Pocket wizard Plus III & Flex TT5
Started Jun 16, 2012 | Discussions
Mat Miller
Mat Miller Regular Member • Posts: 205
I am trying to get these to work together. I want to use the Plus III as a trigger. Can this be done? If so how? I cannot find it...
Thanks!
Nikonparrothead Veteran Member • Posts: 4,611
Re: Pocket wizard Plus III & Flex TT5
It will work but the flex will only work as a normal PW make sure they're both on the same channel.
'Nice pen, bet you write good stories with it.'
 Nikonparrothead's gear list:Nikonparrothead's gear list
Panasonic Lumix DMC-TZ1 Canon PowerShot S95 Fujifilm FinePix X100 Nikon Coolpix A Panasonic Lumix DMC-LX100 +13 more
DecibelPhoto Contributing Member • Posts: 791
Yeah you just have to plug your flex into your computer and check what your standard receive channels are set to. Then set your plus III to the same thing.
Mat Miller
Mat Miller OP Regular Member • Posts: 205
Yep that was my issue. Thank you so much everyone!
DarkRain New Member • Posts: 3
Hi DecibelPhoto,
I seem to have the same problem here and hoping you or another might be able to help
I've just got a FlexTT5 and Plus III for my D700. I've attached the III to the D700 and the TT5 to my SB-910 for remote flash trigger setup. I've checked the channel setting on the TT5, which is set to channel 1, and set the III to the same channel. I've followed the manual for other recommended settings including changing Nikon Custom Setting 'e1 Flash sync speed' to '1/250s (Auto FP)' and setting 910 to standard illumination pattern.
Problem is that when I test the setup the 910 is not firing. The 910 seems to be communicating with the TT5 OK. It looks like the III is not communicating with the TT5. When I press the test button on the III I get no response from the TT5 and 910.
Anyone have any ideas? The answer is probably right in front of me. Any help would be greatly appreciated.
gadelrosario
gadelrosario New Member • Posts: 8
Hi,
I'm thinking of moving to the IIIs and called the MAC Group to ask about backward compatibility.  They said the III and the TT5s will work together but the TT5s need to be configured (via computer) to be just a standard trigger, not TTL.  Perhaps the way to do this is to configure C2 as standard trigger mode, set the channel and update the TT5s, leaving C1 as TTL.  I've actually done this previously because I use C2 with my Sekonic light meter.  I don't yet have a Plus III to test it with.  Please post your results - I'd love to know what comes of this.
 gadelrosario's gear list:gadelrosario's gear list
Nikon D4 Nikon D800 Sony Alpha 7 II Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +7 more
Thanks gadelrosario, I'll try this and come back to let you know. Cheers
Ok. I tested and it works.
If you go into the PocketWizard Utility and into Settings>Configuration 2>Misc and check 'Basic Trigger' check box. Click on Apply Changes. Probably goes without saying that you also have to set the SB-910 to a non-TTL flash mode.
Thanks again.
gadelrosario
Thanks again.
Glad to hear that you got them working together.  I'm about to pull the trigger on the Plus IIIs myself.
Freddie Kang New Member • Posts: 2
Thanks again.
I shoot with a Nikon D3s and D700 with 3 SB900's. To enjoy the convenience of iTTL/CLS, I bought one each of the AC3 Zone Controller, Mini TT1 Transmitter, and 3 sets of the Flex TT5. This works great and I love the convenience of iTTL plus the ability of powering on/off each speedlite and controlling the power of each speedlight from the camera position.  Hence I configure C1 on the TT5 to transmit ControlTL and Standard modes, but receive only in ControlTL mode.
Since I also shoot with other non-Nikon bodies and manually adjusted speedlites / strobes, I configure C2 on the TT5 to receive only in Standard mode.  This allows me to place a PW Plus III, set is to C2, and have it mounted at the triggering unit on the hot shoe of a non-Nikon body.
Set up this way, I set to C1 when I want the 3 TT5's to be used with Nikon bodies and hence enjoy the iTTL convenience.
When I need the TT5's to fire speedlites triggered by non-Nikon bodies, I just switch all the TT5's over to C2, mount a PW Plus III (selected to Channel 2) on any non-Nikon body, and now I trigger as many TT5's as required.  Of course, all flash on/off and power settings are done at the flash location.
Trust this sharing is helpful.
Fred
gadelrosario wrote:
Hi,
Hi,
I have 3 TT5s and a Plus III, and have configures the TT5s C2 to standard non-CtrlTL mode while leaving C1 configured for TTL. Works fine. And very convenient too. When I shoot with my Nikon bodies and Nikon Speedlights, I set the TT5s to C1. Then when I shot 'non-Nikon' bodies and non-Nikon speedlights, I use C2 on the TT5s and this works well with the Plus IIIs.
mariakorea New Member • Posts: 1
I finally got the PW Plus III to trigger my two 580exII's along side with my Flex TT5 thanks to this forum. However, I can't get the speedlights assigned to an A, B, or C zone. I want to be able to assign them a zone so that I can easily turn one off, both off, or both on through the PW Plus III. Does anyone know how this can be done?
EmailYasmin Junior Member • Posts: 29
To assign Groups, simply select group select switch on the side of Flextt5 connected to your flash units. Now you can choose groups you want to fire on Plus-III by pressing Group Select buttons on  it.
Hope we this helps.
