60D – Why are all my pictures are BLANK!!
Started Jun 12, 2012 | Discussions
Danny Somekh2
New MemberPosts: 1
Jun 12, 2012
Hello. I've been using my Canon 60D without a hitch for over a year but it suddenly started only taking blank/black pictures. I've tried defaulting to factory settings, different shooting modes, using live view and removing the sim card – still no luck. In live view mode an indicator saying EXP.SIM is constantly flashing. Other than that the camera seems fine mechanically - doing everything as expected. As I have been travelling for a year, taking far more shots than a casual user, I'm concerned there is something fundamentally wrong with the electronics/sensor. Any ideas?
Canon EOS 60D
Jim B (MSP)
Veteran MemberPosts: 6,607
Re: 60D – Why are all my pictures are BLANK!!
In reply to Danny Somekh2, Jun 12, 2012
No idea yet for the blank shots.
But for the Rebel: The little badge at lower right says "Exp. SIM", indicating that the Exposure Simulation feature has been enabled, approximating the brightness of the final image on the rear panel LCD screen.
and I found: Exposure Simulation will attempt to continue even with depth of field preview active, though this may raise the live view noise levels even further. If you pass outside the range where the live view feed can simulate your exposure, the "Exp. Sim" icon near the bottom right of the LCD will blink, as a warning.
Jim
TTMartin
Senior MemberPosts: 5,365Gear list
In reply to Jim B (MSP), Jun 12, 2012
Make sure the exposure compensation is set to zero.
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon EOS 400D Canon EOS 7D Canon EOS M +23 more
ARShutterbug
Veteran MemberPosts: 8,287Gear list
You have a SIM card?
In reply to Danny Somekh2, Jun 13, 2012
Your camera has a Subscriber Identity Module card? I feel so obsolete!
It actually sounds like your lens cap is on. If that's not it, something is broken.
Oly Canikon
Contributing MemberPosts: 998
Re: You have a SIM card?
In reply to ARShutterbug, Jun 13, 2012
We have too many acronym's, who can keep them straight.
Does live view work? That will check the sensor.
Take a shot in manual with no lens and look through the lens mount. Can you see the mirror flip up and the shutter open?
sleibson
Regular MemberPosts: 244
Take off the lens and put the camera into sensor cleaning mode. (Not the automatic sensor cleaning, the mode for manual cleaning). This mode should open the shutter and raise the mirror. If you can look through the lens mount, into the camera's mirror box, and see the sensor, then the shutter mechanism is working. If not, there's something blocking the sensor in the mirror box. Your shutter might have died or the mirror might not be lifting and a trip to Canon (possibly an expensive one) is the next step because something is definitely broken.
This assumes you're not getting an image in LiveView mode. If you are, then you already know the shutter is working and the mirror is lifting. However, the blinking "Exp. SIM" indicator (exposure simulation) suggests that the sensor isn't getting any light because the camera can't find anything on the sensor even when amplifying the image signal.
Steve Leibson
Shooting with Canons for 40 years
Lajos Hajdu
Senior MemberPosts: 1,585
Got it!!
In reply to Danny Somekh2, Jun 14, 2012
You forgot to take off the lens cap.
(Sorry, couldn't resist.)
TTMartin
Without some feedback from Danny on what he's tried and hasn't tried, or if he even still has a problem, posts on how to fix it are kind of pointless.
tko
tko
Forum ProPosts: 10,046
well. don't you hate it?
In reply to TTMartin, Jun 14, 2012
When people don't post back? Kind of rude. I'd be trying everything.
Thorbard
Contributing MemberPosts: 677Gear list
How many photos have you been taking? The rated shutter life is around 100,000 shots, if not more.
The error as described sounds like a sensor failure or a shutter failure. Do you still hear the shutter activate when you try and take an image, or is the camera silent?
 Thorbard's gear list:Thorbard's gear list
Canon EOS 7D Canon PowerShot G15 Canon EF 85mm f/1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 40mm f/2.8 STM +1 more
Danny Somekh
New MemberPosts: 9
In reply to TTMartin, Jun 15, 2012
Thanks and apologies – I'm new to this forum and naively assumed I'd get an email notifying me of any responses. I'll post some feedback now...
Danny Somekh
New MemberPosts: 9
Re: well. don't you hate it?
In reply to tko, Jun 15, 2012
Sorry, didn't mean to be rude. I've very appreciative of all feedback.
Danny Somekh
New MemberPosts: 9
In reply to Jim B (MSP), Jun 15, 2012
Thanks Jim. I assume Exp Sim only relates to Live view mode so it's probably a red herring.
Danny Somekh
New MemberPosts: 9
Thanks TTMartin. I've restored factory setting but will double-check exposure compensation again.
Danny Somekh
New MemberPosts: 9
In reply to ARShutterbug, Jun 15, 2012
Thanks ARShutterbug, I was actually sorting out my phone's SIM card just five minutes before posting the issue and got a bit muddled! Having said that, I'm sure the major manufacturers are working on SIM-enabled cameras. Like we need more functionality!
Danny Somekh
New MemberPosts: 9
In reply to Oly Canikon, Jun 15, 2012
Thanks Oly, but ARShutterbug is right – I was being thick. Looks like the mirror/shutter works fine so all fingers are pointing to the sensor at the moment
Danny Somekh
New MemberPosts: 9
In reply to sleibson, Jun 15, 2012
Many thanks sleibson, I'm getting an image in Live View mode so it could well be a faulty sensor. Gulp! sounds expensive!
Danny Somekh
New MemberPosts: 9
Re: Got it!!
In reply to Lajos Hajdu, Jun 15, 2012
Thanks Lajos, leaving the lens cap on is my forte but sadly not in this instance!
Danny Somekh
New MemberPosts: 9
In reply to Thorbard, Jun 15, 2012
Hi Thorbard, I think the shutter is fine but you got me thinking about just how many shots I must have taken during my year away. My photo library contains about 20k-25k images and I tend to purge of at least 80% when importing them to my computer. Chances are I've taken over 100k shots so I'm going to check what the estimated life of the sensor is. Anyway, I'm quite happy with the pics it's given me. You can see some here: http://www.facebook.com/ouryearaway and http://www.ouryearaway.com . Thanks again for your feedback!
TTMartin
In reply to Danny Somekh, Jun 19, 2012
Any luck?
