x10 vs. Nikon D40
Started Jun 19, 2012 | Discussions
rpaschal New Member • Posts: 6
x10 vs. Nikon D40
I've been a happy Nikon D40 owner for several years, but I'm in the market for a smaller travel camera. In looking at the X10 samples online, the IQ seems to be equal to my D40. For those who have both, what do you think?
Fujifilm X10 Nikon D40
Daniel Barnett Contributing Member • Posts: 692
Re: x10 vs. Nikon D40
I went from a D70 to an x10. The D70 is much older than the D40 and the x10 does not have the same IQ that my D70 has. You are talking about a much bigger sensor in your D40. My x10 does have a few options that my D70 does not have. I think the dynamic range is better in the x10. If you are a pixel peeper, you will be disappointed.
Visit my site and give me feedback!
http://dbarnett.smugmug.com/
sparkle1103
sparkle1103 Veteran Member • Posts: 3,654
I have a D40 and went to a Sony HX9V
Janice
In Loving Memory of
Sparkle
July 4, 1993 to August 14, 2011
Wayne N. Veteran Member • Posts: 9,986
My understanding is that the X10 had good IQ for it's smaller sensor. Whether or not it will satisfy you is hard to say. But if you are happy with the web sized images that you are seeing online, then possibly the X10 will do the trick for you.
If you want fixed lens with a step up in IQ, then possibly look into the Sony RX100 (which will have a 1" sensor and great IQ and RAW capability), or the Canon GX1.
The Nikon N1 cameras have interchangeable lenses, so they might not be your cup of tea, but they also have 1" sensors, great IQ and RAW capability. The J1 + 10-30 lens would be fairly compact (the 10mm prime even more so). Oh, and if you wanted to, you could get the FT1 adaptor and use your Nikon F mount lenses for long reach with excellent IQ (for example, the 300mm converts into a 810mm equivalent focal length).
Wayne
http://www.pbase.com/wayne_n
rpaschal OP New Member • Posts: 6
This helpful. Thank you.
Two of the things that appeal to me about the X10 are the fast lens and the optical view finder. I know the VF is not great, but I can't imagine having to use only an LCD screen to take all photos. Most users also comment on the build quality, the surprisingly good IQ, and the fact that it makes taking photos fun again. Any thoughts on these things vs. some of the competitors?
I also considered an X100, but there seem to be so many technical problems with it that I'm not sure I want to risk that much money on something I may not be able to rely on while traveling.
Thanks for your feedback.
gmark53 Regular Member • Posts: 129
Re: x10 vs. Nikon D40 - Have both
and am pleased with the IQ of the X10 at even ISO 3200.
The D40's ISO 3200 is barely usable for a 6x4" print. If your D40 has only a kit lens, you're gaining around 3 stops using the X10 with its fast lens and ISO set to 3200 which looks like D40's ISO 1600. Of course there's the WDS problem on the X10. Only you can decide if you'll likely be in situations that bring it out.
George
 gmark53's gear list:gmark53's gear list
Canon PowerShot A650 IS Canon PowerShot G11 Fujifilm X10 Nikon D3100 Nikon D40 +3 more
ddtan Contributing Member • Posts: 609
You are right in these observations, there are many, including me, who have mentioned these qualities of the X10. You should give it a try, and see if you agree.
 ddtan's gear list:ddtan's gear list
Fujifilm X10 Fujifilm X-S1 Fujifilm X-T1 Fujifilm X-M1 Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
tom_yellowblue Junior Member • Posts: 36
I have both the X10 and D40, and I still use both of them. Overall, at any given exposure the image quality of the D40 is slightly better.
BUT... the lens on the X10 is faster than any zoom I have for the D40. Thus for lower light levels it can use a lower ISO and I find the pictures are better than the D40's. The D40 with the 35mm/1.8 is better, but it's not a zoom. If there is plenty of light then the D40 is better. A D40 with a bounce flash also wins, but I haven't tried a bounce flash on the X10.
The focusing on the D40 isn't as flexible (only 3 points), but it is fast. The X10 is pretty quick too but not quite as fast. The X10 does have face detection and when it works it makes the focusing pretty easy and it also adjusts the exposure so the face comes out correctly. The face detection has problems when people are wearing sunglasses. It also loses faces sometimes, but it's gotten a lot better since the last firmware update.
So what do I mostly use? The X10. It's pictures are almost as good as the D40 and it's just so much smaller and easier to carry.
DutchieinLA Forum Member • Posts: 66
I had a D70 with really nice glass. But I switched to the X10 and gave the Nikon to my 12 year old. Never looked back. Very happy with the Fuji.
 DutchieinLA's gear list:DutchieinLA's gear list
Fujifilm XF 23mm F1.4 R Fujifilm X10 Nikon D200 Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 50mm f/1.8D +2 more
le_alain Senior Member • Posts: 1,558
You won't be desapointed , until you stay
great IQ, good viwfinder (better than D70)
but a longuer learning curve than a P&S, it's not one if you want the best of the camera
 le_alain's gear list:le_alain's gear list
Epson R-D1 Sony Alpha 7S Sony Alpha 7R II Sony FE 24-70mm F4 OSS Sony FE 55mm F1.8
Kim Letkeman
Kim Letkeman Forum Pro • Posts: 33,335
Which means that you are not a high ISO shooter. On the other hand, you have fantastic video.
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F200EXR Fujifilm FinePix F770EXR Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-G5 +16 more
I recently got the 35mm 1.8 for my D40. Looks like it will be very good, but it doesn't solve the travel size issue, and I'm not sure whether I'll be happy limited to that particular focal length. Hence, my interest in the X10. I appreciate all the feedback.
Kim Letkeman
I shot the D70s for years and this comment is definitely a personal taste thing. The X10 has a tunnel OVF which I think sucks ... the D70s has a very nice OVF, as do all dSLRs.
It is a P&S. It just has more buttons and dials and is bigger and heavier. There is no functional difference between the X10 and the F770EXR, except the F770EXR has much better reach. The IQ of the X10 is better at 800 and above as well (obviously.)
But ... what is identical between them is the presence of EXR and all that implies. The learning curve is steep because EXR has a bazillion modes, most of which are inferior in one way or another to simple PASM settings, as I document here ...
http://kimletkeman.blogspot.com/2009/10/fuji-f70exr-how-to-shoot-it-mkii.html
Kim Letkeman
I just bought the Tamron 17-50 2.8, a wicked sharp lens that would have no trouble spanking the X10 in my opinion. This lens is small and inexpensive, and would work really well on the tiny D40. Mine does not have the built in motor, but that version exists. And so does a stabilized version, with slightly less acuity.
What I remember about my testing of the X10 (for several weeks) is that carrying it around was just as inconvenient as a bridge cam or a dSLR. Once you need a case ...
Very helpful hints in your blog! Thank you.
PAUL TILL
PAUL TILL Veteran Member • Posts: 9,285
Small world, I just got myself another Tamron 17-50mm f/2.8 XR Di II VC LD Aspherical IF SP AF (what a mouthful) yesterday, I wouldn't call it small though, it's big even on a D200.
Paul.
Kim Letkeman
sorry, I call BS ...
The X10's 3200 looks nothing like the D40's 1600 ... as I show here ...
Honestly, I don't know why simple physics needs explaining so often on this forum ...
Kim Letkeman
the version I have is smaller ...
Lens based stabilization always increases the size of a lens ...
How's the acuity of your sample?
Kim Letkeman
thanks
