Nikon D3200 Blurry. Not happy
Started Jun 7, 2012 | Discussions
Mark Parren
New MemberPosts: 4Gear list
Jun 7, 2012
I tried a D3200 and was very unhappy, all the pictures were blurry. Tried a second D3200 with same results.
My D300 & D40x were much sharper, I tried sever different lens, all with the ISO 100 or 200 (the lowest setting).
Any one else do side by side comparison, with same lenses.
 Mark Parren's gear list:Mark Parren's gear list
Sigma 150-600mm F5-6.3 DG OS HSM | S
Nikon D300 Nikon D3200 Nikon D40X
Barry Fitzgerald
Forum ProPosts: 29,888
Re: Nikon D3200 Blurry. Not happy
In reply to Mark Parren, Jun 7, 2012
Are you sure the AF is working ok on the D3200? (ie it's accurate not front/back focus etc)
I'd pop it into live view just to check
Nikon have had some AF issues of late across various bodies it's worth looking into it.
Mark B.
Forum ProPosts: 18,581Gear list
[edit]
no text
joejack951
Senior MemberPosts: 2,682Gear list
All of the images look soft. The D3200 images appear more soft mostly because they are magnified more at 100% view. The softness appears to be camera shake and not a focus miss though. At what shutter speeds were these images shot? Note that if you shot the D3000 at ISO 200 and the D3200 at ISO 100 (the base ISO for each) you used a shutter speed twice as long with the D3200 contributing to even more camera shake.
 joejack951's gear list:joejack951's gear list
Nikon Coolpix AW100 Nikon Coolpix P7700 Nikon D300S Nikon D3S Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
Mark Parren
In reply to joejack951, Jun 7, 2012
All images are 100% crop, no editing, these are the results of many tripod and hand held VR shots, both MF & AF, different lenses, not one image from d3200 was sharp. Both the D300 and D40x delivered consistently tack sharp, while I could not get one from both D3200 I tried.
Deleted1929
Forum ProPosts: 13,050
We need the EXIF data from each shot to properly diagnose. How about posting the actual images without processing ( or cropping ) ?
You should not that when you start hitting these extreme resolutions ( and 24Mp is a heck of a lot ) you need exemplary technique and lenses used optimally to get pixel sharp resolution. Even from your screen shots it's obvious you're not doing that.
The 18-200 at 200mm isn't up to your expectations anyway - it's just not designed for such extreme resolutions ( even center frame ).
I'm not sure what the Sigma's performance is at 500mm, but I'd be very surprised if it's designed to cope with that level of resolution.
StephenG
jon404
Senior MemberPosts: 2,039Gear list
In reply to Deleted1929, Jun 7, 2012
But sjgcit, if you buy a camera, isn't there an implied warranty that you should get sharp pictures, particularly with a lens from the same manufacturer? I mean, unless it's a Holga, it should be sharp in daylight, out of the box, just by definition as a Nikon?
I think he should go try the Nikon lens on a different 3200, and see what happens...
Deleted1929
Are you being serious ?
In reply to jon404, Jun 7, 2012
Image sharpness is a result of a combination of factors and the single most important of these is the technique applied when shooting. Regardless of what lens you put on any body that is true.
And lenses do not produce arbitrary levels of detail. You can't simply squeeze more pixels into the same area on the sensor and get more detail from the lens. So if you zoom in at 100% ( pixel peeping ) then it's incorrect to expect more detail. Some lenses may, in some parts of the frame and in ideal conditions, produce enough detail to allow you to do this, but it's easily lost by even slight errors in technique.
In any case, image quality has nothing to do with pixels. The quality of the image is the viewer's perception of the image as a whole.
StephenG
richardplondon
Veteran MemberPosts: 9,622Gear list
sharpening
IMO, there is a big distinction to draw between whether something is sharp (noun), and whether something has been sharpened (verb). In order for something to appear clear and well-defined pictorially, we need BOTH aspects to have been taken care of suitably.
Sharpness of an image is a quality to do with optical performance, number of pixels, focus and shake. We know that an image is unsharp when no matter what we do to it in our postprocessing, or in our camera settings, we cannot get the expected detail level to show.
Sharpening is an image processing activity - which we do with camera settings, or Raw conversion, and also any later enhancement in an image editor. We know that an image is unsharpened when we CAN improve its apparent definition by means of added sharpening.. which tells us, that the softness was not inherent - that latent detail IS "in there", we are just not presenting it properly.
