Canon EOS 60D battery charging via USB?
Started Jun 8, 2012 | Discussions
rgsverma
rgsverma Forum Member • Posts: 51
Is it possible to charge the battery via USB. I got my charger damaged due to high power fluctuations. New charger from vendor will take 15 days or more. So, can I charge my 60D battery via USB route in the meantime. Otherwise, I will have to buy a third party, non-conforming type of charger, which will also be redundant when the original supply comes in.
Kindly suggest?
RGS Verma
 rgsverma's gear list:rgsverma's gear list
Canon PowerShot SX50 HS Nikon D300 Canon EOS 60D Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II Nikon AF-S Nikkor 300mm f/2.8G ED VR II +4 more
Canon EOS 60D
Pastynator Contributing Member • Posts: 913
Re: Canon EOS 60D battery charging via USB?
In short, no. Sorry.
If you really need the cam you'll have to get the 3rd party i guess.
It won't be redundant because it can be a backup in situations like this, or even be used to charge 2 batteries at the same time in tight situations when you don't have much down-time.
TTMartin
TTMartin Veteran Member • Posts: 7,304
I don't know where you live, but, Amazon shows most vendors here in the US have the genuine Canon charger in stock.
Wasabi Power Battery and Charger Kit for Canon LP-E6 is a 3rd party charger that adds an automotive power adapter, so at least when you were done that would be an added capability.
Kindly suggest?
RGS Verma
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
