New paanasonic 12-35mm f2.8 and 35-100mm f2.8 lenses
Started Jun 9, 2012 | Discussions
Krishna Das
Contributing MemberPosts: 736
Jun 9, 2012
How good are these lenses? Seems that Panasonic is trying to copy the best selling zoom ranges for full-frame Canon and Nikon lenses. I hope they try to emulate their quality also... These lenses from Canon and Nikon are of excellent quality but very expensive. Perhaps Panasonic is going to take their fight to the big boys. Hope so...
Brian Mosley
Forum ProPosts: 20,404Gear list
I expect them both to be high grade. /nt
In reply to Krishna Das, Jun 9, 2012
Join our free worldwide support network here :
http://www.ukphotosafari.org/join-the-ukpsg/
UK, Peak District Local Olympus Safari Group : http://snipurl.com/bqtd7-ukpsg
Keep up with me here : http://twitter.com/alert_bri
 Brian Mosley's gear list:Brian Mosley's gear list
Olympus E-M1
Krishna Das
Re: New paanasonic 12-35mm f2.8 and 35-100mm f2.8 lenses
12-35mm for MFT is equivalent to 24-70mm FF
And
35-100mm is equivalent to 70-200mm...
Brian Mosley
And
Here you go... knock yourself out :
Sensor Equivalence: Size Does Matter. Or Does It?
Read more: http://the.me/...ensor-equivalence-size-does-matter-or-does-it/#ixzz1xDNXR9Uw
Cheers
Brian
Olympus E-M1
c_henry
Regular MemberPosts: 177
I think they'll be fairly good quality and as long as they're better than th 12-50 and the 40-150, then I'll be very happy.
We'll have to wait and see.
Colin
ryan2007
Veteran MemberPosts: 7,225Gear list
I would think any company that puts out a lens is staking their reputation. The lens at $1300 should be stelar and matched to the system.
If Panasonic flops it will be very bad because all you have to hear is that Panasonic or Olympus, Nikon or Canon or that matter put out a lens that is bad.
I would highly advise either waiting for editor reviews or someone here willing to take a chance and well return the lens if need be if it does not seem performance and price make sense.
 ryan2007's gear list:ryan2007's gear list
Fujifilm X100S
Aleo Veuliah
Forum ProPosts: 14,455Gear list
They are not copying, they are just expanding the lenses line, and they seem to have very good quality from the reviews of the 12-35mm, I think this besides expanding the lenses line up, has to do also with Panasonic Lumix partnership with National Geographic, they want that pro photographers like some of landscapes and wildlife look at those lenses and Micro 4/3 system as a good choice, and a smaller one
Simplicity is the ultimate sophistication.
God is the tangential point between zero and infinity.
Imagination is more important than knowledge.
God always take the simplest way.
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Nikon 1 V3 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +3 more
Dr_Jon
Senior MemberPosts: 1,107Gear list
In reply to Brian Mosley, Jun 9, 2012
Brian Mosley wrote:
And
That gave me Page Not Found. However when composing a Photograph the Field of View is perhaps the most important thing, so I have no issue with people making lenses with similar fields of view to established ones. Also I'm cool with using 35mm equivalence numbers to give an idea of the field of view, as with the endless sensor formats out there it gets impossible fast.
For example I have a friend who won't buy a compact camera unless it gets to 24mm equiv at the wide end. That's a whole lot simpler than getting his calculator out to work out angles of view for every sensor size. Plus people do usually get that smaller sensors will have more DoF and more noise at common EVs. (Although these days it seems that the endless push for faster processors to smudge away the noise is the bigger problem, especially if a raw format isn't available. Don't get me started on cameras that do noise reduction on raw...)
John
 Dr_Jon's gear list:Dr_Jon's gear list
Fujifilm FinePix Real 3D W3 Sony RX100 Canon EOS 5D Mark II Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH3 +23 more
Mark B UK
Contributing MemberPosts: 905Gear list
AFAIK there have so far been no independent reviews of the 35-100. But there have been several of the 12-35 (try searching in this thread for links). All say performance is very high indeed, that maximum aperture is very good, with peak performance being reached only 1-2 stops down and staying pretty consistent until diffusion cuts in at (from memory) f/11 onward.