Here I took the lower example in the OP's screenshot (from the 500mm lens) and extracted the right hand side. For fairer comparison - since more magnified images tend naturally to look softer - I reduced it to the same scale as the image on the left. Then I sharpened the extract on the right in Photoshop - using Smart sharpen (not especially carefully).
I think this demonstrates it to be at least as well focused and steady as the other one is. There is also slightly more real detail and better tonal subtlety - though perhaps the lens has nothing more to give. The exposure and the angle are slightly different but seeing these side-by-side the image on the left has an oversharpened look to me, with the lighter tones a little crude. The image on the right shows slightly lower overall contrast, but that is again a matter of processing or otherwise, of camera settings. I only applied sharpening here.
So perhaps you can either adjust your expectations about what you initially see (making due allowance for the fact that at 1:1 the greater megapixel image will always tend to look less clear) - and then process the image further - or else if it's a question of straight-out-of-camera JPG, perhaps you can have the camera apply more sharpening before you view the image.
However, sharpening can always be added but cannot be so easily taken away once committed into pixels. Going too far gets horrible fast. So erring on the side of less rather than more in-camera, is IMO prudent and this may be what you are seeing here... some cameras are set conservatively in the factory, in the expectation that the user is going to further postprocess the output or turn up the strength to his or her individual taste.
Just like the salt in a restaurant meal - it is better to have the kitchen put slightly less in than most people like, rather than slightly more; and then to supply some at the table for those who want to add it.
regards, RP
 richardplondon's gear list:richardplondon's gear list
Panasonic Lumix DMC-LX100 Pentax K-5 Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited +7 more
rraheja
New MemberPosts: 2
In reply to Mark Parren, Nov 4, 2012
Did you get any resolution on it? Did you try another piece or different lens? I just went from a D5100 to D3200 for its wifi capabilities, lighter weight, 24MP resolution, newer technology, EXPEED3 etc. etc. I so wanted to like it and keep the camera. However I am facing the same issues you are.
Almost 75% pictures are blurry. While some are genuinely out of focus, others are clearly in focus but with camera shake. And these are pictures taken in bright sunlight at a kids soccer field at following settings:
Lens: 55-200mm
S: 1/1000-1/2500s
A: f4 to f5.6
VR ON
So all the recommendations for "sharpness" aside, the pictures were still blurry even at the high shutter speed.
My older D5100 took similar pictures at 1/500 with no shake as of date (of course focus in AF-C mode with kids was a hit-and-miss though), but the pictures in focus were SHARP.
Even the D3200 metering seems way off overexposed with the grass very brightly "glowing" (and almost always shaky) while the kids faces are not too sharp (it is correctly focused on their face) and very less contrast. The D5100 metering captured the grass and players accurately.
Wondering whether to go back and exchange for another piece (is this defective), or simply return it back and go for the D5100. They will probably allow one exchange so I don't want to get stuck with another D3200 if it turns out bad.
Thanks!
Raj
jon404
If this is still unresolved, suggest going to Aperture priority at a midpoint setting... like f/5.6 or f/8... and the auto-focus should work well enough, even at 500mm. Right?
Jonathon Donahue -- Olympus XZ-1 tips at http://jon404.com
johnh2007
New MemberPosts: 10
Re: sharpening
In reply to richardplondon, Jan 24, 2013
"Sharp" is an adjective, by the way, not a noun. I bought a D3200 in August and I have not seen any issues with sharpness (a noun).  I previously had a D40 and the images from the 3200 are superior  in every way - detail, colour balance, and especially dynamic range. I use the 18-105 lens and the 55-200 VR. At first I couldn't understand why when zooming in at 100% the images didn't look as smooth. Then I realised that on the 3200, because there are 24 million pixels, you are zooming in 6 times as much, so you are looking at a section of the image which is 6 times smaller. I now compare images from the D40 at 100% and from the 3200 at about 40%. This then a truer comparison and the improvement is more obvious. I am very impressed by the video quality. At first I tried continuous focussing, but it kept hunting. I now set the shutter speed at 1/100th and in good light it gives a nice small aperture so that I get a good depth of field. If I want to have a close up with good bokeh I up the shutter speed to 1/400th and a small aperture. Even at this short shutter speed the vifeISPs very smooth. I set the ISO to a max of 400. This is a superb camera. I am now going to buy the Nikon ME-1 microphone.
