7D firing twice when shutter pressed half way, anyone else?
Started Jul 4, 2012 | Discussions
aldownunder OP New Member • Posts: 22
Re: How would you know ???
Thanks ARShutterbug, I am using single shooting mode and not continuous as some have suggested. Maybe I didn't have my finger completely covering the shutter button but a bit off to one side and that caused the shutter to fire twice.
Remembering back to each occasion I don't think I was completely set up to take the shot.
Since the second time this happened I have been careful on my finger placement but the last time was in moonlight and we all know that is supposed to make one act crazy
to birdbrain Phil
What an excellent shot birdbrain, what 700mm lens were you using for it?
Thanks,
Alan.
Le Kilt Senior Member • Posts: 1,788
Re: Because you're in the wrong message
ARShutterbug wrote:
Please pay attention to the part of the thread you're replying to. I'm talking to TTMartin, not the OP.
Sorry if I've ruffled feathers, I have read all the thread and was replying to your post.
Perhaps you didn't grasp that the point I'm making is that the OP is quoting "one shot" which is irrelevant, so I presume (maybe wrongly) that he is mistaking the AF mode with the drive mode, and thinks "one shot" is telling him he is in single-shooting mode when he is in fact in high-speed drive mode. So yes, he would be in a "wrong" drive mode in that case, which would be the most likely explanation.
Using a continuous drive mode does indeed not mean that the camera must be made to take multiple frames during each press of the shutter button, but for a single shot you have to press the shutter release for less than 1/8', easily reached if you think you're in single-shooting.
Not sure, but the exif data may reveal the AF mode and drive mode...
If that was intentional, the drive mode would be irrelevant as I explained. Please actually read the whole message that you repeated before criticizing it, in addition to my original reply to the OP. Using a continuous drive mode does not mean that the camera must be made to take multiple frames during each press of the shutter button. So, there's either something wrong with the camera or the user, as I explained in a previous message.
 Le Kilt's gear list:Le Kilt's gear list
Canon EF 16-35mm f/2.8L II USM
My suggestion. Sorry if you really were in single-shooting mode, the high-speed continuous shooting mode is a classic for taking two shots and seemed the most likely explanation (if unsure one can check the exif data in DPP, it's all there).
TTMartin
TTMartin Veteran Member • Posts: 7,304
Ok, how about you have Custom Function I 4 Exposure Bracketing auto cancel set to 1 OFF.
Then at sometime you set your camera for exposure bracketing.
Your camera is now set to a multi shot mode until you manually cancel the exposure bracketing.
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
The bracketing doesn't change the drive mode, in single shot mode you still need to take three distinct shots when bracketing.
birdbrain
birdbrain Veteran Member • Posts: 3,475
Re: to birdbrain Phil
Thanks,
Alan.
Thanks.
Canon 500 f4 plus 1.4 x II.
Phil
I wondered why the ball kept getting bigger, then it hit me.
http://www.flickr.com/photos/philthebirdbrain/
 birdbrain's gear list:birdbrain's gear list
Sony Cyber-shot DSC-RX10 II Canon EOS 5D Mark III Canon EOS 6D Canon EOS 7D Mark II Canon EF 16-35mm f/2.8L II USM +13 more
TTMartin
Guess, I should refrain from posting at 2:45 in the morning. D'oh
In trying to duplicate the OPs issue with my 7D about the only thing I can say is with my 7D is that you don't really need to press to have the shutter button half depress, you simply touch it and it half depresses, any sort of actually pressing, borders on taking a picture.
Steve Balcombe Forum Pro • Posts: 11,638
Re: 7D firing twice when shutter pressed half way, anyone else?
The 7D shutter is not like the XXD bodies, it's taken from the 1D series and it has a different feel. When I upgraded from a 40D it took me a while to get used to it, but it was worth the effort - I definitely prefer it now.
One characteristic is that you can fire the shutter a second time by backing off the pressure just a little - not all the way back to half press - then squeezing again. It's possible to do this inadvertently, and I think this is quite likely to be what you've done. I've done it a few times - the trick is to learn to ignore it so it doesn't make you miss the next shot!
aldownunder wrote:
In the past 2 months I have had an issue with my 7D which is almost 2 years old and only shot 1948 times. The shutter when pressed half way to check the exposure details, fires 2 shots. This has happened only 3 times, the first 2 were in ISO 100 1/50 sec in Av mode and the third set at ISO 6400 trying to get a shot of the full moon last night.
The camera is set for RAW (of course) and ONE SHOT.
Maybe the new firmware upgrade in August will fix the problem but I was wondering if anyone else has had this experience.
Thanks for any input
yehudakgtbnet Senior Member • Posts: 1,188
Here's an Israeli full moon.
Yehuda
Thanks,
Alan.
 yehudakgtbnet's gear list:yehudakgtbnet's gear list
Canon EF 24-105mm f/4L IS USM
Dale Buhanan MOD Veteran Member • Posts: 4,002
Very wise, Steve. I completely agree with you.
My 7D is pretty new still -- got it at Christmas. But I have inadvertantly gotten a double like that also. It happens if I gently squeeze the shutter like I do when target shooting. So there is very little finger movement and a slow approach to the shutter release. The pressure difference between firing and not firing becomes so little that even the tiny jump of the camera as the mirror flips up and the shutter is released is enough to initiate another shot.
That has happened twice now in 6 months and both times, I was trying to hold extra still and very gently squeeze off the shot. I'm convinced my 7D is not defective. It is just very responsive, and you need to be aware of that.
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot SX50 HS Canon PowerShot G1 X II Canon EOS 70D Canon PowerShot SD500 Canon PowerShot G5 +34 more
Typo
I meant to say shutter release, of course.
That's right - perversely, the more careful you are the more likely it is to happen.
realtor Regular Member • Posts: 236
I've been using the 7D over 2 years and I've experienced the problem you describe since practically day 1. At first I blamed myself. I double / triple checked every setting, but every so often the 7D fires two shots while in single shot mode, no bracketing etc. Oddly, I cannot replicate this anomaly on demand, and I can go months without it happening. It's probably caused by a very sensitive shutter button. The double fire doesn't really bother me at all. Could be a useful feature if we could turn it on and off.
birdbrain
Nice.
Phil
Yes! Well said, Steve.
kind regards
Dale
Thanks very much to all that responded, I am sort of glad that I am not alone.
Al.
