Hot-swap HD question
Started Jun 28, 2012 | Discussions
Timzee
Contributing MemberPosts: 867
Jun 28, 2012
Looking at buying a new desktop PC and would like to configure the tower case with hot swappable, trayless HD slots. I assume that a device such as this would be what I need?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817998020
Also, given I'd like to add multiple slots, I'd have to know how many open eSATA ports the case has, but that's not a spec I generally see on the main vendor type sites. (?)
Any general advice/comments on going this route appreciated.
fft81
Contributing MemberPosts: 939
Re: Hot-swap HD question
In reply to Timzee, Jun 28, 2012
Number of SATA slots should be listed on motherboard description. PC description may list MOBO model. Cheap HP/Comaq etc PCs most likely have crappy PSY, which may not have enough connectors to power as many HDs as you want to add. I build last 4 PCs i had and i remember maintaining/upgrading my parents HP was royal PITA. If going with retail PC, have they configure it for you.
Timzee
Timzee OP
In reply to fft81, Jun 28, 2012
Appreciate the input.
Still considering going the do-it-myself route, but lately time is pretty tight so I'm weighing all my options.
Jen Yates
Senior MemberPosts: 1,402
Rather than one bay per drive, it might be worth looking at a '5 in 3'
http://www.icydock.com/goods.php?id=48
Even if you're not using them all at first it keeps your options open.
Timzee
Timzee OP
In reply to Jen Yates, Jun 29, 2012
Interesting. I wonder about the possibility of cooling issues but worth a closer look. Thanks for the link.
fft81
The last 2 computers i've built had these 5in3 bays.
1. They work well, removing drive from bay requires taking out 4 screws; no big deal.
2. They have fan in the back to cool drives.
3. they take 4-pin atx and SATA power connectors.
4. kind of useless for laptop users since there is no ac/dc converter.
EDIT
installing was a pain; the aluminum rails in the case between the 5.25 slots get in the way; had to dremmel them off.
