dishwashing liquid soap safe for cleaning optics?
Started Jun 16, 2012 | Discussions
EOS_GUY
Regular MemberPosts: 100
Jun 16, 2012
Yesterday I accidentally touch the rear optics of my 85mm 1.2L, first I tried to wipe it using pecpad lens tissue with distilled water but still it smudges, second I tried isoprophyl alcohol but still I can see marks then lastly I tried water with a little of dishwashing liquid soap and viola no more marks, crystal clear! Is it safe to use dishwashing liquid soap in cleaning lenses?
Kjeld Olesen
Veteran MemberPosts: 3,710Gear list
Re: dishwashing liquid soap safe for cleaning optics?
In reply to EOS_GUY, Jun 16, 2012
I suppose it does no harm to the glass or coating, but if you get it under the ring holding the outer lens it could be hard to get rid of again.
photonius
Veteran MemberPosts: 6,379
As far as I can tell it's safe, less aggressive than some of the lens cleaning compounds. I use it on filters, when the grease doesn't want to come off (one reason for me to use filters, can take them off and wash them).
works very well for grease.
of course with a lens you got to be careful to not get liquid inside.
Life is short, time to zoom in ©
victorian squid
Veteran MemberPosts: 3,390Gear list
Dish soap has potential to leave residue, although it should be safe for the lens coating which is pretty durable. I think I'd avoid things like alcohol. You don't say what you're using as a "delivery system".
You should be able to get skin oil off using just a clean micro fiber cloth.
 victorian squid's gear list:victorian squid's gear list
Canon EOS 6D Canon EOS 70D Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Tamron SP 150-600mm F/5-6.3 Di VC USD +37 more
victorian squid
Good video on proper lens cleaning techniques
In reply to victorian squid, Jun 16, 2012
From Nick Kelsh:
http://vimeo.com/39494324
hotdog321
Forum ProPosts: 14,569Gear list
I'd recommend a clean microfiber cloth and avoid solvents, alcohol, lens cleaners and soaps unless you have a truly spectacular glob of sticky crud on the lens. Just breathe on the surface and polish clean. This has worked for me for the last 30 years.
By the way, I rarely clean my lenses. New camera owners generally spend way too much time cleaning the lens and damage the multicoating.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 16-35mm f/4L IS USM Canon EF 24-70mm f/2.8L II USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 11-24mm F4L +1 more
unknown member
(unknown member)
I just place my glass into the dishwasher and gets em squeaky clean. Nt
No text
unknown member
(unknown member)
Breath contains bacteria. Bacteria leads to mold. Nt
In reply to hotdog321, Jun 16, 2012
No text
JstarImaging
Regular MemberPosts: 260
Re: Breath contains bacteria. Bacteria leads to mold. Nt
In reply to Apewithacamera, Jun 16, 2012
IPA on a cotton bud and a lint free cloth to wipe clean.
Use back at base, rather than in the field as you'll create more of a mess.
I've used this method for 25 years with no issues except clean optics.
Cheers
James
The chances of survival are equal to the angle of arrival !!
rsn48
Veteran MemberPosts: 7,254
Another post I don't understand...
Its amazing how many guys will spend all kinds of money on lenses and quality glass, then won't break down and spend $10 on cleaning fluid designed for photo glass. I don't get it, could some one explaining to me so it makes rational sense.
Lots of things guys have tried leave residue on glass, why fiddle with stuff when its clear you don't know what you are doing. Break down and get the cleaning fluid from a photo store, it will last you a decade if no more, mine is 20 years old, I think I paid $4 back then.
"Photography is, indeed, an inclusive language."
Ansel Adams
Gearóid Ó Laoi, Garry Lee
Veteran MemberPosts: 6,033Gear list
When I have to clean a lens this is what I do
Tiny drop of detergent in warm water. Agitate.
Small bead of cotton wool dipped in this. Squeeze.
Clean lens.
Dry with dry cotton wool.
Blow on lens.
repeat with dry cotton wool.
I only do this for fingerprints etc., so fairly seldom.
have done so without damage for 35 years.
 Gearóid Ó Laoi, Garry Lee's gear list:Gearóid Ó Laoi, Garry Lee's gear list
Fujifilm X10 Canon PowerShot S90 Canon EOS-1Ds Mark III Canon EOS-1D Mark IV Sony Alpha NEX-7 +25 more
andrewsf
Contributing MemberPosts: 534Gear list
In reply to Apewithacamera, Jun 17, 2012
Your comment is BS ape.
It has never happened to me so it can't be right.
Apewithacamera wrote:
No text
 andrewsf's gear list:andrewsf's gear list
Canon EOS 400D Canon EOS 7D Canon EF-S 17-55mm f/2.8 IS USM Canon EF 50mm f/1.8 II Canon EF 85mm f/1.8 USM +1 more
In reply to andrewsf, Jun 17, 2012
No text
Fungus comes from spores in the air. They will settle in someplace damp. There are bacteria everywhere, on your skin, in your mouth, intestines and in your expensive lenses.
There are even bacteria high in the atmosphere.
We couldn't live without bacteria.
cedrec
Regular MemberPosts: 328
Your post makes me sad for the state of our educational system.
hotdog321
Re: Another post I don't understand...
In reply to rsn48, Jun 17, 2012
Lens cleaning liquids are ideal, but people new to photography often put the drops directly on the lens allowing it to seep into the edges and onto the back of the lens where it can't be wiped clean.
unknown member
(unknown member)
Here have a tissue. nt
In reply to cedrec, Jun 17, 2012
no text
unknown member
(unknown member)
Good spot for a commercial.
In reply to Gearóid Ó Laoi, Garry Lee, Jun 17, 2012
trulandphoto
Contributing MemberPosts: 712Gear list
I still have a spray bottle of ROR with some left over from 20 years ago. If I have to clean off a front element now, I use a Zeiss lens cleaner in a packet (get them at Walmart) then a dry microfiber cloth after it's dried to remove any residue.
 trulandphoto's gear list:trulandphoto's gear list
Canon EOS 5D Mark III Canon EOS 7D Canon EF 70-200mm f/2.8L USM Canon Extender EF 2x III Canon EF 40mm f/2.8 STM +6 more
dgovoni
Contributing MemberPosts: 786Gear list
I use this and so do a number of pros. Never fails to clean a dirty lens.
In reply to EOS_GUY, Jun 17, 2012
photonius
In reply to victorian squid, Jun 17, 2012
Quite right, but the liquid detergent is very easy to rinse off with water. If you have distilled water, even better. If you dry off the water after rinsing, it leaves no residue.
