iMac i5 3.1Ghz or iMac i7 3.4Ghz (both 27 inch)
Started Jun 14, 2012 | Discussions
ajimon
Regular MemberPosts: 276
Jun 14, 2012
Hi,
I'm having a tough time deciding between 3.1GHz Quad-Core Intel Core i5 and 3.4GHz Quad-Core Intel Core i7
Primary needs : Editing raw files from 5D Mark2 and D700 in CS5, DPP and CaptureNX2. HD video editing in After effect and Final cut pro.
Having read a lot on web, and having seen pages of benchmarks, it is obvious than i7 has a good lead. But my question here is, do I really need all that power for my needs?
Once bought I don't plan to upgrade in next 3-4years time.
Appreciate your suggestions.
AJ.
Canon EOS 5D Mark II Nikon D700 Samsung i7
Powerdoc
Veteran MemberPosts: 3,225Gear list
Re: iMac i5 3.1Ghz or iMac i7 3.4Ghz (both 27 inch)
In reply to ajimon, Jun 14, 2012
There is no need for the I7
That's said, the SSD is wonderful feature : you boot way faster your mac. I recommand this option even if it's expansive.
(Mac OX and applications on the SSD), data on the HD.
It's all about photography
 Powerdoc's gear list:Powerdoc's gear list
Fujifilm FinePix X100 Fujifilm X-Pro1 Panasonic Lumix DMC-GX7 Canon EF 50mm f/1.4 USM Canon EF 135mm f/2.0L USM +21 more
ajimon
ajimon OP
In reply to Powerdoc, Jun 15, 2012
I forgot to mention that video editing will only be 10%.
I'm slowly beginning to understand i5 3.1Ghz should suffice. Need to make a decision by end of beginning of next week.
AJ.
JediLight
Forum MemberPosts: 98Gear list
In reply to ajimon, Jun 15, 2012
Are you aware that all rumours point towards an imminent refresh of the iMacs? I am holding off for about a month and would hope / expect that the latest Ivy Bridge versions of iMacs will be out by then.....just possibly with retina displays .
 JediLight's gear list:JediLight's gear list
Nikon D80 Nikon D7000 Nikon D800 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 16-35mm F4G ED VR +2 more
Howard Moftich
Veteran MemberPosts: 7,449
In reply to JediLight, Jun 15, 2012
IMO, the probability of a 27" Retina iMac is quite small at this time. They're going to have their hands full just trying to make 15 and 13 much less 27.
And then, could you afford it? At the current rate, it'd probably be soemthing like a $1000 adder
OwenG
Contributing MemberPosts: 588
Editing video may only be 10% now but who knows what the future holds. If you can afford it and as you don't plan to upgrade for 4 years then future proof your machine with the i7
More operating systems and software will be released that will need more computing horsepower and 4 years is a very long time in computing. My 3 year old Mac Pro won't run Final Cut Pro X properly.
bravozulu
Contributing MemberPosts: 897Gear list
In reply to OwenG, Jun 15, 2012
Also waiting in the wings for the new iteration of iMacs. From what has been posted on MacRumors, and from a friend who founded a big MUG group in Los Angeles, the i7 cpu offers advantages only to certain sorts of applications. It would largely go unused by PhotoShop and LR. But, if you've got the extra money, why not?
Several pro photographers have told me that displays for PCs are superior to the iMac screen. So, since there is an advantage to having two screens in any case, save money and choose a small iMac. Then buy a second monitor that is larger to sit alongside it.
 bravozulu's gear list:bravozulu's gear list
Nikon D7000 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Micro-Nikkor 60mm f/2.8G ED Nikon AF-Nikkor 80-200mm f/2.8D ED +5 more
ajimon
ajimon OP
New iMacs coming soon.. wow, I don't mind waiting a month or two. Can you imagine a situation where I have purchased the current version and a newer one follows the following month!
AJ.
Jeff_Donald
Regular MemberPosts: 300Gear list
In reply to ajimon, Jun 16, 2012
If you expect your computer to last 3 to 4 years minimum, your best off getting the fastest unit you can afford. This helps future proof you and little and extends the life of the computer to better meet your expectations.
Adobe is already making considerable use of the graphics cards in both PS and LR. This is expected to increase in the future releases of those programs. I would personally go for the i7 and the largest graphics/video card available. I would then load it up with 16 GB of aftermarket ram and sit back and enjoy it for the next 3 to 5 years.
 Jeff_Donald's gear list:Jeff_Donald's gear list
Canon PowerShot G12 Ricoh GR Digital IV Canon EOS-1Ds Mark II Canon EOS-1Ds Mark III Canon EOS 7D +40 more
ajimon
ajimon OP
In reply to Jeff_Donald, Jun 17, 2012
Thank you all. I will go for i7 having considered change in resource intensive application that can come out in the next 3-4 years.
AJ.
Bruce McL
Senior MemberPosts: 1,177
In reply to ajimon, Jun 17, 2012
I think spending an extra $100 for the 2GB graphics card is a very good idea. The processor upgrade I would put a slightly lower priority on. Of course you want to buy a lot of RAM.
