New to flash and studio lighting
Started Jun 16, 2012 | Discussions
RevolvingSheep Junior Member • Posts: 43
I own a Nikon D90, a 35mm f1.8, a 85mm f1.8G... and today I bought a SB700 flash and a lighting kit with 2 lights - 70 watt florescent bulbs.
Where is the best place to learn how to use this gear? Is there a good web page for this, or an all around good book on the subject? If I need to look at flash photography and studio lighting separately, I am fine with that.
I will be shooting portraits... but I like to shoot in many styles and settings.
Thanks.
Nikon D90
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,278
Re: New to flash and studio lighting
My first suggestion is that you return the lighting kit for credit toward a studio strobe lighting kit if you want to do portraiture. Continuous lighting is fine for non-animate subjects but the long shutter speed required make shooting animate objects without getting images that aren't blurred problematic.
Read my article on equipment for a small home studio for information on what I recommend.
http://photocamel.com/forum/lighting-technique/156228-equipment-guide-setting-up-small-home-portrait-glamor-studio.html
As far as books for flash go, you can't find anything better than Syl Arena's book, "Speedliter's Handbook". It is written for the Canon Speedlite user but 98% of what is in the book is applicable to any hot-shoe flash.
http://www.amazon.com/Speedliters-Handbook-Learning-Craft-Speedlites/dp/032171105X/ref=sr_1_1?ie=UTF8&qid=1325480043&sr=8-1
For general information about digital photography and portraiture check the following links.
http://www.ttl-biz.com/links
http://www.lumitouch.com/benstudiotutorial/index.html
http://prophotoresource.com/home/item/652-how-to-handle-hands.html
http://www.professionalphotography101.com/portrait_lighting/lighting_names.html
http://ddata.over-blog.com/3/31/09/97/trucs-et-astuces/pg1.pdf
http://www.vci.net/~mmorgan/pg2.pdf
I also suggest you join the PhotoCamel forum. It is a very friendly forum and you will find many specialty forums with many active participants, including a number of professional photographers, who are willing to help.
Here are some links to useful tutorials found on PhotoCamel.
http://photocamel.com/forum/tutorials/35976-high-key-imaging.html
http://photocamel.com/forum/lighting-technique/109737-make-up-your-female-subjects.html
http://photocamel.com/forum/tutorials/14991-photographing-big-beautiful-teen.html
http://photocamel.com/forum/tutorials/100098-facial-analysis-fine-portraiture-corrective-techniques.html
http://photocamel.com/forum/portraits-people/121488-fabulous-fill-light-article.html
http://photocamel.com/forum/photography-talk/65933-critiques-how-give-take-important.html
http://photocamel.com/forum/tutorials/142441-how-judge-your-own-photographs-article.html
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
AdrianGray Regular Member • Posts: 119
To learn how to use your flash, check out strobist.blogspot.com and (possibly NSFW due to glamor photography) smokingstrobes.com
Klaus dk
Klaus dk Veteran Member • Posts: 3,349
Yep! Lose the continuous...
Studio strobes with model lights works for me, but you can go the strobist way too.
Less is more
 Klaus dk's gear list:Klaus dk's gear list
Canon PowerShot S120 Canon EOS 500D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF 50mm f/1.8 II +9 more
Bob Stothfang Senior Member • Posts: 1,153
+1 For the Strobist blog
Bob
Use the preview feature before you post your message to see if you any words or letrs out. You can check your links to see if they work too.
Quantum Help Senior Member • Posts: 1,666
Wow
A lot of camel-ization there Sailor. Hope Ed doesn't get a hold of him.
 Quantum Help's gear list:Quantum Help's gear list
Nikon D90 Nikon D1X Nikon D200 Nikon D300S Nikon AF-S Nikkor 300mm f/4D ED-IF +5 more
Kali108 Regular Member • Posts: 268
strobist.com and kelbytraining.com
Joe McNally classes at kelby training are excellent.
Thanks.
