources/articles/2012/eos_error_msgs.shtml
Now it may not fit your case. But I did notice that only two of the pins in my 60D were still gold plated. The rest have been rubbed clean down to a silvery color. I would suggest that Canon  either make better contacts if possible or warn us. I've taken 29000 shots in two years. I was not aware that the pins were gold to being with and that the gold rubbed off. In the future when I buy a DSLR under the same mechanical circumstances I will not remove the card until a 32GB card is full. Or if possible a terabyte.
Mark B. Forum Pro • Posts: 19,581
So much for SD cards being more reliable because they don't have pins like CF cards.
CameraCarl Veteran Member • Posts: 4,468
Since this thread is four months old, could the OP please let us know what the fix was for his problem?
There was no fix. But this happened twice after using the camera on vacations taking a thousand shots in less than a week. The first time I set it down 4 a few days after the usual fixes didn't work. I'm repeating the recipe again and hoping luck returns.
mraedge New Member • Posts: 5
Thanks for this thread folks, you've saved me a tonne of trouble.
My 60D is years old and out of warranty. It's never had a problem and has shot tens of thousands of frames.
This weekend it failed me with the No Card In Camera message. I could have cried.
The clues of a previous poster sorted me out though!
No bent pins, no mistreatment, no reason to believe a failure was imminent BUT the last time I used the camera was unusual! I had been shooting they lunar eclipse. It is VERY rare for me to use a tripod and have the camera set to Manual Focus, Stabilzer Off and 2 second Drive Mode (plus bracketing) with the camera in M full manual mode. In fact, I may have NEVER turned the camera off in this state ever before.
I absolutely agree with a previous poster who noticed the Sensor Cleaning step was being skipped on startup and thought a software glitch was to blame!
I simply changed the EF-S 18-200mm lens out for my 50mm 1.8 nifty fifty and everything was fixed.
Putting the original lens back in caused no troubles. We're back baby!
Ahhh, dead again this week. My theory is out the door. I guess it fails over time. I cannot get it working again this time.
Has anyone paid to have it fixed? What did it cost?
The OP is still AWOL after 3 years.
My camera has been assessed for an out-of-warranty repair here in Melbourne, Australia.
The error is apparently an SD Card Slot PCB failure. Repair requires the dismantling of the Canon 60D body and replacement of the SD Card PCB (printed circuit board). Parts are quoted ar AUD$45 and labour (including imager and optics clean, firmware upgrade, and testing) at AUD$180.
Total bill with taxes will be AUD$250 (about US$185).
The failure smells like a (known) manufacturing fault. There's no way such a static part should fail after such a short life. Canon Australia washed it's hands of me because the camera is from overseas.
If you have this problem with your 60D (and it was purchased locally) I recommend demanding Canon fix it, whether it is out of warranty or not.
Not pleased.
It's interesting that this was a thing (which I just discovered). https://www.canon.com.au/en-AU/Personal/Support-Help/Support-News/Service-Notices/Users-of-the-EOS-Digital-SLR-Cameras
Apparently a whole bunch of 60D's no longer function after the SD card is removed too promptly after opening the SD slot door.
My 60D was purchased right in the middle of the affected timeframe for faults.
But I think the issue is limited to 60D cameras which had their PCBs replaced after initial production. Which begs the question... why were so many 60Ds having their SD Card PCBs replaced?
My 2011 Canon 60D exhibited the same issue.
It would occasionally come good but eventually failed totally. I tried the compressed air cleaning technique mentioned elsewhere to no avail.
The "No Card In Camera" error was permanent and my camera was well and truly outside of warranty. Canon Australia were not interested in discussing any production fault possibilities because the camera was purchased outside of Australia.
The repair involved replacement of the SD Card PCB and cost AUD$250.00 (and took a couple of weeks).
My camera lives again.