Osvaldo Cristo
Veteran MemberPosts: 3,835Gear list
Some considerations on higher pixel density camera sensors
In reply to Mark Parren, Jan 24, 2013
It is an old thread, but it can be usefull for some one using a searching engine.
Additionally to eventual front/back focus, you would have expect more blurring when see an image at 100% in cameras with different pixel density. The D3200 has the doulble of pictures than the D300 at the same sensor size, so they have quite different pixel density.
The lens limitations will be more evident and perfectly detectable for lower end range - that is one reason most people that go to D800 try to use insanely great quality lenses! Add to that more reflaction and other optical artifacts and you have a big source for headache.
If all above is not sufficient, the camera handling is much more critical as you increase the pixel density (all other variables maintained same). It is easy to check even the slight instability can ruin an image at a higher density image sensor.
My suggestion is to check the camera for front/back focus, get the best lenses you can, to work on appropriate lens aperture and to invest in your technique.
There is no free lunch!
Best regards,
O.Cristo - An Amateur Photographer
Opinions of men are almost as various as their faces - so many men so many minds. B. Franklin
 Osvaldo Cristo's gear list:Osvaldo Cristo's gear list
Olympus Stylus 1030 SW Nikon D200 Nikon D300S Nikon D810 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED +32 more
Ritesh Biswas
New MemberPosts: 1
In reply to rraheja, Jan 17, 2014
Hi
i'm ritesh biswas
i'm facing some problem in my photography
i'm using now nikon d3200 with AF-S Nikkor 18-105mm , 3.5-5.6G ED Lens.
and my pictures are so blured..
i want to take sharp pictures.. but i don't know whats wrong thing going on in my photography
please friends
help me
suggest me
how to take i sharp pictures ..
this is my recent pictures ... pplease friends
tell me what is going wrong thing in my photography .. please help me ..
darklamp
Senior MemberPosts: 3,567
Is this a joke ?
In reply to Ritesh Biswas, Jan 17, 2014
Your images are perfectly sharp. Were you trying to be funny ?
Lightpath48
Senior MemberPosts: 3,336Gear list
Not a good standard comparison
In reply to Mark Parren, Jan 17, 2014
If you are enlarging views at 100% for comparison side-by-side the higher resolution camera will look less sharp. For a better comparison the higher resolution image should be downsized (preferred) or the lower resolution image should be upsized accordingly (less preferred). The better way to compare is as many reviewers now do: by printing equal sized enlargements of the identical subject at the same size from both cameras, with the same lens under controlled lighting conditions and matched settings, including sharpness, dynamic range, noise control, etc. Chances are your D3200 is fine, especially if you bought it new. Nikon's quality control should be assumed close enough for most eyes.
 Lightpath48's gear list:Lightpath48's gear list
Sony Cyber-shot DSC-RX10
unknown member
(unknown member)
Re: Not a good standard comparison
In reply to Lightpath48, Jan 17, 2014
But if you have to downsize significantly or to the same resolution as the lower MP camera then there has been no real improvement in the higher MP camera, which wouldn't be surprising.
Lightpath48
OP is judging as 1:1. Not so.
In reply to Basalite, Jan 17, 2014
No text.
Parmz
New MemberPosts: 1
In reply to Mark Parren, Apr 13, 2014
Hi! you can learn some tricks and settings from web to capture finer pictures. This is a great camera but requires some practice as many times we get blurry pictures, I agree with you.
Kennyf99
New MemberPosts: 2
In reply to Ritesh Biswas, Feb 8, 2015
You're photos are sharp and it looks like they have a shallow depth of field and if you are using auto focus the camera will automatically decide on the focus points for you as no doubt that's what will have been the case here. You could try stopping down your aperture, depth of field to f10 or f14 or more so that way you can get the background in focus (you can do this in aperture priority or manual mode), but for potriat shots a shallow depth of field is preferable as the person in the shot is the primary focus point and so its better the background doesn't take away from that.  If you are using one of the modes on the camera (e.g. portriat) or in P mode the settings are determined for you, which again possibly looks to be the case here, so it could be better if you try setting your camera to aperture priority or even manual setting where you can set all the camera settings yourself i.e. shutter speed, depth of field and ISO.  I'd also probably see if there are some tutorials on youtube for your camera aswell to give you some tips on taking photos the way you want to.  I'm new to this camera as well and have been into photography for just over a year myself so I think it all takes a bit of practise.  Hope that's of some help.
