dynamic range setting X10
Started Jul 2, 2012 | Discussions
Alexander Vienna Junior Member • Posts: 39
Hello, I am not sure how to set this dynamic range setting.... Automatic or 100/200/400 ?
If I leave it on auto and ISO on 100-400 auto... the camera very often uses 400 ISO in sun light..... ???
Fujifilm X10
evogt500 Regular Member • Posts: 497
Re: dynamic range setting X10
What setting are you using? When using "L" size, the ISO will match DR setting. EXAMPLE: ISO100=DR100%, ISO200=DR200%, etc.
Using "M" size you can use DR400% with ISO100, and all other ISO setting.
 evogt500's gear list:evogt500's gear list
Canon PowerShot SD500 Olympus D-560 Zoom Sony Cyber-shot DSC-P92 Fujifilm FinePix S200EXR Sony Alpha NEX-5N +14 more
Alexander Vienna OP Junior Member • Posts: 39
I understand. And what would you recommend?
nicoboston Regular Member • Posts: 200
Danielepaolo
Danielepaolo MOD Veteran Member • Posts: 4,364
Try Kim's article.
http://kimletkeman.blogspot.com.au/2009/10/fuji-f70exr-how-to-shoot-it-mkii.html
Apologies if my lack of photographic knowledge is catching.
Dominick Scotto Junior Member • Posts: 42
What I have been doing as I learn the nuances of this camera is to bracket the DR. Each shot has a DR of 100-200 & 400.
