Xpro-1 BW Output - My Settings
Started Jun 24, 2012 | Discussions
framus Contributing Member • Posts: 847
Another thing I enjoy about the Xpro-1 is the quality of the BW OOC jpegs.
I've found that setting noise reduction to -2 and sharpness to +2 and ISO to 6400 yields files that render very sharp grain-like noise. In bygone silver halide days I appreciated tri-x processed in 1:25 Rodinal and printed with a Focomat enlarger - gave very sharply rendered detail and grain.
Someday when I recover from the financial impact of purchasing the Xpro-1 I plan to look into Nik Silver Efex Pro.
This image uses the above approach:
-Framus
 framus's gear list:framus's gear list
Fujifilm X100S Fujifilm X-T1
Digart Veteran Member • Posts: 3,688
Re: Xpro-1 BW Output - My Settings
A lovely b&w, especially at 6400 ISO. I occasionally work with SEP and like it a lot, but IMHO I think you are doing fine as is. :)))
Digart
zyghom
zyghom Regular Member • Posts: 123
we are closer and closer to the negative
Zygfryd Homonto
http://homonto.eu
 zyghom's gear list:zyghom's gear list
Fujifilm FinePix X100 Nikon D700
framus OP Contributing Member • Posts: 847
Not so much me as the in camera jpeg conversion the Fuji developed.
Plust the sensor has very 'grain like' noise.
Can you comment on SEP's grain engine?
-Framus
Digart
Yes, you can control the amount of film-like grain you desire in your images. Also, there are many different film stocks (Tri-x, etc.) you can emulate.
-Framus
Digart
Digart
fluxism Contributing Member • Posts: 511
love it--which B&W setting did you use?
 fluxism's gear list:fluxism's gear list
Fujifilm X-E2 Fujifilm X-Pro1 Fujifilm X-Pro2 Fujifilm XF 56mm F1.2 R Fujifilm XF 35mm F1.4 R +2 more
Mike Arledge Regular Member • Posts: 441
Here is what I did with X-Pro1 and SEP for B+W
Creyr Glas Lightworks
 Mike Arledge's gear list:Mike Arledge's gear list
Fujifilm FinePix X100 Fujifilm X100T Leica X Vario Canon PowerShot G5 X Pentax K-S2 +2 more
Toccata47 Senior Member • Posts: 2,785
Silver efex is a must have
If you must live on ramen for a month to get your hands on silver efex, do so! It's totally worth the sacrifice.
borgein
borgein Contributing Member • Posts: 537
Re: Silver efex is a must have
There's also a 15 day trial version available so that you can test SEP 2 before you consider purchasing it.
Just go to this link: http://www.niksoftware.com/silverefexpro/usa/entry.php
and click the "15 day free trial" button on the top right.
I advice you to watch a few SEP 2 videos on Youtube first though, so that you can use SEP 2 during those fifteen days at it's full potential.
Control points is a blessing!
929406 Regular Member • Posts: 221
Agreed, after hearing so many good things about it I decided to try it out. Very worthwhile, makes a nice difference to my previous attempts at B&W.
Wonder what color efex is like?
MuMinded Senior Member • Posts: 1,939
Wow, beautiful tonal range all the way thru.. very very impressive for in-camera work..
I appreciate you giving me your settings.. might just have to add that to my quick menu..
I use SEP 2 simple for the fact that I can tinker with the sliders to give the effect of different filters.. back in my film days I used my red gels often... Now, with either LR or better still, SEP, I have an entire virtual gel set in my computer..
Having said that, I totally respect you taking the time to study and experiment to get great outputs right from the Xpro-1 jpeg engine.. Kudos.
MuMinded
-Framus
 MuMinded's gear list:MuMinded's gear list
Fujifilm X100S Olympus Tough TG-4 Nikon D300 Fujifilm X-Pro1 +2 more
-Framus
Hi Framus
Which in camera b&w filter have you found best results with in addition to the iso, sharpness and noise reduction setting you have listed in your OP? Although I am now a silver efex convert, I can still appreciate the simplicity of OOC b&w
thanks
I use BW or BWY pretty much interchangeably.
-Framus
-Framus
Hi Framus
thanks
love_them_all Senior Member • Posts: 2,770
Nice. There are a few noise "white dead pixel" like on the right side dark area. But they can be easily removed (or add more?)
Funniest thing I've seen here in a while.
Peep much?
-Framus
km25
km25 Contributing Member • Posts: 601
Acufine 1:3 Tri-X at ASA 800. Nice work. I miss Fuji's ISO 1600 film. With my X-Pro I am going to to try. Again nice work and thank you for the info.
kam
 km25's gear list:km25's gear list
Fujifilm X-T1 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Leica Summilux-M 35mm f/1.4 ASPH Leica Elmarit-M 24mm f/2.8 ASPH +3 more
Lol no, don't peep.
Peep much?
-Framus
dengx Senior Member • Posts: 1,020
Fantastic.
Especially for its contrast filters (pro, tonal...).
Best regards
Asylum Photo
Asylum Photo Senior Member • Posts: 1,277
My B&W Settings:
BWr
Shadows +1
Highlights -2
Sharpening +1
Noise Reduction -2
I wish there was mid-range contrast controls.
 Asylum Photo's gear list:Asylum Photo's gear list
Fujifilm X-E2 Fujifilm XF 23mm F1.4 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +2 more
km25
Can you not do that with raw data or photoshop. Try Silver Efex Pro 2. It will give you full control and the images can be very smooth and natural looking.
kam
