Driving me CRAZY! Need Eos Utility 2.11 for mk3...
Started Jun 20, 2012 | Discussions
denmarkdavis New Member • Posts: 2
Threw away the CDs expecting there to be an online download like usual.. No such luck. Could anyone send me their version so I can load some profiles onto my new cam?
arthon Regular Member • Posts: 249
Re: Driving me CRAZY! Need Eos Utility 2.11 for mk3...
denmarkdavis OP New Member • Posts: 2
Thanks for the reply, but this is for installing DPP not the latest Eos Utility..
5D mk3 isn't recognised with 2.10 - I need 2.11 which is not available for download through Canon..
Really frustrating.
ScottieC
ScottieC Contributing Member • Posts: 643
Contact Canon customer service and order a new disc...
 ScottieC's gear list:ScottieC's gear list
Canon EOS-1D Mark II Canon EOS 5D Mark II Canon EOS 7D Canon EOS 5D Mark III Canon EF 85mm f/1.8 USM +8 more
Peter Galbavy Senior Member • Posts: 1,015
Actually, it's Method 1 from the link posted you want - works for all Canon software I've come into contact with. My CDs are in boxes in the loft and have never been used.
Peter Galbavy
KBStudio Regular Member • Posts: 254
This only works if you can find the software to download. I haven't!
 KBStudio's gear list:KBStudio's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark III Sony Alpha 7R Sony Alpha 7R II Canon EF 400mm f/5.6L USM +7 more
John_Hoffman Contributing Member • Posts: 588
Right. Canon hasn't posted yet. Do not understand why OP threw away the CDs he had, that contained the software, to count on a web download. A bird in the hand...
kevindar
kevindar Veteran Member • Posts: 4,023
I contacted canon
same problem. Cps member. contacted them. they immediately wrote me back apologizing. asked for camera serial number my address, date of purchase, to send me a new cd. found the CD in office this am. wrote them back, and asked why was it removed from website. answer was we dont know why, but hopefully will be back up shortly.
I would upload it for you, except I think I will be violating some copy right infringement, as silly as it may be.
 kevindar's gear list:kevindar's gear list
Canon EOS 5D Mark III Canon EF 85mm f/1.2L II USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Sony Alpha 7R +23 more
Shamus1
Shamus1 Senior Member • Posts: 1,660
Re: I contacted canon
You're probably right. I noticed even some of the FW downloads require a s/n....
 Shamus1's gear list:Shamus1's gear list
Canon EOS-1D Mark IV Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EOS-1D Mark III Canon EOS 5D Mark II +6 more
When I asked CPS about EOS Utility 2.11 I got the same "we don't know" response. This was a lot better than the response I got from Canon support, which was no response at all. If they won't release EOS Utility 2.11 at least make 2.10.4 available for Windows 7.
shooter00 Regular Member • Posts: 305
2.10.2 for Windows and 2.10.4 for Mac are the same release versions.
SDRebel Senior Member • Posts: 1,489
Several Canon programs require original install
Several Canon software programs, such as EOS, require an original install of some version from the Canon disc. So, even if there is an update posted, it won't install unless you have a previsious version on your computer and properly installed.
Other Canon software is free of this constraint.
Whether someone who has a disc with EOS can email you files that will install is a question I can't answer.
What I understand is that you have to have a disc, that if you have lost it, then you have to purchase a disc from Canon. I believe the price is in the range of $30.
Of course, if you have a prior version of EOS, you can download the update when it is made available.
That is another issue. For some reason, perhaps Freud explains it in his writings, Canon retains these sorts of updates for months after new equipment has made it to the market. I've never been able to ascertain a reasonable basis for this policy, but it has been the practice of Canon for many years.
No they aren't. I am running both and there is a significant improvement with "Compose" in 2.10.4 which is not available in 2.10.2. But 2.10.4 is only available for Mac OS. Thus, why?
Go to page 40-41 of the 2.10.2 Windows manual and you'll see the same overlay composite feature as in the Mac version manual.
So I guess your saying the Mac 2.10.4 manual is wrong and there is more features showing up in your download than they are showing in manual......
How odd,You compare those two manuals side by side and they are almost identicle page for page.
Re: Several Canon programs require original install
Please read the thread before posting. There are web sites that list the (empty) registry keys required to fool the installer into working. I have been doing it like this on new PCs for years with the original disks (I have DPP 1.0 on CD amongst others!) stored away, never used.
rgds,
Peter Galbavy
I can only speak from experience. I use both. EOS 2.10.2 does not have the same "Compose" functionality as EOS 2.10.4. Again, I use EOS Utility daily on both a Mac and Windows 7 machine. The only function that is different, that I am aware of, is the "Compose" feature. So again, why hasn't this upgrade been made available to Windows users?
You keep saying "Compose" feature.
What is it and what does it do ?
When you activate "Live View" the "Live View" window opens and there are two tabs, Live View and Compose. Live View allows you to focus, set the white point of the screen view of Live View and check depth of field. Compose, allows you to overlay an image onto the Live View window. You can enlarge, rotate, and change the opacity of this overlaid image. This is an extremely valuable tool for commercial shooting. Compose also provides a group of preset grids or the ability to customize the grid. What is different in EOS Utility 2.10.4 is that Compose Overlay does not require you to predetermine the size of the image you are using as an Overlay, EOS Utility 2.10.2 does. It is really difficult to get this presizing correct. EOS Utility 2.11 has the never version of Compose but as of today Canon has not seen fit to allow users of older cameras to update EOS Utility.
Hope this helps. Again, I use the Compose/Overlay feature daily and it helps tremendously when shooting similar products or trying to match previous work exactly.
I guess Canon left out some info in the Windows manual,both look the same to me.
What does the Windows version do differently than what is shown in the manual ?
Mac on the left Windows on the right.
Interesting. I constantly learn using this forum. If there was mention of the keys previously, I missed it. So, thanks for bringing it to my attention.
The fact that people make registry keys available doesn't, of course, explain why Canon engages in hiding the ball. Clearly, if the keys are readily available, there is no economic justification. Also, the availability of the keys makes it even more outrageous for Canon to charge $30 for a disc.