It's my guess that the 35-100 will be slightly better even than the 12-35, on the basis that short to medium tele zooms generally outperform wide angle to short tele ones from the same maker and in the same series. Also it is rumoured that the 35-100 will be around 50% more expensive, so I would expect its performance to be even better than the cheaper optic's.
 Mark B UK's gear list:Mark B UK's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Panasonic 12-35mm F2.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS
Dr_Jon
In reply to Mark B UK, Jun 9, 2012
I just wish the 35-100 would come out in time for the Olympics, would be ideal to take to the Athletics. (The "alleged" rules on what you can carry in photographic-wise would be a bit borderline with a Canon 70-200 f2.8 on a FF camera, plus I'd rather not lug the weight around all day. Also you don't get back anything they confiscate!)
John
bobn2
Forum ProPosts: 26,120
Brian Mosley wrote:
And
There was nothing wrong with his statement. Are you trying to stir up controversy? Or what?
Bob
bobn2
I don't think that it is a case of 'taking the fight to the big boys'. There is nothing comparable to these two lenses in the ranges of 'the big boys'. The closest ones would be the Canon 24-104/4 and 40-200/4 and the Nikon 24-120/4 but those are really serving something different. Hopefully, by not vainly trying to match the operational characteristics of the big tope end zooms on the Nikon and Canon systems, but specifying and designing with and emphasis on compactness and quality, Panasonic will exploit markets those two cannot address.
Bob
g2van
Contributing MemberPosts: 660
Based on Panasonic's current line of premium lenses, I'd expect both the fast zooms to be great. I would pre-order the 35-100 once it's out for pre-order, but from a store that allows returns. The wait time will be long for this I believe. To be fair, I don't expect the performance to be as good (accurate fast AF and IQ) as the Canon 70-200 f2.8 L Mk II, so long as it's reasonably close enough, I'll be happy to carry something so much smaller and lighter and weather-sealed.
Adventsam
Veteran MemberPosts: 4,983
In reply to bobn2, Jun 9, 2012
What?
Apart from the Sony and Pentax offering oem lens for 16-50, only Tokina have available 2.8 options for Can-ikon. Canon do have the nifty 15-85 though, but its certainly not f2.8 constant, so they start out at about the same c/w FF, but as soon as you zoom in on the Canon, hmm. Its definitely a fab range, the 12mm being better than 22mm on the GH2 in 16:9, possibly the widest zoom out there with a tele capability, nice, want. I hope that street price matches the pre-order deal price of last week, damm.
Bob
Dr_Jon
In reply to Adventsam, Jun 9, 2012
?? Canon 17-55 f2.8 is an excellent lens. Not really sure I follow anyway, these are just a pair of lenses with the same FoV and exposure as the Canon/Nikon Pro staples 24-70 f2.8 and 70-200 f2.8. They won't give the DoF or noise (or resolution) of those lenses on FF bodies, but then again they are much (much) smaller, which is the m43 selling point over FF.
Brian Mosley
Sorry Bob...
bobn2 wrote:
Brian Mosley wrote:
And
Glad you feel that way Bob, and no... just trying to add simple qualification to the equivalent statement without stirring up controversy.
Sorry the link was broken - here's the correct one :
Read more: http://the.me/sensor-equivalence-size-does-matter-or-does-it/#ixzz1xJisObZx
Cheers
Brian
Olympus E-M1
Dr_Jon
Re: Sorry Bob...
A couple of minutes later I posted three broken links in another thread, so no problem with that (plus I was commenting not complaining)...
Krishna Das
Both Nikon and Canon have each a 24-70mm f2.8 - I know, I've owned the Canon and now still own the Nikon.
Same with the 70-100mm F2.8...
kd
Brian Mosley
Completely agree John, thanks & see corrected link to Bob. /nt
In reply to Dr_Jon, Jun 9, 2012
Olympus E-M1
bobn2
Re: Sorry Bob...
Brian Mosley wrote:
bobn2 wrote:
Brian Mosley wrote:
And
Why did it need the qualification. There is no controversy, it seems, that 12-35 on FT is equivalent to 24-70 on FF or that 35-100 is equivalent to 70-200, so far as AOV is concerned. It's so uncontroversial that the manufacturers mark it on the lenses.
Thank you for that. I must admit, a failed to grasp what was the point of the piece, or what bearing it has on the point you were making above, except to say that you seem to concur with Joe James' definition of 'equivalent' photos.
Bob
